Old June 20th, 2015, 05:29 PM   #1
br1ckd
Motorcycle(s): 07 EX250
Installing camshafts and timing chain guides
I tore down the top end of my engine but I can't get the cams back on. Once I set the timing and pull all the slack in the timing chain to the intake side of the engine and I start tightening the brackets that hold the cams down, the chain is pulled off the cam towards the exhaust side of the engine (pic below). I think it might be caused by the front/exhaust cam chain guide being installed incorrectly. I'm using a Haynes service manual and this guide, but they both just say to install it and don't say how, so I just dropped it in the engine in front of the cam chain. I did find a parts diagram, so I know I didn't put it in backwards or upside-down, though.
br1ckd is offline   Reply With Quote
Old June 20th, 2015, 06:52 PM   #2
Linkin
Down Under
Linkin's Avatar
Motorcycle(s): Kawasaki ZXR250C Ninja
Step #1: Rotate crank to TDC for cylinder 1.
Step #2: Install cams with the cam chain as tight as possible on the exhaust side (with cam chain tensioner removed). Use cam caps with light torque to hold them in place
Step #3: Tighten cam caps to spec & install cam chain tensioner.
Linkin is offline   Reply With Quote
Old June 20th, 2015, 06:55 PM   #3
ninja250r81
ninja250r81's Avatar
Motorcycle(s): 2012 ninja 250r se
Need to get a timing degree wheel.
If the timing chain is old it looks like the chain is stretched. if you line up off the exh the int will be out and the opposite the other way. this is where adjustable cam timing int and exh will come in handy.
If its a new timing chain degree off the int side. Rotate the internals from tdc two or three times from the crankshaft and see what degree timing is out after that. Then adjust the valve clearance after that.
ninja250r81 is offline   Reply With Quote
Old June 20th, 2015, 09:48 PM   #4
It is very important that the brackets go back to the exact position and orientation that they originally had, since the journals are machined after those assemblies are in place.
You can remove all the tension from the chain by removing the chain tensioner and then installing each camshaft with no care about angular position or synchrony.
Align the sprockets by the manual, install the chain guard and then the cam chain tensioner.
Please, read these:
https://www.ninjette.org/forums/show...01&postcount=4
https://www.ninjette.org/forums/show...2&postcount=18
Old June 21st, 2015, 01:32 PM   #5
br1ckd
The service manual and link I posted both say it should be done with cylinder 2 at TDC. Other than that, that's exactly what I've been doing.
That's what I did.
It's an old chain, I'll measure how much it's stretched later today. What's a timing degree wheel?
Old June 23rd, 2015, 09:44 AM   #6
spooph
spooph's Avatar
Motorcycle(s): '08 Ninja 250R
MOTM - Oct '15
also ready this post: https://www.ninjette.org/forums/showthread.php?t=229378
It is difficult to get the chain to settle while tightening the caps back down....
Tighten a few turns, check the chain on the sprocket, then tighten some more.
Sometimes it's not just a drop-in and tighten situation.
Old June 23rd, 2015, 07:06 PM   #7
br1ckd
Thanks for the tip, I'll try it this weekend.
Old June 26th, 2015, 09:02 PM   #8
ninja250r81
That's what I did.
https://www.google.com.au/search?q=t...w=1680&bih=921
[motorcycle.com] - BMW C650GT and C600 Sport Recalled for Faulty Timing Chain Tension Ninjette Newsbot Motorcycling News 0 May 27th, 2014 12:40 PM
Ex.side timing chain guide alex.s 2008 - 2012 Ninja 250R Tech Talk 5 September 23rd, 2012 10:09 AM
Timing chain ticking n4mwd 1986 - 2007 Ninja 250R Tech Talk 15 April 27th, 2011 05:09 PM
[sportrider - latest stories] - Video: Performance Upgrades - Installing A 520 Chain Ninjette Newsbot Motorcycling News 0 October 30th, 2009 03:10 PM
[roadracingworld.com] - Friday Video: Project GSX-R750 -- Installing A 520 Chain Kit Ninjette Newsbot Motorcycling News 0 October 29th, 2009 11:10 PM
