Old September 30th, 2013, 07:34 AM   #1
mikromo
Motorcycle(s): 1970 Moto Guzzi Ambassador, 1999 Honda VFR800, 2001 Kawasaki ZRX1200R, 2010 Kawasaki ninja 250 (sold)
rear brake issues
I bought a 2010 Ninja 250 a couple of weeks ago, largely because a local dealer tried to rip off the PO. She rode it to the dealer with rear brake issues (pads worn slick). Once there they REMOVED the rear master cylinder and refused to let her ride it home. So, when I bought it the rear master cylinder was in a bag, and the rear brake completely inoperable. So last week I got new pads, and yesterday I installed them and attemped, with a mighty Vac, tried to bleed new dot 4 through the system. I can't get any brake fluid to bleed through. Now I have bled many brakes over the years, but this one has me flumoxed. I even took off the brake line from the top of the MC and can see fluid, but no amount of manipulating the rear brake pedal even causes fluid to pump out. Is there a bench bleed procedure for the MC?? My Mighty vac will hold 25psi vacummn all day long, with no brake fluid leaving the resevior. I'm thinking of buying a syringe and trying to "back bleed" it (thought I had one but no where to be found). Any advice? Please.
mikromo is offline   Reply With Quote
Old September 30th, 2013, 08:34 AM   #2
Originally Posted by mikromo View Post
............My Mighty vac will hold 25psi vacummn all day long, with no brake fluid leaving the resevior.................
It seems that the whole problem is in the master cylinder.
It should freely pump down the hose from the reservoir.
I think you meant 25 inches of mercury, since 14.7 psi is the maximum achievable vacuum.
Old September 30th, 2013, 09:12 AM   #3
cuong-nutz
cuong-nutz's Avatar
+1
HalfFast Racing Team
Old September 30th, 2013, 11:25 AM   #4
Lychee
sail away
Lychee's Avatar
I would replace the master cylinder. You could also rebuild it if cost is an issue, but replacement is better. It sounds like the piston is stuck inside.
As a side note, from the info given, it doesn't sound like the dealer was ripping the PO off at all. It sounds like she didn't want to pay for a rear master cylinder replacement, which you have discovered is actually necessary. Although the dealer should have returned her key when she asked for it and paid the bill. I don't think refusing is within their rights while advising against would be. You probably got a smashing good deal on the bike though.
Old October 1st, 2013, 08:44 AM   #5
JAG
Motorcycle(s): 2010 Kawasaki Ninja 250
Put pressure on the plungers to get them started. No fluid coming
Out of open bleed screw when brake applied not sure the problem
Last futzed with by JAG; October 1st, 2013 at 02:41 PM.
JAG is offline   Reply With Quote
Old October 1st, 2013, 02:19 PM   #6
mikromo
Taking it apart tommorow (the m/c) I'll clean the bejesus out of it, pre load the lines, caliper, and m/c, and try again. I'm thinking sploog in the return hole. But if not....it's a new one. The reason I think the shop was trying to rip off the PO, is they wanted to sell her a m/c, a new caliper, a new disc, + pads. The disc is within spec, The pistons in the caliper move freely...... they were quoting her near $700.00. Rip off in my book.
Old October 2nd, 2013, 04:33 AM   #7
mikromo
Couldn't wait for today, so last night after dinner I went into my workshop and got busy. It was a stuck piston in the M/C. There was quite a bit of corrosion around the snap ring and washer that holds it together, and the part of the rod that touches the "business end" of the piston looked kinda rusty, fluid probably had never been changed, so at some point it absorbed some water. Upon inspection the seals looked brand new, so I carefully cleaned everything, worked on the "piston" with 1500 grit sandpaper, cleaned up the cylindr bore with fine steel wool (no hone that small) lubed everything with dot4 and reassembled. WALA! Rear brakes (not that I missed them). Should be even more fun to ride now, knowing that all is right, and I can see some brake sliding may be in my future, as I'm an old dirtbike racer. Saved me $178.00 (Ron Ayers) for a new one, so, so far I've got $32.00 in repairs in my $900.00 special, spent on EBC pads. Thanks for all of the helpful comments!!
Old October 2nd, 2013, 09:51 AM   #8
nice work.
Rear Brake Lever Travel is Excessive and Rear Brake won't Lock Tire. N-m 1986 - 2007 Ninja 250R Tech Talk 14 July 17th, 2014 04:13 AM
08+ rear wheel, right rear set, rear brake system, seat cuong-nutz Items Wanted 2 October 6th, 2013 05:37 PM
Rear Brake Doesn't activate Brake Light And DOT3/4 FRONT BRAKE OIL coelgrim 2008 - 2012 Ninja 250R Tech Talk 16 March 11th, 2013 05:10 PM
Brake Issues SSANGHA 2008 - 2012 Ninja 250R Tech Talk 9 November 5th, 2012 09:49 PM
Rear Shock Issues .... ninja3575 2008 - 2012 Ninja 250R Tech Talk 15 January 2nd, 2011 01:21 PM
