Old November 17th, 2013, 04:12 PM   #1
mikedabike64
Motorcycle(s): 2008 ninja 250
jetting question
Hi Iam trying to use my questions wisely as not to become a pest.
I installed a uni air filter now at full throttle the bike bogs and surges,
I have some 114 DJ Main jets left over from my old ninja 500.
But I was wondering if I just started by shimming the needles would I be correct?
The bike ran fine prior to the air filter change, so I think there is a air fuel conundrum.
I was hoping to hear from others that might have shimmed the bike.
Theses little bikes seem touchy, so I want to work on it in small increments.
Thanks mike h
mikedabike64 is offline   Reply With Quote
Old November 18th, 2013, 05:30 PM   #2
Lucagst
Lucagst's Avatar
do you have a jet kit on the bike? if not put the 114 jets in and take the bike for a spin and c if a gets better
Lucagst is offline   Reply With Quote
Old November 18th, 2013, 07:34 PM   #3
mikedabike64
Ok thanks no jet kit, I do have 114 Mains left sitting around, I will give it a try with & with out the snorkle & added shims,
I have the bike stripped down with everything off, except the carbs, the stock air box looks like there is little room to pull the carbs out. I saw the demo with the pods & carb removal hopefully it is the same.
Thank you.
Old November 19th, 2013, 08:56 AM   #4
A replacement filter shouldn't make a huge change in mixture that would make it run terrible.
I think there may be a couple of things going on.
Cold temps. Cold air will make you run lean. If you are on the border of being lean in warm weather you'll be lean when it cools off.
Summer gas. Summer gas won't vaporize properly in cold weather.
Old gas or condensation. If the tank have been low for a while you can get condensation that will make it run poorly.
You can add the shims, but it's not going to get you good WOT running. Shimming the needles richens the mixture from off idle up to where the needle is out of the jet - then it's all controlled by the main.
A 114 main would be way too much with just the mods you have.
Old November 19th, 2013, 02:01 PM   #5
mikedabike64
ok thanks jk
I will proceed with much caution and the skill of a drunken sailor, I think you're right there are couple things going on like that for sure. Thank you. Small changes, snorkel no snorkel old filter new filter two shims no shims, and a couple of strip carburetor bolts ha ha.
Jetting Question msebastian 2008 - 2012 Ninja 250R Tech Talk 7 February 5th, 2013 01:11 PM
Jetting Question Zaydoc 1986 - 2007 Ninja 250R Tech Talk 9 March 23rd, 2012 02:11 AM
Jetting question deadzed 1986 - 2007 Ninja 250R Tech Talk 5 March 8th, 2012 12:44 AM
jetting question lotus168 2008 - 2012 Ninja 250R Tech Talk 12 April 10th, 2011 02:26 AM
Jetting Question crankinaway 2008 - 2012 Ninja 250R Tech Talk 1 June 9th, 2010 12:18 PM
