Old October 29th, 2016, 03:45 PM   #81
sickopsycho
One ugly son of a gun.
Motorcycle(s): 2012 250
Originally Posted by Triple Jim View Post
My procedure for setting idle mixture is to adjust for maximum RPM, erring very slightly on the rich side. Others may prefer different methods. The needle position should have close to zero effect on the idle mixture.
I kicked them both back out to my original setting of 2.5 turns out and it runs fine now. I guess I should listen to the old adage... if it ain't broke, don't fix it =)
Thanks, Jim.
sickopsycho is offline   Reply With Quote
Old October 29th, 2016, 06:15 PM   #82
Originally Posted by sickopsycho View Post
Well, I pulled the carbs out and raised the needles 1 position. The bike now runs quite a bit better in the midrange... Just really smooth. Unfortunately now my butter smooth idle has a bit of a surge to it. Not much, I can hear it more than see it in the tachometer... Is that an indication of imbalance or what? I leaned the air/fuel mixture screws by 1/4 turn (all the way in, then out 2 1/4 turns), but they are both in the same position... Not sure what would have caused this.
EDIT: Didn't see your reply before writing this
Turn the idle mixture screws back out.
I usually tune the idle mixture like Jim does - highest RPM then 1/16 to 1/8 richer or until you start to hear a drop in RPMs.
Cold temps will lean the mixture, so the idle mixture adjustment can change. Gas with ethanol gives you a leaner mixture than gas without on a carbed engine.
Former lurker here with some tech questions... sickopsycho 1986 - 2007 Ninja 250R Tech Talk 6 October 3rd, 2016 04:42 AM
ecotrons tech questions. bigbadbob 1986 - 2007 Ninja 250R Tech Talk 1 April 17th, 2015 10:50 AM
Tech Questions 08ninja250 2008 - 2012 Ninja 250R Tech Talk 6 February 25th, 2011 08:41 PM
New Here, Have some Tech Questions btovar250r 2008 - 2012 Ninja 250R Tech Talk 6 February 12th, 2011 10:54 AM
[topix.net] - Motorcycle Tech Questions and Answers Ninjette Newsbot Motorcycling News 0 September 3rd, 2010 05:40 PM
