Go Back   ninjette.org > Marketplace > Motorcycle-related
Closed Thread
Old December 14th, 2011, 01:55 PM   #1
Broc
Broc's Avatar
Motorcycle(s): 2009 Ninja 250R Black - Sold / 2011 Honda CB1000R
Sold
BIKE IS SOLD!
I'm getting a new bike and this one is gone. Saturday it will be traded into a dealership unless someone steps up privately. If no one wants the thing all aftermarket goodies will be stripped and put up for sale on this site.
I loved this bike very much but it is time to move back to Honda. This would make a complete package for something just starting out to motorcycling. It comes with everything you need to do all your own maintenance as well. I already have a for sale ad out & about so I will just copy it over.
I AM VERY FLEXIBLE ON PRICE!!!
For Sale - $3000 OBO
2009 Kawasaki Ninja 250R
Metallic Black Diablo (Rare / Only available in 2009 Kawi's)
11,700 Miles & Counting
Very clean 1 owner 2009 Ninja 250R. Purchased the bike brand new off the showroom in 2009 and have taken imaculate care & maintenance of the bike. Bike has never ever been laid over or seen pavement. Bike has been adult/mechanic owned, garaged kept, washed, & serviced religiously. Bike has been stripped down to the frame every winter, cleaned, & every system gone through. You will not find greater attention to detail or maintenance. This bike is as clean as you will find. Bike averages between 50-65mpg! Bike runs very strong and is mechanically sound.
-(Bike has currently just been stripped, cleaned, waxed, & maintenance up to date. Bike received a full look over top to bottom & complete buff/wax job as off 10/25/2011.)
Bike has also been treated to several aftermarket modifications to clean up the bike. I also have ALL OEM PARTS that will go with the sale of the bike.
- Gold RK520 106 Link Chain, JT Steel 15t front sprocket, & Lightweight steel 45t rear sprocket waiting to be installed ( Bike currently has JT 15th front sprocket and stock 45t rear sprocket / Bought new chain & sprockets for future preventative maintenance)
- BikeMonkey LED Integrated Tail/Brake/Turn signal light with OEM Kawasaki connections - NO WIRING SPLICING HAS BEEN DONE, THIS IS A COMPLETE PLUG & PLAY TAILLIGHT / I have also left connections for the stock rear turn signals if you would like to run both.
- LED Turn signal relay - Must have for use with the integrated tail light
-Under tail license plate mount with custom LED tag lights / AGAIN NO WIRES SPLICED , COMPLETE PLUG & PLAY INTO OEM CONNECTORS / I have asked several law enforcement officers about the location of my license plate & the LED lights and all of them had no issues with it's placement. The tag is clearly visible especially at night with the LED's.
- Slip on HMF Black street exhaust w/ baffle
- Upgraded front foot pegs in silver
-Air box snorkel removed
-Kleen air system removed (Removed popping under deceleration with slip-on exhaust)
- Both Carburetors have had the needles shimmed and slides drilled ( Tuned for slip-on exhaust - Bike pulls strong all the way to redline and fires up in the cold with no choke!)
- OEM Kawasaki Metallic Black Diablo Solo Seat Cowl w/ extra rubber grommets
- Tank pad
- EBC Rear Brake Pad / Stock Front Brake Pad
- Rear Black Swing arm Spools/Sliders
- (2) Brand new Shinko Podium 006 tires / Upgraded rear size to a 140 tire / Tires have 200 miles on them ( Stock IRC tires were not worn out & will also go with the sale of the bike)
- (1) Brand new set of NGK Spark Plugs installed & (1) set for future maintenance
- Oil always changed with K&N filter and Repsol FULL Synthetic racing 10w-40 oil / Fresh oil/filter & freshly cleaned OEM air filter.
ADDITIONAL EXTRAS:
- All OEM/Stock parts
(1) Used set of the stock IRC Road Winner tires 30-50% tread life remaining
(1) Copy of the Kawasaki OEM Service Manual in .PDF digital form ($110.00 value)
(2) Both front & rear black motorcycle stands. The rear uses the rear swing arm spool lift and the front uses the correct pin for a head lift. ($120.00 value - as seen in pictures)
(1) I will also include a complete auto/motorcycle tire changing stand/setup which includes a tire balancer w/ sticky weights, Mojo no scratch mount/demount bar, Mojo no scratch wheel clamps, 2 piece tire changing stand/bead breaker, & a custom made pallet platform for mobility. ($400.00 value)
2009 Black 250R - Stock and staying that way. No matter what you do it's still a 250 at the end of the day! Save your money for gear, riding lessons, & a 600cc
Last futzed with by Broc; January 23rd, 2012 at 06:54 AM. Reason: SOLD
Broc is offline
Old December 14th, 2011, 02:19 PM   #2
nice bike. glws
alex.s is offline
Old December 14th, 2011, 02:34 PM   #3
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Pretty good deal
AFM #676
Supersports are for n00bs
Jiggles is offline
Old December 14th, 2011, 02:36 PM   #4
Broc
Broc's Avatar
Thank you sir. Just lowered the price to $3000. Come and get it!!!! The dealer already mentioned they are going to list it at $3600 STOCK without anything! WOW!
Broc is offline
Old December 14th, 2011, 02:58 PM   #5
flynjay
flynjay's Avatar
Where are you located? America is a little too vague
flynjay is offline
Old December 14th, 2011, 03:28 PM   #6
DreamN
Beer Me!
DreamN's Avatar
Motorcycle(s): '13 Ninja 300 Car(s): '09 Cube, '93 240SX (Coupe & 'Vert)
You're selling everything mentioned for $3k obo? WOW!
I bet you're no where near Southern California though.
DreamN is offline
Old December 14th, 2011, 04:21 PM   #7
Broc
Broc's Avatar
Isn't it insane the price difference?? Even at this price people don't even bother with 250's. Only girls & squids ride 250s don't ya know?
I am located in Kansas. I had thought about taking my bike to Cali for a week just to sell it, the market is that good there. I saw similar while I was on vacation in Florida recently.
It was 60 out today and I took her for one last ride with everything on it.
I really am gonna miss this bike. There probably is no other street bike I will ever be able to ride like this thing. My ride went so well it has me double thinking trading up, seriously. Decisions Decisions.......
Broc is offline
Old December 14th, 2011, 05:20 PM   #8
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Just get both!
AFM #676
Jiggles is offline
Old December 14th, 2011, 07:36 PM   #9
Cazper
ninjaholic
Cazper's Avatar
GLWS, thats a bangin deal I'll be one of the vultures that says... if you do part out I may be interested in the solo seat cowl and stands depending on prices
09' SE Ninja 250R
$2,547.83
Cazper is offline
Old December 14th, 2011, 09:26 PM   #10
94fiveohvert
Motorcycle(s): ninja 250r, crf 50
Where in Kansas?
94fiveohvert is offline
Old December 14th, 2011, 09:37 PM   #11
flynjay
flynjay's Avatar
I would totally make you an offer if I had the spare cash. I ended up getting a non-running 07 that is almost ready to ride.
flynjay is offline
Old December 14th, 2011, 09:54 PM   #12
Broc
Broc's Avatar
You have a PM sir. Just got done taking everything aftermarket off the bike. Parts will be up soon I guess...
Broc is offline
Old December 15th, 2011, 08:11 AM   #13
burningscooter
clutch
burningscooter's Avatar
Motorcycle(s): L1 GSXR600
pm me a price for the bikemonkey shipped to 21701.
burningscooter is offline
Old January 23rd, 2012, 06:50 AM   #14
Broc
Broc's Avatar
Sold
Bike is SOLD!
Broc is offline
Old January 23rd, 2012, 08:28 AM   #15
massacremasses
Avid Kitteh Poster
massacremasses's Avatar
Motorcycle(s): 2006 Yamaha TTR 50 SUCK IT
so any part out thread or was it sold with everything on it?
I powdercoat stuff Help me pay for my addiction
I say funny stuff. http://twitter.com/JustinPWNSyou sometimes...
I write like a 12 year old too, http://justinpwnsyou.wordpress.com/
massacremasses is offline
Closed Thread
SoCal 2009 Ninja 250R Price is OBO! ez12a Motorcycle-related 2 May 31st, 2014 06:55 PM
2009 Ninja 250r - NJ, $2000 obo dimeified Motorcycle-related 0 September 2nd, 2013 12:31 PM
FS: 2010 Ninja 250, Kansas City $3100 obo thurt88 Motorcycle-related 2 November 2nd, 2012 10:31 PM
2009 Ninja 250r - Culpeper, Virginia ($3500 obo) Live2ride Motorcycle-related 2 June 8th, 2012 09:44 AM
2009 Ninja 250r Black low mileage (pittsburgh PA) - 3700 OBO Xuracing Motorcycle-related 4 June 5th, 2011 01:16 PM
