Old August 7th, 2018, 11:40 AM   #1
s7rokers
Motorcycle(s): 08' Ninja 250r
Question Will a ZX11 rear shock fit our Ninja 250r?
Hi guys, was wondering if by any chance the ZX11 rear shock will sit into our 250 r nicely?
s7rokers is offline   Reply With Quote
Old August 7th, 2018, 12:37 PM   #2
gantt
gantt's Avatar
not sure about that, but a gsxr600/750 shock can be adapted with a little work. many threads covering that here. you may have to buy a used shock and see if the zx11 will fit
Old August 8th, 2018, 05:13 AM   #3
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
center to center is 12.6"
you can pick up a progressive that bolts right in low 300's
"trying not to get old"
Old August 8th, 2018, 05:15 AM   #4
s7rokers
Question
As in the length of the shock for our 250?
Old August 8th, 2018, 06:11 AM   #5
maverick9611
MOTM - Feb '18
but of course it's made for newgens.
https://www.progressivesuspension.co...shock-kawasaki.
i found it cheaper on amazon. go to my godzilla reborn thread. i did a little chat about it.
they 2 colors brown and black. the large letter B at end of part # means black
Old August 8th, 2018, 08:45 AM   #6
Measure length of ZX11 shock, if it's 320mm (c-t-c), then it will fit. After you install it, you will find it's very stiff due to extra 100kg weight of ZX11 over Ninjette.
Old August 8th, 2018, 09:43 AM   #7
s7rokers
Thumbs up
Noted with thanks!
Old August 8th, 2018, 09:43 AM   #8
s7rokers
Thumbs up
thank you!
Old August 8th, 2018, 09:43 AM   #9
s7rokers
thank you!
Old August 8th, 2018, 09:44 AM   #10
s7rokers
thank you!
Old August 8th, 2018, 10:09 AM   #11
gantt
gantt's Avatar
thank you!
its my understanding the gsxr shock is a decent spring rate for our ninja's. due to the gsxr using a different linkage setup, it adds leverage to spring so the rate needed to be lighter. which ends up being a pretty good budget shock upgrade for about 30 bucks. takes a little modification but nothing crazy.
not rally adding leverage TO the spring, but taking the force of the spring, and once it passes through the linkage it was at a higher force, because of the fulcrum (leverage) effect the linkage provided.
Old August 10th, 2018, 01:32 AM   #12
s7rokers
and I was ogling at this too LOL
https://item.taobao.com/item.htm?spm...ne=taobao_shop
Old August 10th, 2018, 04:41 PM   #13
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
JMO stick with what is tried and true. The GSXR shock is the way to go. Lots of people have tried other shocks and they don't seem to work as easily or as well or at all. It's impossible to say if a shock will work or not or without too much fuss with out having it in hand and a bike stripped down to check clearances with.
From my experience there is always something that just doesn't quite fit/work correctly, this is why the GSXR shock is the way to go, it's practically bolt on.
Old August 10th, 2018, 04:45 PM   #14
maverick9611
MOTM - Feb '18
whats tried and true is the progressive. it bolts right on. no mess, no grinding, just bolt it on, adjust preload and go
Old August 11th, 2018, 08:49 AM   #15
Ralgha
Ralgha's Avatar
I don't see any place to specify rider weight when ordering that progressive shock. What weight is it set for?
bike * miles = smiles
smiles / bike = miles
smiles / miles = bike
Old August 11th, 2018, 09:10 AM   #16
maverick9611
MOTM - Feb '18
you have to look on progressive details/info page. i have it open so i will give you the specs
center to center 12.60 or 320mm
compressed length 10.10 or 257m
travel 2.50 or 64mm
spring # 04-1466-20B
rate 425/570 lbs or 7.59kg/10.18mm
this is for part #435-1001(435 series shock)
Old August 11th, 2018, 05:33 PM   #17
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
I'm talking about conversions/shock swaps which cost about $50.
Few years back you could find a couple nice aftermarket shocks for the 250r in the $300-$600 range. I feel like Elka had some nice ones in the $400 range and Ohlins had one for a bit more. Been awhile since i looked at any of that stuff.
Old August 11th, 2018, 06:17 PM   #18
maverick9611
MOTM - Feb '18
since you live in Singapore, member bernawanfr from Indonesia might be your ticket on getting a name brand shock at a bargain price. he has helped me on a couple of sinnob poly sprox transactions and it went quite smooth. let me and i will contact him.
Old August 13th, 2018, 04:04 AM   #19
s7rokers
You have a PM
Old August 13th, 2018, 04:06 AM   #20
s7rokers
YSS front fork upgrade kit
I will be flying to Bangkok on the 15th to pick up the upgrade kit
Old August 13th, 2018, 04:10 AM   #21
s7rokers
A mechanic told me that i should not be running on a K&N filter if I do not have a power commander on board as the machine would be running lean?
Old August 13th, 2018, 06:11 AM   #22
taz
taz's Avatar
MOTM - May '17
a power commander is not going to do a thing for a carbed bike, there for fuel injected. unless it has been converted to a fuel injected setup.
Old August 13th, 2018, 06:15 AM   #23
s7rokers
Oh! Mine is a FI model
Old August 13th, 2018, 06:24 AM   #24
taz
taz's Avatar
MOTM - May '17
is it a k&n drop in filter(factory replacement) or a k&n pod filter setup?
Old August 13th, 2018, 06:25 AM   #25
s7rokers
K&N drop in filter.
Old August 13th, 2018, 06:39 AM   #26
taz
taz's Avatar
MOTM - May '17
that shouldn't change it enough that it would need a retune
Old August 13th, 2018, 07:24 AM   #27
s7rokers
That's what I thought so too!
Anyway, I have already drop the K&N in LOL!
Old August 13th, 2018, 10:28 AM   #28
s7rokers
[IMG][/IMG]
Old August 13th, 2018, 10:29 AM   #29
s7rokers
[IMG][/IMG]
Old August 13th, 2018, 10:42 AM   #30
s7rokers
Tried searching for the Power Commander V for my model but it seems like they do not make for the FI 250r?
Old August 13th, 2018, 11:27 AM   #31
taz
taz's Avatar
MOTM - May '17
power commander is an american made product and over here in america the 250r is carbed, but you could write to there technical support and ask them if the one for the 300 would work for yours and that would give you a straight answer.
Old August 13th, 2018, 12:09 PM   #32
gantt
gantt's Avatar
wasn't the 250 offered for several years as a FI bike? i cannot understand how anyone would have wanted a carb bike over FI. two shop price carb rebuilds and cleanings would probably equal what the FI would have cost over carb
Old August 13th, 2018, 12:31 PM   #33
taz
taz's Avatar
MOTM - May '17
the 250 was never factory offered with fi in america, there is company's out there that sell conversions for them though
Old August 13th, 2018, 11:27 PM   #34
Certainly do... http://bfy.tw/JOqF
2010 Ninja 250r - Rear Shock, Adjustment Tool, and Linkage conrya5 Motorcycle-related 19 June 2nd, 2013 02:57 PM
WTB - 08/09 Ninja 250R Rear Shock conrya5 Items Wanted 2 September 26th, 2012 06:39 AM
