August 2nd, 2017, 12:30 PM | #1 |
‘94 Rider
Join Date: Nov 2010 Motorcycle(s): 1994 Kawasaki Ninja EX250F Posts: 81
Perfectly Running Bike Stalls Out
My 1994 runs absolutely perfect, and idles as it should also. No issues at all, except this random but rare issue where it stalls out at a normal idle (in neutral, sidestand down).
Heres the scenario. I like to let the engine run after i get back from a ride, while im taking my helmet and other gear off. So i pulled into my driveway, put the bike in neutral and put the sidestand down and left the engine on. After about 20 seconds, the bike randomly shuts off with no warning. No struggling noises, no rough idle or anything. Just shuts off all by itself. It starts right back up too. This is driving me nuts more than anything, it doesnt happen often, but its annoying when it does. First time it happened, i thought it was because i was pretty much at the point of needing to switch to reserve. This time though, i have plenty of fuel and am about 60 miles away from hitting reserve. Also, the bike doesn't have the symptoms of being starved of fuel, like would be the case if youre at/near the point of switching to reserve. Any ideas guys? Any possibility of a safety switch problem in the scenario I described? Again, bike running in neutral, sidestand down, no rider on it, bike quits running. |
August 2nd, 2017, 01:31 PM | #2 |
Have you checked your battery voltage? I'd check it before starting (should be 12.7 or more) and while cranking (should be over 10V, engine cold and choke off so it doesn't start).
Then start it up and read the voltage at idle. It should be more than it was before cranking and around 13V. Then rev the engine to 4000 and see that it went up again. Does it do the same thing if you have the stand up or are on the center stand? If not, check the connections and lube the switch on the sidestand. Does it ever do it in traffic at a stop sign? Is your hot idle set to 1300? Have you made adjustments to your idle mixture? |
August 5th, 2017, 10:38 AM | #3 | |
‘94 Rider
Thanks again! |
August 5th, 2017, 03:56 PM | #4 |
Try looking at these,
https://faq.ninja250.org/wiki/Unders...afety_switches https://faq.ninja250.org/wiki/My_sid...27t_work_right https://faq.ninja250.org/wiki/Checki..._safety_switch https://faq.ninja250.org/wiki/Cleani..._clutch_switch Hope this helps
August 5th, 2017, 10:27 PM | #5 |
Measure vacuum level going to petcock. What is vacuum @ 4000 rpms? Vacuum @ idle?
August 6th, 2017, 12:46 PM | #6 |
Join Date: May 2017 Motorcycle(s): 2001 Kawasaki Ninja 250r(SOLD) 2006 Kawasaki Ninja 250r full Muzzy(my pride and joy) Posts: 331
Hmmm wonder if it's something as simple and stupid as the kickstand sensor? Mine was acting funny it wouldn't run in neutral with the kickstand down or it would but it would shut off. Took a look at the thing and the whole area was dirty as hell. Cleaned it up and haven't had an issue in 2 weeks. Not saying that's your issue but just throwing it out there. Never know.
Looks like Ghostt might have eluded to it already.
"A car or truck will get you from point A to B. But a motorcycle, that is the point." -unknown |
August 9th, 2017, 05:49 PM | #7 | |
Join Date: Mar 2017 Motorcycle(s): 2007 Kawasaki 250 Ninja, 1982 Honda Ascot FT500 Posts: A lot.
Just a thought. Bill |
Bike stalls out instead of starting | Ballardst | 2008 - 2012 Ninja 250R Tech Talk | 10 | September 27th, 2016 11:28 AM |
[motogp.com] - Lorenzo: “Brno is beautiful and suits the bike perfectly" | Ninjette Newsbot | Motorcycling News | 0 | August 17th, 2016 06:50 AM |
Bike stalls, rattles, and won't idle properly | goldfox | 1986 - 2007 Ninja 250R Tech Talk | 19 | September 3rd, 2015 01:37 PM |
Bike stalls when touch throttle | Cycy | 2008 - 2012 Ninja 250R Tech Talk | 31 | May 20th, 2013 12:35 AM |
Please Help - Bike not running well | CampinCracker | 1986 - 2007 Ninja 250R Tech Talk | 14 | November 15th, 2011 12:51 PM |
