Old August 24th, 2014, 07:54 AM   #1
joecool
Carb to Intake rubber boot clap leaking
Hey guys,
I noticed that 1 of the rubber boots that connect the carb to the motor is dirty, looks like it is starting to leak. How do i fix this? Do i just tighten the clap screw? If it needs replacing is it an easy repair?
Thanks!
Joe
Posted via Mobile Device
joecool is offline   Reply With Quote
Old August 24th, 2014, 08:17 AM   #2
Start by trying to snug it down. Clean the area and watch for the same thing again.
You can also spray carb cleaner around the clamp after you snug it down. If the RPMs change when you do it at idle there's still a leak.
FS: Motion Pro Syncpro Carb Tuner (Carb Sync) $60 Shipped menikmati Motorcycle-related 4 April 8th, 2020 12:39 AM
Valve adjustment, carb clean, carb sync? amad1972 1986 - 2007 Ninja 250R Tech Talk 2 July 29th, 2014 09:42 PM
Intake boot ktp1598 1986 - 2007 Ninja 250R Tech Talk 2 December 10th, 2013 07:51 AM
Leaking Carb- Out of ideas.... drew13 1986 - 2007 Ninja 250R Tech Talk 7 May 10th, 2012 04:12 PM
07 ninja carb. and intake? fivepin 1986 - 2007 Ninja 250R Tech Talk 2 March 26th, 2010 04:02 AM
