Old June 27th, 2020, 12:59 AM   #1
anthonyjclarke
Motorcycle(s): Ninja 300 SE ABS, Honda CUB
Dash Dead (Intermittent), Front Lamps on, Wont Start
Newbie here, and new Ninja 300 SE ABS, well 2013 model, but new for us as Learners working on getting our licence here in Sydney, Australia. Had a bit of a wobble last weekend when practising for the test, tight u-turn manoeuvre and the bike and i fell over with little movement, all good but since then and its happened 3 times now your turn the ignition and none of the dash lights up, BUT the lights come on! Today I checked all the fuses and put them back, all seemed fine but still did not light up. It was only when I moved the handlebar from left to right and pressed the handbrake that it came to life. Twice today that has been the solution to getting it to come back to life. Anyone any advice on what to start looking at next? Really appreciate it and a case of beer via PayPal for your fixing solution ;-) Video here - https://i.imgur.com/4Q4V2SV.mp4
Last futzed with by anthonyjclarke; June 27th, 2020 at 01:09 AM. Reason: Adding link to video
anthonyjclarke is offline   Reply With Quote
Old June 27th, 2020, 10:02 AM   #2
I would say to start by looking for a broken wire or bad connector if you can get it to work by moving the bars side-to-side.
What happens when you hit the starter button?
Have you done anything to the ignition switch?
Cycle is in neutral, correct?
Have you checked the battery voltage and terminals to make sure they are tight?
Also posted at kawasaki ninja .com
Last futzed with by jkv45; June 27th, 2020 at 04:25 PM.
Old June 27th, 2020, 11:07 AM   #3
Hi Anthony and welcome to Ninjette!
Seems your tipovers may have loosened or broken something. My personal philosophy is that things are in one of two states: working and non-working. Typically what causes things to flip states from working to non-working is some sort of impact or smack. So to reverse states, you smack it again!!!
With key ON, gently grab wiring harness coming out of each handlebar control and gently wiggle it. Does dash turn on? Move aobut 10cm down harness and wiggle again. Then move and wiggle again. Repeat for other handlebar control. Also inspect harness connectors and disconnect and reconnect to ensure each one has good fit.
Something probably got knocked loose with no permanent damage. Just a matter of finding what that piece is by wiggling. Key to troubleshooting is scientific methodical testing with gathering lots of data (ideally quantifiable), and ruthless usage of boolean logic.
Old June 27th, 2020, 02:16 PM   #4
anthonyjclarke
Thanks for the welcome, and pointers.. that's my Sunday job today.... appreciate it, will come back with any findings (hopefully!)
Old June 27th, 2020, 02:37 PM   #5
If you don't find anything obvious, we'll have to break out multimeter and measure voltages at various points and entre into spreadsheet table with multiple columns. One for each state of key. Another column for state of start button. In programming, this is called a "finite state machine" with anticipating all possible combinations.
Let's hope you find loose connector beforehand....
Old June 27th, 2020, 04:11 PM   #6
anthonyjclarke
Thanks DannoXYZ, as a programmer I'm with you Bugs hard to find sometimes!
Bike wont start yet again Edhead 2008 - 2012 Ninja 250R Tech Talk 11 November 24th, 2017 10:55 AM
250R wont start webfoot 2008 - 2012 Ninja 250R Tech Talk 6 January 10th, 2015 11:43 PM
- - -Bike Wont Start - - - Triple R 2008 - 2012 Ninja 250R Tech Talk 1 July 31st, 2014 06:54 AM
Bike wont start, please help? zev42 2008 - 2012 Ninja 250R Tech Talk 11 November 9th, 2010 01:02 PM
uhh, bike wont start. ajaygraci 2008 - 2012 Ninja 250R Tech Talk 37 June 24th, 2009 06:39 PM
