June 21st, 2022, 02:00 PM | #1 |
[webbikeworld.com] - 2022 Harley Davidson Road Glide Limited [Specs, Features, Photos
Click here for full story...
The 2022 Harley Davidson Road Glide Limited: The Touring Icon Contents With a bike this good, no significant changes were need from Harley Davidson. The Road Glide Limited has everything one could want to make a great 2-up touring ride. Shared across the 2022 Harley Davidson lineup, the powerful Milwaukee-Eight® 114 engine has 119 lbs-ft of torque to move the Limited with ease, even laden down with gear and humans. The Sharknose fairing looks just right and shows the American Bagger roots at the heart of this bike. The Tour-Pak luggage provides ample space that can easily house both rider and passenger helmets along with extra travel essentials. The Road Glide Limited is loaded with features like heated grips, cruise control, and awesome floorboards. The Reflex Defensive Rider System is an option, but let’s face it, you know you are adding those very useful electronic rider aids, they are well worth it. Get your gear, crank up the Boom! Box GTS Infotainment System, and point yourself down the highway.. 6 Color choices for the 2022 Harley Davidson Road Glide Limited:
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Harley Davidson Road Glide Limited in one place. Model Overview </p>General Info
Main Specs
Competitor 2022 Harley Davidson Road Glide Limited Specifications ENGINE EngineTwin-Cooled*Milwaukee-Eight®*114Engine Torque122 ft-lbBore x Stroke4.016 in. x 4.5 in.Compression Ratio10.5:1 Fuel SystemElectronic Sequential Port Fuel Injection (ESPFI)StarterExhaust2:1:2 dual exhaust with 4 in. tapered mufflersDRIVETRAIN ClutchTransmission6-speedPrimary DriveGear, 34/46 ratio CHASSIS Front Fork49mm Dual Bending Valve Rear ShocksPremium standard height hand-adjustable rear suspension Wheels, Front TypeSlicer II cast aluminum with clear coat Wheels, Rear TypeSlicer II cast aluminum with clear coat Brakes Front32 mm, Dual floating rotors Brakes Rear4-piston fixedTires FrontBW 130/70B18 63H Tires RearBW 180/55B18 80H Fuel Tank Capacity6 gal.ColorVivid Black (Chrome Finish), Mineral Green Metallic (Chrome Finish),Gauntlet Gray Metallic/Vivid Black (Chrome Finish),Vivid Black (Black Finish),Reef Blue/Vivid Black (Black Finish)ELECTRICAL IgnitionSpark PlugsHeadlightAll LED headlampTail LightLEDDIMENSIONS Length102.2 in. Trail6.7 in. Rake26Wheelbase64 in. Ground Clearance5.1 in. Seat Height27.2 in. Weight, As Shipped897 lb. WARRANTY WarrantyExtension 2022 Harley Davidson Road Glide Limited Features MILWAUKEE-EIGHT® 114 ENGINE The most displacement in standard H-D® Touring models. You get 114 cubic inches of passing and horizon-chasing power. REFLEX LINKED BREMBO® BRAKES WITH STANDARD ABS Designed to help prevent the wheels from locking under braking to assist the rider in maintaining control when braking in a straight-line. ABS operates independently on front and rear brakes to keep the wheels rolling and help prevent uncontrolled wheel lock in urgent situations. BOOM! BOX GTS INFOTAINMENT SYSTEM An evolved interface experience that offers a contemporary look, feel and function, with exceptional durability and features designed specifically for motorcycling. Every element is optimized to enhance the rider’s interaction with the bike and connectivity with the world. FRAME-MOUNTED SHARK NOSE FAIRING A distinctive aerodynamic shark-nose fairing with triple split stream vents that deliver smooth air flow and reduce head buffeting. HEATED HANDGRIPS Equipped with six settings, so you can easily adjust on the fly for the heat you need. RESPONSIVE SUSPENSION High-performing front and rear suspension with easily adjustable rear shocks put you in control of a plush ride. PREMIUM TOUR-PAK® LUGGAGE CARRIER A sleek yet spacious Tour-Pak® luggage carrier with luggage rack that can easily house both rider and passenger helmets along with extra travel essentials. 2022 Harley Davidson Road Glide Limited Photos 2022 Harley Davidson Road Glide Limited Videos New 2022 Harley Davidson Road Glide Limited Motorcycle | 10 Things to Know: 2022 Harley Davidson Road Glide Limited: Links Harley-Davidson Official Websites Social Media Links The post 2022 Harley Davidson Road Glide Limited [Specs, Features, Photos] appeared first on webBikeWorld.
[webbikeworld.com] - 2022 Harley Davidson Road Glide Special [Specs, Features, Photos | Ninjette Newsbot | Motorcycling News | 0 | June 20th, 2022 07:23 PM |
[webbikeworld.com] - 2022 Harley Davidson Road King Special [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | June 13th, 2022 07:31 AM |
[webbikeworld.com] - 2022 Harley Davidson Street Glide [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | June 13th, 2022 07:15 AM |
[webbikeworld.com] - 2022 Harley Davidson Road Glide [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | June 13th, 2022 07:15 AM |
[webbikeworld.com] - 2022 Harley Davidson Road King [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | June 13th, 2022 06:54 AM |
