Old June 21st, 2022, 08:25 PM   #1
[webbikeworld.com] - 2022 Harley Davidson Road Glide ST [Specs, Features, Photos]
Click here for full story...
The 2022 Harley Davidson Road Glide ST: 117 Kinds Of Perfect!
Contents
The Road Glide ST is the machine many have been aching for Harley Davidson to send us. Everything has been blacked out for a menacing look that never lets you forget that this Road Glide is packing the Milwaukee-Eight® 117 and 126 lbs-ft of torque. Front tire size is 19 inches and the rear stays at 18 inches. With the overall clearances being higher, and this tire combination, the ST should feel more nimble than other Road Glide models in the 2022 Harley Davidson lineup.
This epic American bagger has 2.3 cu/ft saddlebags with one-touch opening. The bags are the smaller set which sits a bit higher for a bit more clearance. The only option available is the package of Cornering Rider Safety Enhancements. Sit back behind the sick-looking Shark Nose frame-mounted fairing, turn up the Boom! Box GTS infotainment system and just roll.
2 Color choices for the 2022 Harley Davidson Road Glide ST: Vivid Black, or Gunship Gray
The 2022 Harley Davidson Road Glide ST starts at $29,999 USD / $36,999 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Harley Davidson Road Glide ST in one place.
Model Overview
</p>General Info
  • Price: $29,999 USD / $36,999 CAD
  • Key Features:
    • Milwaukee-Eight® 117 V-Twin engine
    • Bronze Prodigy Wheels
    • Boom! Box GTS infotainment system
    • Optional RDRS Electronics Package
Main Specs
  • Engine: 117 ci V-twin
  • Power: 103 HP (estimated)
  • Torque: 126 lbs-ft @ 3750 RPM
  • Wet Weight: 842 lb. (382 kg)
  • Seat Height: 26.7 in. (715 mm)
Competitors
2022 Harley Davidson Road Glide ST Specifications
ENGINE
EngineMilwaukee-Eight®*117Engine Torque127 ft-lbBore x Stroke4.075 in. x 4.5 in.Compression Ratio10.2:1
Fuel SystemElectronic Sequential Port Fuel Injection (ESPFI)StarterExhaustDual, with crossoverDRIVETRAIN
ClutchTransmission6-speedPrimary DriveGear, 34/46 ratio
CHASSIS
Front Fork49mm Dual Bending Valve
Rear ShocksPremium standard height hand-adjustable rear suspension
Wheels, Front TypeBronze Prodigy
Wheels, Rear TypeBronze Prodigy
Brakes Front32mm Dual floating rotors
Brakes Rear4-piston fixedTires Front130/60B19 61H
Tires RearBW 180/55B18 80H
Fuel Tank Capacity6 gal.ColorELECTRICAL
IgnitionSpark PlugsHeadlightAll LED headlampTail LightLEDDIMENSIONS
Length94.7 in.
Trail6.7 in.
Rake26Wheelbase64 in.
Ground Clearance5.5 in.
Seat Height26.7 in.
Weight, As ShippedVivid Black, Gunship Gray
WARRANTY
WarrantyExtension
2022 Harley Davidson Road Glide ST Features
MILWAUKEE-EIGHT® 117 V-TWIN
The new pinnacle of torque and displacement with a factory-installed powertrain. Precision oil/air cooling. 126 ft. lbs. of torque at 3750 RPM. Tuned heavy breather intake and high flow exhaust maximize engine performance, a boost you can feel with every twist of the throttle.
West Coast Styling
BLACKED OUT EVERYTHING
Front end, controls, powertrain and exhaust. The only bright bits are pushrod tubes and tappet covers, and machined cylinder fins.
SPORT TOURING PROFILE
Standard bag height for a trimmed look and more room to lean.
FIXED SHARKNOSE FAIRING
This frame-mounted fairing keeps the cross-winds and traffic buffeting at bay, with a design that is unmistakably Harley-Davidson.
STANDARD FEATURES
  • Standard Anti-Lock Braking System (ABS)
  • Boom! Box GTS infotainment system with color touch screen, two fairing-mount speakers and hidden radio antenna
  • Emulsion-technology rear shocks, with a single knob to hydraulically adjust pre-load for optimal ride and control
  • 49mm forks with dual bending valve suspension technology
  • Daymaker LED headlamps
  • Smart Security System with proximity-based, hands-free security fob
OPTIONAL CORNERING RIDER SAFETY ENHANCEMENTS
  • Cornering Electronically Linked Brakes
  • Cornering-ABS
  • Cornering-Traction Control with modes
  • Drag Torque Slip Control
  • Vehicle Hold Control
  • Tire Pressure Monitoring (TPMS)
2022 Harley Davidson Road Glide ST Photos
2022 Harley Davidson Road Glide ST Videos
Harley Davidson Road Glide ST Test Ride!
Review – 2022 Road Glide ST:
Links
Harley-Davidson Official Websites
Social Media Links
The post 2022 Harley Davidson Road Glide ST [Specs, Features, Photos] appeared first on webBikeWorld.
[webbikeworld.com] - 2022 Harley Davidson Road Glide Limited [Specs, Features, Photos Ninjette Newsbot Motorcycling News 0 June 21st, 2022 02:00 PM
[webbikeworld.com] - 2022 Harley Davidson Road Glide Special [Specs, Features, Photos Ninjette Newsbot Motorcycling News 0 June 20th, 2022 07:23 PM
[webbikeworld.com] - 2022 Harley Davidson Street Glide [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 June 13th, 2022 07:15 AM
[webbikeworld.com] - 2022 Harley Davidson Road Glide [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 June 13th, 2022 07:15 AM
[webbikeworld.com] - 2022 Harley Davidson Road King [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 June 13th, 2022 06:54 AM
