Old July 2nd, 2022, 04:26 AM   #1
[webbikeworld.com] - 2022 Yamaha Tenere 700 [Specs, Features, Photos]
Click here for full story...
2022 Yamaha Tenere 700: Japanese Middleweight ADV Dominance
Contents
With Yamaha’s 1200cc ADV beast being sold as the Super Tenere ES, it only makes sense for the Japanese motorcycle manufacturer to offer a capable middleweight ADV stepping stone for riders seeking a more entry-priced model. The Yamaha Tenere 700 can take you anywhere, and it can do it all for a relatively low price.
Built around the CP2 engine borrowed from the MT-07, the Tenere 700 boasts a 689cc paralell-twin motor with the ability to utilize around 74 horsepower and 50 lb-ft of torque. Although those power figures pale in comparison to its much bigger brother – the 1200cc Super Tenere ES – what the Tenere 700 lacks in overallpower it is sure to make up for in manouverability. Coming in at around 450 lbs wet, the Tenere has the perfect amount of ‘flickability’ to get you out of any dicy situation you may find yourself in.
To keep this motorcycle as ‘ADV purist as possible’ at a low cost, Yamaha has ditched almost every rider aid you could possible imagine (aside from dual-zone ABS), keeping this bike low-pro, lightweight and rider-centric; the perfect middleweight ADV contender for Yamaha’s 2022 lineup.
The 2022 Yamaha Tenere 700 starts at $10,299 USD / $12,799 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Yamaha Tenere 700 in one place.
Model Overview
</p>General Info
  • Price: $10,299 USD / $12,799 CAD
  • Key Features:
    • ABS that has a true on/off setting for on-road and off-road situations
    • LED lighting all around that survives hard riding better than traditional bulbs
    • The same advanced and powerful engine that sits in the MT-07 hypernaked
Key Specs
  • Engine Type:* 689cc liquid-cooled DOHC 4-stroke
  • Horsepower: 74 HP
  • Torque: 50 lb-ft
  • Wet Weight: 450 lbs (204 kg)
  • Seat Height: 34.4 inches (875 mm)
Key Competitors
2022 Yamaha Tenere 700 Specifications
ENGINE
Engine689cc liquid-cooled DOHC 4-stroke; 8 valvesPower74 HpBore x Stroke80.0mm x 68.6mmCompression Ratio11.5:1Fuel SystemFuel InjectionStarterElectricLubricationDRIVETRAIN
Clutchmulti-plate wet clutchTransmission6-speedFinal DriveChainCHASSIS
Suspension Front43mm inverted fork, fully-adjustable; 8.3-in travelSuspension RearSingle shock, adjustable preload (w/remote adjuster) and rebound damping; 7.9-in travelBrakes FrontDual 282mm hydraulic disc; selectable ABSBrakes Rear245mm hydraulic disc; selectable ABSTires Front90/90R21 Pirelli® Scorpion® Rally STRTires Rear150/70R18 Pirelli® Scorpion® Rally STRFuel Tank Capacity4.2 galColorELECTRICAL
IgnitionSpark PlugsHeadlightLEDTail LightLEDDIMENSIONS
Overall Length93.3 inOverall Width35.6 inOverall Height57.3 inWheelbase62.8 inRake27 DegreesSeat Height34.4 inWet Weight452 lbsWARRANTY
Warranty1 Year (Limited Factory Warranty)Extension
2022 Yamaha Tenere 700 Features
TOP FEATURES
  • Advanced Twin-Cylinder Engine
    The Ténéré 700 features a fuel-injected, 689cc liquid-cooled, inline twin-cylinder engine derived from Yamaha’s award-winning MT-07. This compact powerplant features an ideal power delivery for adventure riding, for tractable and controllable power in every riding condition.
  • Adventure-Focused Ergonomics
    The Ténéré 700 features a narrow body, slim fuel tank, and flat seat that allow maximum rider agility, enabling the rider to grip the tank whether sitting or standing, giving added confidence on dirt or asphalt. The protective fairing and handguards work with the tapered handlebar to ensure comfort on the longest rides.
  • Not Afraid To Get Dirty
    Highly adjustable, long-travel suspension is mated to dirt-ready spoked wheels mounting 21-inch front and 18-inch rear tires, ensuring that Ténéré 700 doesn’t shy away from aggressive riding when the pavement ends. The triple-disc brakes also feature selectable ABS, which can be disabled when desired for off-road riding.
  • Refinement Meets Durability
    Every aspect of the Ténéré 700 is built to combine Yamaha’s legendary reliability with impressive performance, from the compact LED headlights, to the strong and narrow steel frame, to the smooth counterbalanced motor, and crystal-clear LCD gauges.
ENGINE
  • Compact, High-Tech Engine
    Developed from the stellar MT-07 Hyper Naked sportbike, the Ténéré 700 engine combines exceptional reliability and exciting power delivery in a compact, fuel-efficient package. With an overall size similar to some single-cylinder motors, the 689cc fuel-injected, liquid-cooled, DOHC inline twin gives the Ténéré 700 exceptional handing, while the counterbalanced two-cylinder design provides smooth, long-legged power ideal for long days in the saddle.
  • Crossplane Crankshaft Concept
    The two-cylinder engine features Yamaha’s “Crossplane Crankshaft Concept” 270-degree crank—which traces its lineage directly to the Dakar-dominating XTZ750 race bikes—to provide linear torque development in response to the rider’s throttle input. The CP2 engine is also light, slim and compact, and offers an excellent level of rider/machine communication.
  • Offset Cylinder Design
    The CP2 engine shifts its cylinder bores slightly forward, towards the exhaust side. This offset reduces piston to cylinder wall friction, for enhanced reliability, more power and improved fuel economy.
  • Compact Stacked Transmission
    The six-speed transmission “stacks” the gearbox and the crankshaft in a triangular layout to keep the overall engine size shorter front-to-back, which optimizes engine placement in the frame for outstanding weight balance. The transmission ratios are designed to bring out the best of the low- to mid-speed torque and excellent response characteristics, letting the rider focus on the road or trail ahead.
  • Refined Fuel Injection
    Electronic fuel injection settings have been calibrated to deliver a balance between rapid response—perfect for technical riding off-road—and smooth, linear delivery ideally matched for flowing progress when back on pavement. Boasting excellent fuel economy, robust acceleration, and precise controllability on- and off-road, the result is an extremely versatile powerplant.
CHASSIS/SUSPENSION
  • Lightweight Double Cradle Frame Design
    A lightweight, high-strength tubular steel frame provides a tuned rigidity balance for nimble, responsive handling with the strength and durability needed to tackle the harshest terrain with confidence. The chassis utilizes a short 62.6-inch wheelbase for agility and boasts 9.5 inches of ground clearance to tackle whatever the trail throws at you.
  • Balanced Ergonomics
    The ability to shift body weight forward and rearward to suit the terrain is crucial in off-road riding situations, so the Ténéré 700 features a flat seat and slim body that allows maximum rider agility. The narrow body and fuel tank also enable the rider to grip the tank whether sitting or standing, giving added confidence whether you’re riding on dirt or asphalt.
  • Adventure-Ready Suspension
    Aggressive dirt riding requires capable suspension, so the Ténéré 700 utilizes a long-travel 43mm inverted fork with 8.3 inches of travel. The beefy inverted layout is highly resistant to flex to maintain precise steering and suspension action, and the fork is fully adjustable to match changing road and trail conditions. The linkage-type rear shock is similarly outfitted for adventure, with 7.9 inches of travel, and a remote preload adjuster to easily fine tune for changing loads or riding conditions.
  • Dirt-Ready Braking With Switchable ABS
    The Ténéré 700 features a pair of wave-style 282mm front discs, with rear braking handled by a 245mm wave-style rotor, for powerful deceleration that isn’t afraid of dirt and dust. ABS comes standard to boost rider confidence and prevent wheel lock-ups in reduced-traction conditions, but the Ténéré 700 gives riders the option of temporarily disabling the system for full manual control—ideal for the unique demands of challenging off-road conditions.
  • Durable Spoked Wheels
    Unlike many so-called adventure bikes which feature cast alloy wheels or road-biased tires, the Ténéré 700 flaunts its serious off-road intentions with tough spoked wheels mounting 21-inch front and 18-inch rear tires, ideal for both on- and off-road riding. Strong and lightweight, these wheels give riders a range of tire choices, from aggressive pure enduro tires to versatile dual-sport options.
ADDITIONAL FEATURES
  • Rally-Bred LED Lighting
    Echoing the focused, purposeful design of rally-built “works” racing machines, the Ténéré 700 utilizes a clear headlight nacelle with quad LED headlights. This vertically-stacked two-plus-two headlight design provides aggressive looks and excellent visibility, while the LEDs themselves are bright, long-lasting and resistant to shock and vibration.
  • Protective, Versatile Cockpit
    The rally-inspired upper fairing and standard handguards ensure wind and weather protection ideal for long riding days. The taper aluminum handlebar is positioned for a relaxed riding position when sitting or standing on the pegs. The cockpit is also designed to accommodate additional navigation devices, such as a GPS or rally road book.
  • Rally-Style Instruments
    The lightweight instrument panel displays a wide range of information that can be absorbed without having to take your eyes off the road or track. The multi-function LCD display features gear position, fuel level, two trip meters and estimated fuel range, as well as average and instant fuel consumption and more.
  • Exceptional Range
    Thanks to the fuel efficient engine and compact 4.2-gallon fuel tank, the Ténéré 700 is ready for the Next Horizon, with a fuel range extending over 215 miles per fill-up.
2022 Yamaha Tenere 700 Photos
2022 Yamaha Tenere 700 Videos
2022 Yamaha Tenere 700 Review | Beyond the Ride
Don’t buy a Yamaha Tenere 700 without watching this first
Links
Yamaha Motorcycles Official Websites
Social Media Links
The post 2022 Yamaha Tenere 700 [Specs, Features, Photos] appeared first on webBikeWorld.
[webbikeworld.com] - 2022 Yamaha Super Tenere ES [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 June 30th, 2022 11:10 AM
[webbikeworld.com] - 2022 Yamaha MT-03 [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 June 30th, 2022 10:15 AM
[webbikeworld.com] - 2022 Yamaha MT-07 [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 June 30th, 2022 10:01 AM
[webbikeworld.com] - 2022 Yamaha MT-09 / MT-09SP [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 June 30th, 2022 10:01 AM
[webbikeworld.com] - 2022 Yamaha MT-10 / MT-10SP [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 June 29th, 2022 09:27 PM
