June 1st, 2015, 10:24 AM | #1 |
Participant
Radial Master Cylinder
Lots of people say a front brake radial master cylinder is better than a plain old regular (axial) master cylinder.
The important characteristics of a brake MC set-up would seem to be piston diameter and mechanical advantage provided by the lever arm (brake handle). What's better about the radial MC? |
June 1st, 2015, 11:55 AM | #2 | |
Fighting Texas Aggie '05
June 1st, 2015, 04:51 PM | #3 |
Great explanation Neil. I never knew there were different types of master cylinders.
June 1st, 2015, 04:57 PM | #4 |
Participant
That is a good explanation. So we're talking better feel for a radial MC.
Does anyone use (or care about) radially oriented MCs for the pedal-operated rear brake? |
June 1st, 2015, 05:24 PM | #5 |
Freedom for Germany
June 1st, 2015, 06:24 PM | #6 |
dirty boy
MOTM - Apr '14
i have a radial MC up front with my brake conversion, i don't know if i could tell the difference. I got it because it worked with the conversion
A different MC for the rear? Might be just me but i feel like doing pretty much anything to the rear brake system is a waste of money. Most people barely use it. You can get some feel from the rear but the boots and lack of sensitivity of the foot compared to the fingers you are not helping the cause. Plus i don't feel like you get the same feed back from the rear that you do from the front, there is so little weight on the rear in most hard braking scenarios that deciphering what is going on with the rear by feel can be tricky. I use the rear brake a lot, i blame my time in the dirt on that and i feel like i have about as good of a feel of it that i can get and it is still ambiguous at times. I do have my rear brake set up a little soft which i think helps a little with the feel, it's not so wooden like
New Rear Master Cylinder? | Devita818 | 2008 - 2012 Ninja 250R Tech Talk | 10 | May 10th, 2015 07:46 PM |
Retrofit: Radial Master Cylinder | ds650rida | 1986 - 2007 Ninja 250R Tech Talk | 10 | October 1st, 2014 12:01 PM |
Radial caliper and Master Cylinder Installed | psych0hans | 2008 - 2012 Ninja 250R Tech Talk | 5 | September 29th, 2014 01:46 PM |
Which Master Cylinder should i get? | krolinked | 2008 - 2012 Ninja 250R Tech Talk | 7 | January 12th, 2013 01:01 PM |
[motorcycle.com] - Brembo updates radial master cylinder | Ninjette Newsbot | Motorcycling News | 0 | July 25th, 2008 09:21 AM |
