July 1st, 2013, 07:29 PM | #1 |
Join Date: Sep 2012 Motorcycle(s): 2008 WR250X, 2008 Ninja 250R Posts: 177
Need help connecting a vacuum hose
I'm looking for some help from the Ninjette gurus to identify where the thicker hose below connects to on the other end. It connects to the top front of the carburetor (near the throttle cable) on a 2008 Ninja 250R, but I can't figure out where the other end connects. It's about 6"-12" long or so.
[url=http://www.flickr.com/photos/68853372@N05/9186491613/] Can anyone here help me identify where it goes? The bike doesn't seem to run right unless I put my finger over the end of the hose. I had the carb out to clean it, but I forgot to where this last hose connects. Thanks in advance for your help! |
July 1st, 2013, 07:48 PM | #2 |
Fix It Till Ya Break It
Join Date: Oct 2011 Motorcycle(s): 08 250RRrrrr Posts: 623
its connects to .....
nothing. its a drain for gas over flow. put over exhaust (not really) |
July 1st, 2013, 07:51 PM | #3 |
If I cover the end of the hose, the bike runs fine with choke on or off. If I don't cover it, the bike idles low when the choke is on and stalls when I pull the choke off.
July 1st, 2013, 09:38 PM | #4 |
Hi,
The hose what you mean, is not connect to anywhere. Quote:
July 2nd, 2013, 12:49 PM | #5 |
Breather/overflow hose. Stick the loose end between the air box and battery box.
July 2nd, 2013, 12:56 PM | #6 |
July 2nd, 2013, 01:35 PM | #7 |
Join Date: Dec 2012 Motorcycle(s): 2008 Ninja 250R Posts: 263
It doesnt connect to anything.
July 3rd, 2013, 10:13 AM | #8 |
That's just the catheter to eliminate the need for stops on cross-country rides.
July 3rd, 2013, 11:58 AM | #9 |
sail away
Join Date: Jul 2012 Motorcycle(s): gixxer (sold), ninjette (upgrade!) Posts: 964
win!
Unregistered found this post helpful. Track Day Preparation Checklist 1. Financial 2. Mental 3. Physical 4. Gear / Bike |
July 3rd, 2013, 01:16 PM | #10 |
July 3rd, 2013, 01:22 PM | #11 |
sail away
Did you remember to attach to rider?
July 3rd, 2013, 02:29 PM | #12 |
Now that would be a win Reddit style.
different style connecting rod bolts? | ebrammer252 | 1986 - 2007 Ninja 250R Tech Talk | 5 | June 7th, 2014 06:44 PM |
Vacuum hose cross caused leak | Quick1 | 1986 - 2007 Ninja 250R Tech Talk | 9 | December 23rd, 2013 03:19 PM |
vacuum hose routing | Sebastian f7 | 1986 - 2007 Ninja 250R Tech Talk | 2 | July 28th, 2013 07:06 AM |
Connecting rod free play | n4mwd | 1986 - 2007 Ninja 250R Tech Talk | 24 | August 5th, 2012 12:21 PM |
[topix.net] - Connecting through Christ | Ninjette Newsbot | Motorcycling News | 0 | May 3rd, 2010 05:40 AM |
