July 19th, 2013, 04:35 PM | #1 |
Join Date: Jan 2013 Motorcycle(s): 1987 Ninja 250 custom gold Posts: 218
Slipping clutch
Hi all,
I recently noticed that i had a bit of clutch slip if i am not careful with the throttle. I also remembered that i recently took apart the clutch cover to replace the oil level lens and try to figure out a problem with my clutch. When i fixed my clutch problem i tightened down the clutch spring bolts, however with a cheap Torque wrench. Do you guys think that it is a possibility that i didn't tighten the clutch spring bolts enough to put enough tension on the clutch discs? Just to mention though, the clutch has over 3000 km on it as that is how long i owned it for. |
July 20th, 2013, 10:17 PM | #2 |
Possibly a torque issue. What is the current status?
July 21st, 2013, 01:36 PM | #3 |
Do you mean, what is the torque on them?
The reason i started this thread is because i heard that clutch discs don't go very often on these bikes and more often than not its something else causing the slippage. |
July 22nd, 2013, 02:46 PM | #4 |
sail away
Join Date: Jul 2012 Motorcycle(s): gixxer (sold), ninjette (upgrade!) Posts: 964
I think he means the bolts were not torqued down enough.
Unregistered found this post helpful. Track Day Preparation Checklist 1. Financial 2. Mental 3. Physical 4. Gear / Bike |
July 22nd, 2013, 02:57 PM | #5 |
Yep, do you have a manual and a torque wrench?
July 22nd, 2013, 03:10 PM | #6 |
sail away
July 22nd, 2013, 03:24 PM | #7 |
why would you remove the clutch springs/bolts to replace the sight glass in the cover?
certain oils with friction modifiers can make the clutch go sooner. being slow / hard on the clutch or doing wheelies will too.
July 22nd, 2013, 06:49 PM | #8 | |
Thanks, i will borrow a very good torque wrench from a friend and get it spot on.
This was my first bike, and i have done 3000 km on it. I have gotten much better but i know i was hard on the clutch initially, for example engine breaking without rev matching (blipping). I will re-torque those things on my next oil change, which will be any day now. One last thing i wanted to mention was that i noticed a gear that was very loose near the clutch. If looking at the clutch basket, it is underneath it and deeper. Should it be loose? |
July 23rd, 2013, 09:26 AM | #9 |
sail away
picture...
July 23rd, 2013, 03:18 PM | #11 |
July 29th, 2013, 05:43 PM | #12 |
Well i just did an oil change and it is the oil pump sprocket that has play in it... So much so that it is visible when moved.
Is it a huge concern, i see something like a cottor pin on there? |
How to tell if your clutch is slipping? | Hero Danny | 2008 - 2012 Ninja 250R Tech Talk | 29 | July 29th, 2014 09:13 AM |
Clutch slipping isssues | wardie | 1986 - 2007 Ninja 250R Tech Talk | 1 | November 16th, 2011 06:44 AM |
{HELP} Clutch Slipping | sprtonyy | 2008 - 2012 Ninja 250R Tech Talk | 20 | April 21st, 2010 05:42 PM |
Clutch slipping? and lube? :D | kyle98927 | 2008 - 2012 Ninja 250R Tech Talk | 7 | October 20th, 2009 09:32 AM |
back tire slipping/clutch slipping???? help? | richierich781 | 2008 - 2012 Ninja 250R Tech Talk | 17 | June 19th, 2009 07:13 AM |
