Old February 7th, 2014, 06:07 PM   #1
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Pre-gen Fork Clunk
Got some questions about pre-gen front forks. One or both of the forks on my ’03 “clunk” when the fork goes from no load (no weight on the front wheel) to loaded with the weight of the bike. I can make it make the noise at will when the bike is on the center stand and I lift and drop the front wheel. It’ll make the noise on the road conditions are right (coming off a bump at a certain speed).
Is this common for higher mileage Ninjettes (mine has 26K mi)? Is the fix to add spacers between the springs and the fork caps? Or is it time for new fork springs and oil? And what brands of springs are good for these bikes?
Your thoughts and ideas are appreciated.
Old February 7th, 2014, 06:11 PM   #2
GeorgeRYoung
Motorcycle(s): EX250, C10 Concours
possibly steering head bearing
If you put some weight on the seat and loft the front wheel, you can check for play.
GeorgeRYoung is offline   Reply With Quote
Old February 7th, 2014, 06:34 PM   #3
dcj13
Participant
dcj13's Avatar
Good idea. Wife does a fine job of that, but doesn't like being in the cold garage. Was able to isolate noise to axial loading of fork tube, but only had about 30 seconds to do it.
Will try to coax her to spend 5 minutes out there with me so I can verify and repeatedly demonstrate noise.
Old February 7th, 2014, 06:52 PM   #4
Boosted139
Motorcycle(s): 2009 Ninja 250R SE, 2009 Triumph Daytona 675
It could be loose steering head bearings
Boosted139 is offline   Reply With Quote
Old February 7th, 2014, 07:10 PM   #5
dcj13
Participant
dcj13's Avatar
I was thinking that too, but I can't get any clunking with weight on the wheels or by pusining the bike with the front wheel against a wall.
I really do need to get someone to sit on the seat with the bike on the centerstand so I can wiggle and push the wheel up and down to absolutely determine exactly where and which side the noise is coming from.
Old February 7th, 2014, 08:26 PM   #6
Try walking the bike forward and playing with the front brake. If it's the stem bearings, that will replicate the noise. That's how I knew my head bearings needed replacement.
Pre Gen Fork Seals?? Dsheumaker 2008 - 2012 Ninja 250R Tech Talk 3 March 27th, 2015 04:59 PM
Do fork legs from old gen fit new gen? scorch 2008 - 2012 Ninja 250R Tech Talk 8 May 9th, 2014 08:37 AM
Pre-gen (2007 and older) and "new pre-gen" (2008-2012) frames kjohng General Motorcycling Discussion 5 February 27th, 2013 10:03 AM
Compare new-gen and old-gen fork inner/upper tube abhijitz 2008 - 2012 Ninja 250R Tech Talk 2 February 23rd, 2013 09:22 AM
Pre-gen fork seals *FREE* spooph Motorcycle-related 1 October 12th, 2010 04:50 AM
