July 25th, 2014, 11:57 AM | #1 |
Inline 4!!!
How to tell if your clutch is slipping?
A few members recommended that I checked my clutch for slipping. Since my bike will be revving at around 9k RPMS going 60 MPH (and I only weigh 150)
At first I didn't think my clutch was slipping, but now I'm starting to think otherwise. I read somewhere that you can tell if your clutch is slipping by coming to a complete stop while in 2nd gear and then slowly let out the clutch without giving it gas and you should stall out, if your bike doesn't stall then the clutch is slipping. I tried this, and my bike did not stall, which means it is slipping. However, this was on a cruiser forum where they are completely different bikes (Red line at like 6k rpms, etc.) So I wanted to know, is this test valid for our little 250's? If so, and my clutch is slipping. What would be the fix for it? Any DIY's or how-to's Thanks everyone!
July 25th, 2014, 12:12 PM | #2 |
clutch all the way out, in gear, with the bike not going anywhere....
either your clutch is slipping or you don't have a chain
July 25th, 2014, 01:06 PM | #3 |
ninjette coonass
Join Date: Nov 2013 Motorcycle(s): 08 ninja 250, 06 wr450f, x15 110, tiny 50 Posts: 30
If you can let the clutch out some what quickly with the rpms mid range, around 6-7 and get the rpms to hang there wile the bike accelerates, and you have fully released the clutch lever, the clutch is slipping
Posted via Mobile Device |
July 25th, 2014, 01:24 PM | #4 |
If the clutch lever is all the way out, you give it gas, and the engine revs higher without the bike gaining speed, the clutch is slipping. Otherwise, it's not. Your symptoms do not sound like a slipping clutch.
July 25th, 2014, 02:25 PM | #5 | |
Join Date: Mar 2014 Motorcycle(s): 2013 Ninja ZX6R, 2009 Ninja 250R Posts: 256
July 25th, 2014, 02:55 PM | #6 |
Blind 250 Loving Whore
In 5th or 6th get on the gas all the way. The revs should rise much too fast for speed gained.
July 25th, 2014, 03:10 PM | #7 |
Inline 4!!!
Thanks guys, I guess it's not slipping.
Hopefully your information will help other's questions of whether not their clutch is slipping. I'll continue to search for a solution, I think maybe my chain might be too loose. Or something of that matter o_O
July 25th, 2014, 03:16 PM | #8 |
Captain 2 Sexy
Join Date: Apr 2014 Motorcycle(s): Kwaka EX250 Posts: 241
Check your shifting technique, your clutch cable adjustment and cable lube. We did all of these things last weekend and now my bike is shifting with maybe a 1/4 inch of lever being thrown and the shifts are so fast its almost like an auto transmission. When you hit that sweet spot for that gear it is awesome.
July 25th, 2014, 06:12 PM | #9 | |
Inline 4!!!
July 25th, 2014, 06:19 PM | #10 |
Dude. It's either the CDI or the tach. I think this is an electrical problem, not a mechanical problem.
July 25th, 2014, 07:43 PM | #11 | |
Inline 4!!!
Glad to hear it's not a serious mechanical problem. Thank you
July 25th, 2014, 07:45 PM | #12 |
Well, if the CDI is off that bad, it's likely that there are power & economy issues that go along with what you're seeing.
July 25th, 2014, 07:55 PM | #13 |
Inline 4!!!
Last fill up I got 64 MPG
July 25th, 2014, 08:36 PM | #14 |
There's known issues with the tach read out as the CDI heats up. Where's a link when you need one...?
July 25th, 2014, 09:15 PM | #15 |
Inline 4!!!
I don't know much about the CDI? Where it's located, how to diagnose it. etc.
July 25th, 2014, 11:26 PM | #16 |
DaBlue provided a link in one of your other threads about the problems you are having with this bike.
https://www.ninjette.org/wiki/Ignitor_problem
July 26th, 2014, 06:18 AM | #17 | ||
....more threads on issues, diagnosis and resolutions for IC Ignitor/CDI issues. https://www.ninjette.org/forums/show...1&postcount=53 https://www.ninjette.org/forums/show...tor#post703109 https://www.ninjette.org/forums/show...9&postcount=23 https://www.ninjette.org/forums/show...tor#post675105 https://www.ninjette.org/forums/show...tor#post629663 ...another quick tip(in case you overlook it in one of the other threads). If you know somebody close by that has a 08-12 Ninja 250, that does not have rpm problems, swap IC ignitors for a test run and see what the results are. |
July 26th, 2014, 06:26 AM | #18 |
Join Date: Mar 2011 Motorcycle(s): 09 Ninja 250r Posts: 634
when you're in 5th gear going over 60 mph pull back on the throttle...if rpm's go up but speed doesn't its slipping.
”Any man dies with a clean sword, I’ll rape his f***ing corpse!”- The Hound |
July 26th, 2014, 06:27 AM | #19 |
You've been telling us about your high speed/ rpm issue, tell us what your avg low speed/rpms readings are, (say 25-35 mph, 40-50 mph, 45-55 mph). Do all of them all in 5th gear and at what temp you ride in.
It will tell you if those readings are off as well (for a stock bike). |
July 26th, 2014, 08:34 AM | #20 | |
Inline 4!!!
I'll report back once I get a chance to ride again. Why 5th gear?
July 26th, 2014, 10:09 AM | #21 |
July 26th, 2014, 12:08 PM | #22 |
Join Date: May 2013 Motorcycle(s): '75 CB550:.'82 XV920:.'00 KLR650:.'00 EX250:.'08 Ninja 250 Posts: A lot.
MOTM - June '15
Oh, I forgot, I did a test for you. 4th gear is about 70 or 80 M/H at 11,000.
I forgot and haven't ridden the bike since then. But I wrang it out in every gear to see what's what.
'82 XV920: Soon to be tracker--'00 KLR685:adv --'04 DRZ400E--'12 Super Tenere --'13 Versys Ride more, worry less. |
July 26th, 2014, 05:55 PM | #23 |
Inline 4!!!
There's no way Amy would only be doing 11k at 4th gear going 70mph. She's at 11k in 6th gear going 70mph
July 27th, 2014, 10:03 AM | #24 |
Inline 4!!!
Here are my results, (which seemed to vary by about 3-5 hundred RPM, although there may have been a slight incline/decline, wind resistance, less tuck, etc.)
All indicated in 5th gear 40 MPH = 6.5k 50 MPH = 8k 60 MPH = 10k
July 27th, 2014, 05:37 PM | #25 | |
You're still not getting numbers that tell me you're in the right gear. Using the speed vs rpm calculator for the pregen (which has nearly identical stock final gear ratios as the newgen), all your correlated speeds match right up with a pregen in 4th gear, not 5th. and your numbers for 6th are nearly identical to a pregen in 5th... I know for a fact that the pregen is not geared a full gear higher than the newgen; I've ridden both. I know it's been beat to death, but are you POSITIVE positive, 150% sure, more sure than anything in your life that you're actually in the correct gear? Are you actually starting out in 1st gear and not just thinking that 2nd is 1st, 3rd is 2nd, 4th is 5th, etc? I swear I'm not trying to suggest that you're an idiot. Really, I'm not. The numbers just match up way too closely. I guess I'm still just confused if the issue is you, the electronics on the bike, or something with your transmission. |
July 27th, 2014, 06:00 PM | #26 | |
Inline 4!!!
I know you're not calling me an idiot, you've been helping me and I appreciate it. I'm just as confused as you are. I really don't know what to say. According to the resource you supplied me with I would have to have a 11 tooth front sprocket to make these RPMS to MPH. Which is absolutely ridiculous... I am going to count my rear since I've never done so. Other than that I am completely lost, maybe it's my tranny? Or something electrical... It's completely banana's I really need to find a way to record a video of it...
July 27th, 2014, 06:05 PM | #27 |
maybe amy just likes having her neck wrung?
July 27th, 2014, 06:13 PM | #28 |
There has to be someone else in Massachusetts with a 250. Take the bike to them, and have them confirm that yours is actually behaving any differently than a normal one.
July 27th, 2014, 07:39 PM | #29 |
Your next step is swapping out either the tach or IC Ignitor or see how far past redline the tach will read before you hit the rev limiter.
July 29th, 2014, 09:13 AM | #30 | |
Inline 4!!!
I looked online, a replacement CDI is roughly $150. Kind of steep. I think i'll just not bother fixing it, as long as it's just reading high and that's all. Then what's the point? If no damage is being caused then it'll just be something else that makes my bike unique lol <3 I am getting ~65 MPG
Clutch slipping... how to fix? | walty87 | 2008 - 2012 Ninja 250R Tech Talk | 35 | September 10th, 2022 06:33 AM |
Slipping clutch | The_big_dill | 1986 - 2007 Ninja 250R Tech Talk | 11 | July 29th, 2013 05:43 PM |
{HELP} Clutch Slipping | sprtonyy | 2008 - 2012 Ninja 250R Tech Talk | 20 | April 21st, 2010 05:42 PM |
Clutch slipping? and lube? :D | kyle98927 | 2008 - 2012 Ninja 250R Tech Talk | 7 | October 20th, 2009 09:32 AM |
back tire slipping/clutch slipping???? help? | richierich781 | 2008 - 2012 Ninja 250R Tech Talk | 17 | June 19th, 2009 07:13 AM |
