Old June 3rd, 2009, 09:41 PM   #1
ak_907_ak
Motorcycle(s): 08 Ninja 250R
Post Hanging Idle
Hello,
I can't seem to figure out the problem of my hanging idle. Most times it will go back to normal idle at 1500rpm, but sometimes it will stay at 1800 to 2100 and really slowly go back down to normal. It only does it when warmed up, from what i can tell, the warmer the engine, the worse it gets.
I've read other forums and people seem to think vacuum leak would be the biggest cause, followed by: out of sync carbs, float bowl level low, valves need adjusting, o-rings in carbs where the needle sits, needle diaphragm punctured.
I've tried adjusting mixture screw, and now I am at 1.8 turns, which seems pretty low.
'08 Ninja 250R: Yoshi Full System, HID's, FP Jet Kit, Snorkel removed, LED Brakelight, LED Footpeg Turnsignals, Zero Gravity SR Windscreen, Fender Eliminator, Solo Seat Cowl, Woodcraft Clip-Ons
ak_907_ak is offline   Reply With Quote
Old June 3rd, 2009, 10:08 PM   #2
what are your jetting specs? intake and exhaust mods?
Old June 3rd, 2009, 10:16 PM   #3
ak_907_ak
snorkel removed, but airbox is still there, yoshi full exhaust
#100 main, factory pro needle, clip in the 3rd position
idle mix screw 1.8 turns out, the best i can tell (that milwaukee screw driver is not the accurate, it has some slack in it.)
This all started when i put on my exhaust and the re-jet, i completely took me carbs out, which leads me to vacuum leak or internal carb problem.
Bikes got 760 miles on it
Old June 3rd, 2009, 10:36 PM   #4
sounds like your idle mixture is too lean. I used the alternate method in this lnk.
http://faq.ninja250.org/wiki/How_do_...dle_mixture%3F
Old June 3rd, 2009, 10:45 PM   #5
ak_907_ak
all right, i will try that tomorrow, but when i first put on my exhaust, i had it set at 2.5, and when i blip the throttle it would go below idle and the raise again, but the idle would hang also...
i will try it anyway, see what happens, its easier that the alternative, which is to remove the carbs and carefully inspect everything
Old June 3rd, 2009, 10:49 PM   #6
was the bike fully warmed up when you were setting the idle? I rode mine around for 10-15 minutes, came home, then worked on setting the idle.
Old June 3rd, 2009, 10:54 PM   #7
ak_907_ak
well, what i did is since 2.5 was too rich i rode it around for an hour, went home and changed it to 2.0. Rode around another hour and still felt to rich as the throttle was still dropping below idle, so I set it to 1.8. not perfect though.
I also noticed that the choke would not work with 2.5 screws out. It would actually get so rich that it would kill the bike. Now at 1.8, I actually have to use the choke to start it in the morning, usually raises RPM by 400-700 than without choke.
Old June 3rd, 2009, 10:58 PM   #8
Something doesn't sound right.
try adjusting the idle using the link and see what happens. If you can't make any progress, remove the carb tops and check the diaphragms for tears.
Old June 3rd, 2009, 11:11 PM   #9
CANTFUNCTION
CANTFUNCTION's Avatar
Motorcycle(s): 09 ninja 250(red)
It sounds like you are to lean.
http://www.factorypro.com/tech_tunin...m_engines.html
Look at
4. Idle and low rpm cruise
CANTFUNCTION is offline   Reply With Quote
Old June 4th, 2009, 01:07 PM   #10
Buffalony
Buffalony's Avatar
I get a flat spot at 4000 in 1st, 5000 in 2nd and I think 6000 in 3rd. Theres is nothing. the bike revs higher but doesnt go any faster. Is that normal for all stock?
Old June 5th, 2009, 11:12 PM   #11
ak_907_ak
OK, I took my bike apart, looked at the diaphragm and they look fine, but i read in another threat that they should not be touched. How come?
Before i took it apart, I started it, and sprayed the pipe coming from the carb to the cylinder with starter fluid, and it suddenly picked up rpm, so maybe a vacuum leak.
Now i'm trying to put the bike back together, but i cant figure out about the 3 way split above the cylinder. One goes to the vacuum valve, and I'm not sure where the other 2 go.
Last futzed with by ak_907_ak; June 6th, 2009 at 12:24 AM.
Old June 6th, 2009, 01:10 AM   #12
VeX
That's me!
VeX's Avatar
Motorcycle(s): 2008 Ninja 250r (Tis blue), 2008 CBR600RR
That's the best way to find a vacuum leak. I had that similar problem with a supercharged vehicle and it took me forever to track down! Sure enough I had a couple of tees (one for the boost gauge, one for the blow off-valve, etc.) and the rubber hose around one of the tees started to crack and would leak intermitently. So spraying the ether on it didn't diagnose it then. It was finally me jiggling the hell out of the hoses and watching a vacuum gauge to find it. You got lucky
As for the vacuum ports, on the left cylinder (when sitting atop the bike) goes to the port in front of the carburetor, ties into the vacuum valve for the fuel, and if you still have the Klean air system the other side goes to that. Although I still have a 3 way tee there and have a check port for sync'ing the carburetors (maybe you put a test port there and forgot about it?)
VeX is offline   Reply With Quote
Old June 6th, 2009, 04:10 PM   #13
HKr1
IC2(SW)
HKr1's Avatar
Water bottle is kinda the best, it will take rpms down.
You have to be real careful spraying carb cleaner/starter fluid around. Even minutes after it looks like it has dried up..... It's still flammable. Dude in our shop almost burned an old chevy blazer to ground looking for a vacuum leak with that stuff
Old June 6th, 2009, 06:19 PM   #14
randomwalk101
self wrencher
randomwalk101's Avatar
Spray on hot running engine? What if it catch fire?
Posted via Mobile Device
Old June 6th, 2009, 08:31 PM   #15
VeX
That's me!
VeX's Avatar
Well you aren't spraying it ON the engine you're spraying it at the vacuum lines. That and being highly flameable in gasseous form, if you fog out an engine bay looking for vacuum leaks you are setting yourself up for disaster. I've always done quick burst (that's all it takes). Never tried water, but that's a good idea. Is the RPM drop as noticeable as the RPM raise that ether causes?
Old June 7th, 2009, 11:42 AM   #16
Buffalony
Buffalony's Avatar
Old June 7th, 2009, 08:13 PM   #17
ROADandTRACK
R&T Suspension
ROADandTRACK's Avatar
If the bike sat for more than a couple weeks it is most likely dirty pilot jets.
Don't spray carb cleaner in the carbs EVER!!
Must remove carbs to clean.
ROADandTRACK is offline   Reply With Quote
Old June 8th, 2009, 12:09 AM   #18
ak_907_ak
Well, I went for a 140 mile test ride today, the longest trip I have taken on the 250.
I gotta say that stock seat is pretty uncomfortable, and the fuel gauge is pretty useless. It goes from 8/8 to 5/8 in the first 10 miles, and then stays at 5/8 for the next 40 miles.
Even though I didn't do much low rpm driving, as most of the way was 60-70mph, I didn't seem to get hanging idles, and the choke seems to work too.
My only problem is the idle is inconsistent. I've got it set at 1600, but sometimes it will go to 1800 and sometimes only to 1200 (I find 1300 is way to low for idle, 1500-1600 seems to be the best). The mixture idle screws are set at 2 turns out.
I've got a GPS program on my IPhone, I just put it in my pocket and it tracks my ride for me.
Old June 8th, 2009, 03:03 AM   #19
Ken08Ninja
Motorcycle(s): 08 Ninja 250R Candy Plasma Blue
What program are you using on your IPhone for the tracking?
Ken08Ninja is offline   Reply With Quote
Old June 8th, 2009, 02:39 PM   #20
ak_907_ak
It's called Motion-X GPS. Costs 5 bucks. It will also tell you you speed, average speed and max speed, which way your heading and has a waypoint feature.
Old June 9th, 2009, 08:47 AM   #21
ROADandTRACK
R&T Suspension
I think your pilots are still dirty since the idle is going up and down.
Old June 9th, 2009, 09:25 AM   #22
Banzai
Psychic war veteran
Banzai's Avatar
I agree on the seat!
As for your fuel level gauge, its a CLASSIC indication of a bad fuel level sender. It's about a 1 hour fix to replace, start to finish, assuming your bike is in full trim. Take it back and have the shop you bought it from replace it, if you're still under warranty. Otherwise, get a confirmed good one off of ebay and do it yourself, all of the torque specs are in the service manual.
Old June 9th, 2009, 11:12 PM   #23
Buffalony
Buffalony's Avatar
Sorry to go off topic: So the fuel gauge can be fixed to work normally?
Old June 9th, 2009, 11:29 PM   #24
ak_907_ak
that was kinda funny, since everybody is complaining about that thing.
Though it has been like that since I've got it and it's only got 940 miles on it.
Is there a DIY maybe here or on some other forum so I can get a general idea of what is involved?
I changed my pilots jets with the ones that came with the Factory Pro #1 jet kit. I believe the pilots are size 40, but I'm not sure. Are you saying there is stuff stuck in the actual jet, and if so, what would be a good way of cleaning them? I'm getting pretty good at tearing my bike apart, I can have the carbs out in less than 40 minutes.
Old June 10th, 2009, 10:12 PM   #25
VeX
That's me!
VeX's Avatar
A good solution would be to A) get an inline fuel filter and
B) If you don't put a ton of miles on the bike, run carb cleaner (the stuff you pour in your tank) periodically. The stuff is meant to treat 15 or so gallons, so with a 4.8 or so gallon tank you can run 1/3 of a bottle every couple of fill-ups.
The 10% ethanol in fuel wreaks hell on the little pilot jets and main jets of these carbs so a little preventative maintenance is king IMO.
Old June 10th, 2009, 10:23 PM   #26
check the clamps that hold the carbs to the cylinder head on the rubber manifold thingy. if they are loose, you might have an air leak through there that could be the source of the idle problem.
Old June 10th, 2009, 11:29 PM   #27
ak_907_ak
When I just put my bike back together, I triple checked that those are one all the way. The each rubber tube, there is also a Cylinder side and a Carb side.
As for the fuel stabilizer, I added stabil when i put it in storage for the winter, is that what your talking about? I should still have some left.
Old June 10th, 2009, 11:32 PM   #28
try to find some Seafoam, if you can. just add some to your gas.
Old June 10th, 2009, 11:36 PM   #29
ak_907_ak
[QUOTE=kkim;67587]try to find some Seafoam, if you can. just add some to your gas.
I used that stuff before on my car, makes a huge cloud of white smoke.
i will put it just in gas, but it can also be put in the crankcase(oil) and one more place, i forgot.
Old June 10th, 2009, 11:40 PM   #30
yep, gas, crankcase and directly into the intake port by using a vacuum line. You want to get the seafoam into the carbs, which is why I suggested putting it into the gas.
have used it on a number of my older cars/trucks and yes... it makes a HUGE cloud of white smoke when inhaled through an intake vacuum port.
Old June 10th, 2009, 11:50 PM   #31
ak_907_ak
next sunday, i will try to get some seafoam by friday, and sunday, if the foam doesn't help, ill take it apart look at the pilot jets.
Old June 11th, 2009, 05:20 AM   #32
Banzai
Psychic war veteran
Banzai's Avatar
Yes, but it requires replacement of the bad sender with a good one. That's the only thing that will cure it's issues. There is bad quality control in the manufacture of the sense coil and the button/wiper assembly that make up the sender unit. Other than the shape of the tank, this is what causes the extreme non-linear function and indicating AFU levels.
I'll do a write up here shortly. I have a bad sender that I'll open up and show you all what's going on inside it and why it's bad and what else goes wrong with them.
Old June 13th, 2009, 02:17 PM   #33
Buffalony
Buffalony's Avatar
Sounds good
Old June 14th, 2009, 08:31 PM   #34
ROADandTRACK
R&T Suspension
Sea Foam is a waste, just ake 'em apart and fix it. Takes less than 2 hours.
Idle issues - Idle is different every time I start up. 106 1986 - 2007 Ninja 250R Tech Talk 6 November 13th, 2014 04:57 PM
rpms hanging badly triumphtriple 1986 - 2007 Ninja 250R Tech Talk 37 May 21st, 2014 06:47 PM
Idle jumps to 9000 rpm on choke then wont stay idle after off Shawn250 2008 - 2012 Ninja 250R Tech Talk 1 June 19th, 2012 06:45 AM
Engine hanging at 4000RPM singlecoillover 1986 - 2007 Ninja 250R Tech Talk 9 March 7th, 2010 07:58 AM
Need some help! Tubes hanging vinnywoo General Motorcycling Discussion 13 May 14th, 2009 08:25 AM
