Old June 1st, 2015, 10:24 AM   #1
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Radial Master Cylinder
Lots of people say a front brake radial master cylinder is better than a plain old regular (axial) master cylinder.
The important characteristics of a brake MC set-up would seem to be piston diameter and mechanical advantage provided by the lever arm (brake handle).
What's better about the radial MC?
Old June 1st, 2015, 11:55 AM   #2
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
Other than the fact that they are generally found in a "sportier" or "pricier" option and therefore can be made to a greater cost point (cheaply build radial masters suck too) - its the fact that the piston movement is directly inline with the movement of your pull against the lever. This provides some with a better "feel" as you work the lever. Also the construction of the actual cylinder and piston body are typically stiffer and again allows for a greater degree of feel.
Old June 1st, 2015, 04:51 PM   #3
Snake
Snake's Avatar
Great explanation Neil. I never knew there were different types of master cylinders.
Old June 1st, 2015, 04:57 PM   #4
dcj13
Participant
dcj13's Avatar
That is a good explanation. So we're talking better feel for a radial MC.
Does anyone use (or care about) radially oriented MCs for the pedal-operated rear brake?
Old June 1st, 2015, 05:24 PM   #5
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
@sharky nrk
Old June 1st, 2015, 06:24 PM   #6
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
i have a radial MC up front with my brake conversion, i don't know if i could tell the difference. I got it because it worked with the conversion
A different MC for the rear? Might be just me but i feel like doing pretty much anything to the rear brake system is a waste of money. Most people barely use it. You can get some feel from the rear but the boots and lack of sensitivity of the foot compared to the fingers you are not helping the cause. Plus i don't feel like you get the same feed back from the rear that you do from the front, there is so little weight on the rear in most hard braking scenarios that deciphering what is going on with the rear by feel can be tricky.
I use the rear brake a lot, i blame my time in the dirt on that and i feel like i have about as good of a feel of it that i can get and it is still ambiguous at times. I do have my rear brake set up a little soft which i think helps a little with the feel, it's not so wooden like
New Rear Master Cylinder? Devita818 2008 - 2012 Ninja 250R Tech Talk 10 May 10th, 2015 07:46 PM
Retrofit: Radial Master Cylinder ds650rida 1986 - 2007 Ninja 250R Tech Talk 10 October 1st, 2014 12:01 PM
Radial caliper and Master Cylinder Installed psych0hans 2008 - 2012 Ninja 250R Tech Talk 5 September 29th, 2014 01:46 PM
Which Master Cylinder should i get? krolinked 2008 - 2012 Ninja 250R Tech Talk 7 January 12th, 2013 01:01 PM
[motorcycle.com] - Brembo updates radial master cylinder Ninjette Newsbot Motorcycling News 0 July 25th, 2008 09:21 AM
