April 18th, 2010, 01:39 AM | #1 |
{HELP} Clutch Slipping
Hey, I realize that recently, my engine speed doesnt match my clutch speed sometimes, it only has 9600kms on it, so i dont think the plates are worn out right? Perhaps someone can gives me a heads-up?
Takes me a good ~3sec to hit 20km p/h (2009 kawasaki ninja 250r) |
April 18th, 2010, 02:08 AM | #2 |
is your clutch lever adjusted so it has at least some free play?
April 18th, 2010, 02:40 AM | #3 |
Umm, im not quite sure about adjusting the other end, but the lever side has 2-3mm of freeplay
April 18th, 2010, 06:03 AM | #4 |
Join Date: Feb 2010 Motorcycle(s): '94 Vulcan 1500, '06 Katana 600, '08 FZ1 Posts: 133
Have you been using only motorcycle approved oil?
April 18th, 2010, 06:39 AM | #5 |
the previous owner said he did back at 6000km
April 18th, 2010, 07:28 AM | #6 |
3600 KM later, since you are in Australia, you might be on the "severe service" schedule, try changing your oil to a premium synthetec motorcycle oil like Motul 7100 or any oil that is JASO-MA approved, like the Systhetic Shell Rotella-T6
April 19th, 2010, 12:41 AM | #7 |
according to my handbook, my next service is at 12000km... hmm thanks for oil tip
April 19th, 2010, 04:11 AM | #8 | |
it recommends oil change at 1k 12k 24k 36k or every year, whichever comes first. also there is a number sign.. and i quote "#: Service more frequently when operating in severe conditions; dusty, wet, muddy, high speed or frequent starting/stopping." So, like I said, if you live in Australia, you have to change it more often, as the average temperature is higher and the oil breaks down faster. |
April 20th, 2010, 04:06 AM | #9 | |
Thanks! If all goes well, then +1 for you my good man |
April 20th, 2010, 04:12 AM | #10 |
April 20th, 2010, 04:20 AM | #11 |
April 20th, 2010, 04:52 AM | #12 |
okay... just checking to see if the issue were a bad CDI like others have been having, but it does not sound like it from your description.
The classic check for a slipping clutch is to put the bike in the highest gear (6th) and open up the throttle quickly. If the engine rpm increases, but speed does not proportionately, the clutch is slipping. If it is indeed the oil that is causing the clutch to slip, your bike would be the first that I've heard that is doing so from oil contamination. Are you sure the previous owner didn't abuse the clutch and simply wore it out? when you change the oil, pass the collected oil through a cloth filter and see if you can find evidence of clutch plate pieces in the used oil. |
April 20th, 2010, 05:53 AM | #13 | |
oic, mmm it doesn't have to be in gear 6, I can actually feel it in gear 1, I'm thinking of bringing it to my authorised dealer, should I check my clutch plates / change my oil before I bring it to him? Btw, what's CDI? |
April 20th, 2010, 08:08 AM | #14 |
Join Date: Mar 2010 Motorcycle(s): 2007 Zx10R 2009 250R Posts: 134
If you going to do an oil change anyways, might as well do the clutch yourself. Since it shares the same oil and the rest of the engine, it would be a waste to change oil and then decide to change the clutch. I've done a clutch and it isn't too difficult to do. Just make sure you get all the parts needed. If you need some pointers let me know.
http://www.cheapcycleparts.com/model...semblies/25735 Wow.. I couldn't find anyone that made a set. You might just have to order the parts individually. When I did mine, I didn't replace the steel plates, I just replaced the organic ones and kept the discs in the same order. Worked out pretty good for me.
2007 Kawasaki ZX10R Red 2009 Kawasaki EX250R Special Edition |
April 20th, 2010, 01:53 PM | #15 | |
CDI= capacitive discharge ignition. |
April 21st, 2010, 01:43 AM | #16 |
April 21st, 2010, 01:53 AM | #17 |
um... call them and ask.
April 21st, 2010, 03:32 AM | #18 |
lol, any chance you would happen to know their number... having a hard time trying to find it, or should i call my authorised dealer :O
April 21st, 2010, 06:20 AM | #19 |
Join Date: Dec 2008 Motorcycle(s): 2008 250r (Fastest Color) Posts: 914
Im pretty sure Kelly means call your dealer...and I know you both live in the pacific but I'm pretty sure you guys dont use the same dealer haha
Pictures of my ninjette plus... |
April 21st, 2010, 06:20 AM | #20 |
Join Date: Aug 2009 Motorcycle(s): 2008 Ninja 250 (Blue!) Posts: 488
Your dealer should be able to help you with any potential warranty issues.
Posted via Mobile Device |
April 21st, 2010, 05:42 PM | #21 |
Hahaha, true that !
Thanks guys, I'll give them a call later today |
Clutch slipping... how to fix? | walty87 | 2008 - 2012 Ninja 250R Tech Talk | 35 | September 10th, 2022 06:33 AM |
How to tell if your clutch is slipping? | Hero Danny | 2008 - 2012 Ninja 250R Tech Talk | 29 | July 29th, 2014 09:13 AM |
Slipping clutch | The_big_dill | 1986 - 2007 Ninja 250R Tech Talk | 11 | July 29th, 2013 05:43 PM |
Clutch slipping? and lube? :D | kyle98927 | 2008 - 2012 Ninja 250R Tech Talk | 7 | October 20th, 2009 09:32 AM |
back tire slipping/clutch slipping???? help? | richierich781 | 2008 - 2012 Ninja 250R Tech Talk | 17 | June 19th, 2009 07:13 AM |
