September 21st, 2010, 10:25 AM | #1 |
New tank and Removing Cali Emissions
Hello guys! This is my first post I just bought a 1990 EX250 that has cali emissions on it. The tank was severly damaged so I got a new one not thinking and it only has one outlet on it instead of three. So my queastion is, where or what hoses do I need and dont need as I have removed the box and cylinder already. Any advice would be awesome! I really want to get riding it instead of looking at it sitting in my garage! LOL
September 21st, 2010, 11:08 AM | #2 |
does this help?
http://www.ninjette.org/forums/showthread.php?t=55567 |
September 21st, 2010, 11:23 AM | #3 |
This thread may help you as well as it shows what needs to be removed and what to plug.
http://www.ninjette.org/forums/showthread.php?t=22296 |
September 21st, 2010, 11:33 AM | #4 |
Does there happen to be a diagram like the one with the black box and cylinder but without it so I know how a regular fuel system looks? I just know with the new tank I dont have a place for the 2 extra hoses on it. so how do I bypass the black box and cylinder?
September 21st, 2010, 11:35 AM | #5 |
^^^ follow the directions in the thread I posted. It tells you which line to plug.
September 21st, 2010, 11:45 AM | #6 |
I think I get it now, Thanks for the help!
September 21st, 2010, 11:48 AM | #7 |
September 21st, 2010, 11:53 AM | #8 |
No prob Jen, anytime.
September 21st, 2010, 02:27 PM | #9 |
Ready for my new issue? So I took the carbs off and rebuilt them, the problem is the guy who owned it before me didnt have all the hoses connected and there is a place for a hose between the two carbs that I have no Idea what it goes to. So, I included a pic
IMG_20100921_125146.jpg IMG_20100921_125055.jpg IMG_20100921_125138.jpg |
September 21st, 2010, 03:55 PM | #10 |
connects to nothing... that's a vent hose.
September 24th, 2010, 04:41 PM | #11 |
Ok, got the carbs on, floats are great, needle and seats are great, but now I cant get it to idle. Mind you I took off the emissions crap. I plugged the hole on the side of the airbox. When I give it gas it dies. Like its getting too much air. Are these bike notorious for bad parts like carbs or anything? I did ride it down the street last night and was able to get it to 3rd gear, but if I tried to open it up it would pop and try to die. Any suggestions would be fantasic! Thanks!
Oh ya, and the choke has to be completely on. |
September 24th, 2010, 04:43 PM | #12 |
are you sure you didn't pinch or tear the diaphragms when you reassembled the slides?
September 24th, 2010, 04:46 PM | #13 |
yes i was extremly careful.
September 24th, 2010, 04:51 PM | #14 |
there was a clip missing off one of the slides that i replaced but that shouldnt make it not run?
September 24th, 2010, 04:52 PM | #15 |
Jen,
some background, please? was the bike running well before you started work on it or did you get it not running? anything else you can tell us about the history of the bike will certainly help. |
September 24th, 2010, 04:53 PM | #16 |
September 24th, 2010, 04:55 PM | #17 |
yes, I got one from the local dealer
September 24th, 2010, 04:58 PM | #18 |
i lied, he said he found an "E" clip lying in it. So he put it in the top one? slide? he was vague
September 24th, 2010, 05:07 PM | #19 |
I wish I could post a video so you guys could see and hear what I'm talking about.
September 24th, 2010, 05:21 PM | #20 |
stock needles don't have E clips. has your bike been rejetted with an aftermarket jet kit?
like I said... some bike history would do well in cutting down the number of questions we need to ask to help you. |
September 24th, 2010, 06:01 PM | #21 |
bahaha! so I took it to the gas station to put more fuel in it, and not realizing that my fairings were not on the gas spewed out the screw hole on the tank. could this have been part of it?
I bought the bike a few weeks ago, the guy I got it from didnt know much about it, but for $600 I wasn't going to complain. I got it home, took all the fairings and tank off due to cracks to repair. I hauled it to my dads house to have the carbs rebuilt which I got kits from the dealer for. Cleaned out the airbox which had sand in it, removed the cali emissions stuff, put the new tank on and replaced everything but the fairings. |
September 24th, 2010, 08:11 PM | #22 |
did you ride it home? if so, how was the bike running? if not... egads.
September 24th, 2010, 09:01 PM | #23 |
Test drove it about 5 miles and it was fine, lol and then I trucked it home
Please tell me that the screw holes on the tanks that attach the fairing are drilled all the way through. If not then I have more issues than I thought lol |
September 24th, 2010, 09:10 PM | #24 |
no. it's a common problem when owners use the wrong length screws when they reinstall the fairings. you will need to patch the holes if they are leaking fuel. try not ride the bike until you fix it. spilling gas is a REAL danger around a hot engine.
I would suggest taking it to a welder in your area that has done tank repair before. |
September 24th, 2010, 09:14 PM | #25 |
Nice, I bought the tank from a guy on ebay. I Boo him! I will take it to the local guy and have it fixed. I'm starting to think that I need to give up on this bike and get one that is needing less repair. lol
September 24th, 2010, 09:20 PM | #26 |
to be clear... the gas is leaking from puncture holes in the sides of the tank... is that correct?
September 24th, 2010, 09:44 PM | #27 |
yes, the upper fairing screw holes
September 24th, 2010, 11:19 PM | #28 |
September 25th, 2010, 11:20 AM | #29 |
I just sent the seller an email. So fingers crossed. Also I was told it sounds like i have a vacuum leak? I plugged the hole on the side of the airbox and i cant find anything else that would maybe be letting too much air into the carb.
September 25th, 2010, 11:28 AM | #30 |
Do you think maybe a head gasket or valve adjustment? Or bad valves? Im at a complete loss. lol I guess i could take it to the dealer, but Im sure it would cost me more than to just get a new one.
September 25th, 2010, 11:38 AM | #31 |
did you let the bike warm up at least a few minutes before riding it? These bikes take a lot of time to warm up properly.
vacuum leaks (which makes the bike run lean) can occur anywhere before the air/fuel mixture enters the engine cylinder. make sure all clamps for the carbs are tight and that the hoses are connected correctly and have no holes or tears. if the bike will only run with the choke, it sounds like the carbs need to be cleaned again. The pilot jets sound like they are clogged. |
September 25th, 2010, 11:39 AM | #32 |
the fact that you rode the bike prior to purchase and was running good (correct?) says that it's something you did since purchasing it.
September 25th, 2010, 11:43 AM | #33 |
September 25th, 2010, 11:57 AM | #34 |
September 25th, 2010, 12:25 PM | #35 |
Changing Spark plugs w/o removing gas tank? | ScorpionNinja | 2008 - 2012 Ninja 250R Tech Talk | 6 | March 9th, 2016 09:12 PM |
Cali model emissions stuff.. | inbox526 | 2008 - 2012 Ninja 250R Tech Talk | 26 | September 13th, 2014 12:59 PM |
Removing Mirror Bracket (with removing all the fairings) | killermase | 2008 - 2012 Ninja 250R Tech Talk | 11 | May 21st, 2012 11:16 PM |
Cali bike / 49 state replacement tank / hose routing help | djliquid | 1986 - 2007 Ninja 250R Tech Talk | 7 | December 14th, 2011 09:33 AM |
removing gas tank - petcock question | james250ninja | 2008 - 2012 Ninja 250R Tech Talk | 5 | August 25th, 2011 11:23 AM |
