Old March 17th, 2012, 06:49 PM   #201
gt_turbo
gt_turbo's Avatar
Motorcycle(s): '09 250R, '13 CBR500R
so i measured my valve clearance and 3 of the exhaust valves are out of spec. the last exhaust valve is on the bottom end of the tolerance. all the intake valves are right in the middle of the spec. so all i have to do is remove the exhaust cam gear and cam shaft to work on the exhaust shims correct? the intake side doesn't need to be touched in my case?
gt_turbo is offline   Reply With Quote
Old March 17th, 2012, 06:53 PM   #202
quanttrom
Motorcycle(s): 250r
sounds good to me !
Make sure your timing(timing marks all align) is good when you are done and everything should be perfect !
quanttrom is offline   Reply With Quote
Old March 17th, 2012, 09:59 PM   #203
headshrink
headshrink's Avatar
Originally Posted by quanttrom View Post
When you are facing the engine from the timing chain side it rotates clockwise.
So basically the SM does tell us to rotate opposite (clockwise from alternator- [L] side) when adjusting for TDC.
Old March 18th, 2012, 06:08 PM   #204
gt_turbo
gt_turbo's Avatar
valve job #1 completed successfully! i am relieved my bike works again after that! what a job it was.
mental notes for next time:
1. do not drop feeler gauge into chain gap. thank goodness those things are magnetic.
2. mark chain and cam gear before taking off chain tensioner and cam covers. some how my chain/cam gear jumped a tooth after removing all that. thank goodness for the SM i had to re-time everything.
some tips for others:
1. if you have shogun sliders the right side bar needs to come off to make it easier to work.
2. if you took out your air box, re-installing the chain tensioner is super easy - just turn the tensioner in all the way and you can easily hold the screw driver and tensioner in place while you tighten the nuts.
other than those slight mishaps, everything went pretty smooth. i test rode my 250 and it feels smoother to me. major props to casey for making this video, it was very helpful alongside the SM.
Old March 18th, 2012, 08:23 PM   #205
quanttrom
Motorcycle(s): 250r
did you sync your carbs?
Old March 19th, 2012, 04:42 AM   #206
gt_turbo
gt_turbo's Avatar
not yet. i will eventually when i get around to building a manometer or vex's bottle method.
Old March 19th, 2012, 05:37 PM   #207
edxmon
edxmon's Avatar
Motorcycle(s): '08 Ninja 250R (SOLD - 2/16/2013)
Does the creator of the thread still offer his services to do valve jobs? I just bought a '08 with 10k miles and I don't want to assume the previous and 1st owner of the bike did them and be wrong (he no longer lives in the US, a sibling sold me his bike). I consider myself mechanically inclined but I'm somewhat intimidated by doing this on this machine that is completely new to me.
I will send "KC" a pm, and ask if his services are still available.
edxmon is offline   Reply With Quote
Old March 19th, 2012, 05:45 PM   #208
Might wanna point out the cheaper shim refill options I mentioned here as I don't think he knows about 'em. He has done more valve jobs since doing mine in the video and we were actually out of one of the sizes we needed! We ground one down but somewhere in this thread he said he wouldn't be doing that anymore.
FYI, Banning isn't terribly close to San Diego. I arranged to stay the night but that might not be an option for you. Expect to dedicate a whole day to the trip there, job, and trip back.
Old March 19th, 2012, 06:00 PM   #209
edxmon
edxmon's Avatar
If he's willing to do the job, I'm willing to make the trip, assuming I don't have to relocate for my internship this summer. I already drive 100mi roundtrip to work, 100mi one way spread over two days should be ok, with a few pit stops :P
I would just like peace of mind knowing that this is being done right and by a person of trust, not to mention avoiding getting robbed by the dealer or a shady garage.
I sent him a PM, and hope to hear from him soon. Is there any member in closer vicinity to SD that does this service?
Old August 1st, 2012, 07:28 PM   #210
MikeJames21
MikeJames21's Avatar
Motorcycle(s): 08 Ninja 250r, passion red
so when i hit 7300 miles i realized that 7500 miles is when you should do this. i am now at 8500 and i'm starting to hear a rattle noise, so i've been basically trying to put it off until oct/nov sometime when i stop riding. i am in the middle of this 2nd video now, stopping it after every step/good bit of info and typing it into a wordpad document. lol. i usually watch diy videos and then just go and complete the task but this is a bit more involved, sort of so i am keeping notes and step by step instructions. i don't know when i will tackle this, maybe in 12 days when i am on a week vacation from work. wish me luck guys...
My 2Fiddy updated 6-12-12
MikeJames21 is offline   Reply With Quote
Old August 1st, 2012, 07:28 PM   #211
MikeJames21
oh yeah, thanks for the videos!!!!!!!!!!!!!!!!!
Old August 4th, 2012, 01:21 PM   #212
headshrink
headshrink's Avatar
My money is on your cam chain tensioner, which is normal. If it bothers you get a manually adjusted one. It could also be slide-slap.... also normal. I seriously doubt it is related to your valves though.
Old August 4th, 2012, 06:59 PM   #213
MikeJames21
should i still try to do valve adjustment? which is needed at 7500 miles?
Old August 4th, 2012, 07:00 PM   #214
headshrink
headshrink's Avatar
Sure. If you're up for it.
Old October 14th, 2012, 12:28 PM   #215
har0ld
Motorcycle(s): 08 ninja 250r
My girlfriend has an 08 250r and is in need of a valve check/adjustment. I see that the videos no longer work. I was wondering if the videos are uploaded somewhere else where I can watch them? Thanks in advance!
har0ld is offline   Reply With Quote
Old October 14th, 2012, 01:12 PM   #216
Damn. I know Casey's YouTube channel is still running.
Old October 14th, 2012, 01:23 PM   #217
cuong-nutz
cuong-nutz's Avatar
Unless someone saved them, I don't think so. There might be others out there or you could read the pictorial in the DIY.
HalfFast Racing Team
Old October 14th, 2012, 04:03 PM   #218
headshrink
headshrink's Avatar
He still around?
Old October 14th, 2012, 04:05 PM   #219
i heard he did a wheelie off of a mountain
Old October 14th, 2012, 07:02 PM   #220
headshrink
headshrink's Avatar
Joking...?
Old October 14th, 2012, 07:43 PM   #221
He still around?
We PMed several days ago, so: yeah. He mentioned his YT channel, but now I have no link to it.
Old October 16th, 2012, 12:07 AM   #222
har0ld
Thanks for your help guys. I guess I'll just read the pictorials and take my time, but hopefully those videos can be retrieved.
Old October 16th, 2012, 09:08 AM   #223
cuong-nutz
cuong-nutz's Avatar
If you get stumped on a step, just ask. A few of us are pros at doing them by now
Old October 16th, 2012, 11:17 AM   #224
its really not hard at all. don't force anything. use proper torque specs on the cam cage bolts. don't be lazy about removing things to give yourself better access. don't use open end wrenches. (don't strip anything.) remember to set it to TDC before you take the cams out or release the CCT. remember to reset the CCT when reinstalling it or you'll mess up your cam chain. i like to lube my feeler gauge tip with some oil before measuring. sometimes it wont fit in right and it seems like its measuring larger unless its oiled up first. make sure you write down your measurements. don't be lazy and try to do it in your head, its easy to make a small mistake and then you have to take the cam cage out again.
always double check your measurements before and after you make a change to shim size. triple check all of the measurements when you think you are done and are ready to put it back together. better to catch a mistake now than have to take it all back apart again or have that thought in the back of your mind or something.
Old February 28th, 2013, 10:56 PM   #225
lilyanx217
Motorcycle(s): Kawasaki Ninja 250R 2008 White
Which gasket sealant should I use? Mine keeps leaking oil even though I applied a coat of gasket sealant around the gasket and engine
lilyanx217 is offline   Reply With Quote
Old March 1st, 2013, 12:17 AM   #226
What kind of gasket maker did you use? Did you scrape off the old stuff first?
Old March 1st, 2013, 09:52 AM   #227
lilyanx217
I used the valve cover gasket, scraped off the old gasket sealant. And applied a coat of the gasket sealant on the engine and the new gasket.
This is the gasket sealant I used: http://performanceparts.com/part/Edelbrock/9300
Old March 1st, 2013, 10:03 AM   #228
the gasket might be old and cracked. maybe its not properly aligned, its easy for it to slide just a mm out of alignment which causes those little edges to get pinched and it leaks a little oil slowly. if its got a good amount of miles maybe just order a new gasket and replace it
Old March 1st, 2013, 10:28 AM   #229
Hmm. Other than Alex's hunch all I can wonder about is the temperature. Kawasaki specifically said to use a high temperature gasket maker. While that one doesn't say anything about being useful for particularly high temps, the applications do sound... applicable, and I would expect temps to be similar.
Old March 1st, 2013, 10:50 AM   #230
cuong-nutz
cuong-nutz's Avatar
Could just use a tube of Moto Seal by Permatex. Not sure how different it is from their regular automotive sealers.
Old March 9th, 2013, 02:13 AM   #231
DryUrEyesM8
Motorcycle(s): 2009 Kawasaki Ninja 250r SE
I think I'm overdue. Any chances someone will repost those vids?
DryUrEyesM8 is offline   Reply With Quote
Old March 9th, 2013, 05:21 AM   #232
Graugaard
Graugaard's Avatar
Motorcycle(s): Ninja 250r
your enigne should easly could do 15000 miles without a valve adjust... sersly... 7500 is very early O.o.
Graugaard is offline   Reply With Quote
Old March 9th, 2013, 12:00 PM   #233
lilyanx217
Not really. I adjusted my valves at 7.5k and if I remember 2-3 of them were too tight. Before I adjusted it, everytime I ride on the freeway at about 80mph at 9k RPM, when I get off the freeway, I feel the side of the fairings with my knees and it's hot. I rather be safe and adjust it ever 7.5k miles. After I adjusted it, everything was fine.
Old March 12th, 2013, 12:15 AM   #234
DryUrEyesM8
Yeah I think I will adjust them. I'm already past taking the tank off since I was doing work to it already. It's also a little cold to start riding yet so no reason not to.
Blog
Old July 22nd, 2014, 07:53 AM   #235
Hero Danny
Inline 4!!!
Hero Danny's Avatar
Nevermind, It stinks the video is gone!!
Be careful. Remember you are
invisible
Old July 23rd, 2014, 01:36 PM   #236
sjc88
Its not too bad Danny. Just adjusted mine for the first time, not as hard as I originally thought, just time consuming. Follow Vex's DIY and ask questions if your stuck.
sjc88 is offline   Reply With Quote
Old July 25th, 2014, 06:14 PM   #237
Hero Danny
Inline 4!!!
Hero Danny's Avatar
I bought a owner's manual (ran me $25) and I printed out Vex's guides for checking the lash and adjusting them. I ordered some feeler gauges and some iridium plugs (mine as well change them since they've probably never been done) I'll plan to do it in a few weeks with my father (he used to work on valves all the time)..
invisible
Old September 29th, 2015, 05:20 PM   #238
Guilty
Motorcycle(s): 2008 Ninja 250r, 2009 Yamaha C3
As the video that was posted has been removed some time ago, is there anywhere in the internet that shows this? I can only find some for 07 and earlier. Does it exist anywhere where I am not looking?
Guilty is offline   Reply With Quote
Old October 1st, 2015, 07:59 AM   #239
bob706
bob706's Avatar
I have looked everywhere and cant find anything. there is a member who said he saved it and I pm'd him but no response
http://sandollarmotorcycleclub.com/
Old February 15th, 2016, 12:43 PM   #240
peperino
Motorcycle(s): 250R
Hey guys, I hope you can help me. I couldn't measure the right cylinder.
I rotate the engine until the camshafts were aligned in the flywheel with the 2T mark and in the camshaft gears the two lines were even, like
https://goo.gl/photos/E2qgyuFsYw5N95tK6
https://goo.gl/photos/Mpv5q5zEjqsjTM2N7
With this position, I couldn't fit almost any feeler gauge, I tried 0.15 and 0.10 but they won't go in. What I'm doing wrong here?
Then, I measured left cylinder, by aligning 1T mark with the lobes pointing away from the bucket like this
https://goo.gl/photos/royJ7vcphG6ZSbjQ6
This gave me a reading, but weird one, as folows:
Intake1: 0.21mm
Intake2: 0.22mm
Exhaust1: 0.20mm
Exhaust2: 0.20mm
Are my intakes close to the upper limit and my exhausts way off the lower limit?
Help!
peperino is offline   Reply With Quote
Valve Adjustment Video? MisterLu 2008 - 2012 Ninja 250R Tech Talk 17 August 19th, 2014 12:54 PM
Valve Adjustment quarterliter 1986 - 2007 Ninja 250R Tech Talk 7 June 25th, 2013 05:32 PM
1st Time Valve Adjustment Guidance Needed (video) az3200 1986 - 2007 Ninja 250R Tech Talk 33 May 21st, 2013 06:31 AM
Valve Adjustment to Come Soon! gilmorec61 2008 - 2012 Ninja 250R Tech Talk 54 June 22nd, 2012 03:43 PM
Valve Adjustment-Really Tight adjustment screw? mikesova 1986 - 2007 Ninja 250R Tech Talk 5 May 2nd, 2010 04:57 AM
