August 27th, 2016, 01:05 PM | #1 |
Join Date: Aug 2016 Motorcycle(s): 2009 Ninja 250r Posts: 5
Won't accelerate
Hey guys,
My bike is having some issues. So I haven't rode it in a year, had my ex work on it and finally got it running(meaning the bike would turn over and stay at 1 rpm). However now, it's fine starting half of the time but when riding it it won't go past 4k rpm. There's no speed. So there's something going on with the acceleration. I'm really not all that tech savy but any ideas what the issue could be? -Thanks! |
August 27th, 2016, 01:22 PM | #2 |
CCS Amateur #501
Join Date: Jun 2015 Motorcycle(s): '09 250 SE 'Booger' Posts: 406
If its year old gas - drain the tank (and float bowls if you feel adventurous) and put in fresh gallon of gas. Dont bother filling it up until u get it running well 'cause u may need to pull the tank off soon.
August 27th, 2016, 01:56 PM | #3 |
Join Date: Aug 2016 Motorcycle(s): R6, SV 650, 300, 250, 250 xc-w Posts: 73
I would drain the old gas and start it up until it uses the rest of the old gas. Then, spray aerosol carb cleaner into the tank (at least half the can) and start it up again. Rev the engine to induce the carb cleaner into different jets. Let it set over night. Add a gallon of fresh gas and see how it does. I've had to do this a few times myself.
August 27th, 2016, 04:38 PM | #4 |
The Mechanical Noob
Join Date: Aug 2016 Motorcycle(s): 2008 Ninja 250R Posts: 66
It sounds like you may have some carb work heading your way. Similar problem with my snowmobile. It would idle, but when under throttle the carbs choked out and it would die. Some people may 100% disagree with me, but I'd honestly poor a ton of sea foam down it (don't bother adding extra gas. Run it till you feel the carbs are filled and let it sit over night.
Then try again and see if it will allow higher RPMs. If it does help your carbs are dirty and should be cleaned and if it doesn't help your carbs are dirty and should be cleaned XD |
August 28th, 2016, 06:30 AM | #5 |
Bad gas and/or gummed up carbs are the most likely culprits.
Note that carbs are precision devices with a lot of small parts and passages. It's very easy for a DIYer to not get them fully clean, even after multiple attempts. Check out ducatiman's Custom Carb Service if you don't mind paying a few bucks to have it done properly the first time.
August 28th, 2016, 09:32 AM | #6 |
Join Date: Dec 2015 Motorcycle(s): 2008 Ninja 250 Posts: 210
^^ this. My buddy couldn't figure out why after he "cleaned" his carbs his bike still had the same problem. Compressed air, a cleaning solution, and the right hand tools are the minimum needed to do it right.
I personally have never used ducatiman's services but I have seen pictures and read reviews, he is very good at what he does. |
August 28th, 2016, 10:47 AM | #7 |
Humbled, compelled to thank you both for comments.
Modern equipment, some service and restoration efforts, coupled with all consumable parts being replaced, basically "resets the clock" on your carbs. I concur with Mr Wolfe...Op's first move is to purge/replace fuel before condemning the carbs.
[motogp.com] - Pedrosa: “I could not accelerate hard” | Ninjette Newsbot | Motorcycling News | 0 | October 19th, 2015 05:10 AM |
06 250r stalls and wont accelerate | fastlife | 1986 - 2007 Ninja 250R Tech Talk | 12 | August 30th, 2015 12:06 PM |
[topix.net] - Triumph revenues accelerate by 3pc | Ninjette Newsbot | Motorcycling News | 0 | November 13th, 2010 05:21 AM |
Help. When I accelerate, I get squeak from front | poo poo | 2008 - 2012 Ninja 250R Tech Talk | 4 | November 9th, 2010 03:28 PM |
Can't Accelerate | makeusquirt | 2008 - 2012 Ninja 250R Tech Talk | 15 | September 8th, 2010 09:32 PM |
