Notices
Old March 3rd, 2022, 11:48 AM   #1
Dizzy
Motorcycle(s): 250r
HELP - turn signal problem :(
Little help I ordered turn signals for the bike was supposed to fit but it has 3 wires and original has only 2 thought I'd ask be I started it plug stuff to stuff
Dizzy is offline   Reply With Quote
Old March 3rd, 2022, 12:09 PM   #2
Dizzy
Motorcycle(s): 250r
Dam eBay I think 1 is a ground I contacted the seller to see what his response is should return them but they look ok
Old March 3rd, 2022, 12:29 PM   #3
thedrewski86
thedrewski86's Avatar
You can just ignore the third wire, they're typically for running lights (always on). The turn signals themselves will function fine, no need to return.
Don't think, look!
Old March 3rd, 2022, 12:56 PM   #4
Dizzy
Motorcycle(s): 250r
Yup that's pretty much what I just found out had to drill a hole oh well but still said it fit yeah sure if you make it fit
Old March 3rd, 2022, 10:06 PM   #5
Personally, I would run power line from headlights to turn on running light filament, like Hondas. More visibility. Then connect turn-signal wires like normal.
Old March 4th, 2022, 03:43 AM   #6
shspvr
Motorcycle(s): 07 Kawasaki Ninja 250
I agree on that
shspvr is offline   Reply With Quote
Turn signal problem ChickenRun 2008 - 2012 Ninja 250R Tech Talk 11 June 9th, 2013 05:44 PM
Turn signal problem kawasaki-guy2008 2008 - 2012 Ninja 250R Tech Talk 4 June 4th, 2013 09:07 AM
Turn signal problem PistolPete93 2008 - 2012 Ninja 250R Tech Talk 19 July 17th, 2012 10:54 AM
Turn Signal Problem shawn57187 2008 - 2012 Ninja 250R Tech Talk 3 June 17th, 2011 02:13 PM
Turn signal problem!!! danjaho 2008 - 2012 Ninja 250R Tech Talk 1 March 23rd, 2011 07:25 AM
