Old July 2nd, 2022, 09:11 AM   #1
[webbikeworld.com] - 2022 Triumph Tiger 1200 GT [Specs, Features, Photos]
Click here for full story...
The 2022 Triumph Tiger 1200 GT: Cross Country Touring At its Best
Contents
Triumph recently updated its Tiger 1200 models. Like the smaller Tiger 900 siblings, there will be two model ranges — the Tiger 1200 GT models and the Tiger 1200 Rally models — as part of the 2022 Triumph motorcycle portfolio. The Tiger 1200 GT is available in three variants — the base GT, a mid-level GT Pro, and a range-topping GT Explorer version.
The British manufacturer has made some rather significant updates to its flagship adventure motorcycle for 2022. The bikes are powered by an updated 1,160cc three-cylinder engine that produces 147 hp and 95 lb-ft of torque. The engine includes a new T-plane firing order for better low down tractability and responsiveness and a more engaging mid-range and top-end.
The Tiger 1200 G models feature an all-new chassis and redesigned swingarm lighter than before. Electronically-controlled Showa semi-active hardware handles suspension, allowing riders to adjust damping and electronically set spring preload. The bikes feature a 19-inch front and 18-inch rear wheel setup with Metzeler Tourance tires.
While all three variants have pretty impressive features, the base GT model misses some tech, like lean-sensitive cornering lights, a bidirectional quickshifter, hill hold, cruise control, and heated grips. It also gets only three riding modes — Rain, Road, and Sport — while the GT Pro and GT Explorer offer five — Road, Rain, Sport, Rider-configurable, and Off-Road.
The Tiger 1200 GT Explorer also gets a larger fuel tank (7.92 US gal compared to the GT Pro’s 5.28 US gal unit), a tire pressure monitoring system, and heated rider and pillion seats. It also features a rear-facing radar system that offers a blind spot and lane change warning system.
The 2022 Triumph Tiger 1200 GT starts at $19,100 USD / $22,300 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Triumph Tiger 1200 GT, GT Pro, and GT Explorer in one place.
Model Overview
</p>General Info
  • Price: $19,100 USD / $22,300 CAD
  • Key Features:
    • New 1160cc triple engine, designed to set a new benchmark for engine character
    • All-new lightweight chassis and class-leading equipment
    • More than 25kg lighter than the previous generation
    • 50+ Genuine Triumph Accessories
Main Specs
  • Engine: 1,160cc inline-triple
  • Power: 147 hp
  • Torque: 95 lb-ft
  • Wet Weight: 529 lbs (GT)
  • Seat Height: Adjustable 33.46 inches /34.52 inches
Competitors
2022 Triumph Tiger 1200 GT Specifications
ENGINE
Engine1160cc, Liquid-cooled, 12 valve, DOHC, inline 3-cylinderPower148bhpBore x Stroke3.54″ X 2.38″Compression Ratio13.2:1Fuel SystemMultipoint sequential electronic fuel injection with electronic throttle controlStarterElectricExhaustStainless steel 3 into 1 header system with underslung primary silencer and side mounted secondary silencerDRIVETRAIN
ClutchHydraulic, wet, multi-plate, slip and assistTransmission6-SpeedFinal DriveShaft driveCHASSIS
Suspension FrontShowa 49mm, semi-active damping USD forks. 7.87″ travel.Suspension RearShowa semi-active damping monoshock, with automatic electronic preload adjustment. 7.87″ wheel travel.Brakes FrontBrembo M4.30 Stylema monoblock radial calipers, OC-ABS, twin 320mm floating discs. Magura HC1 span adjustable radial master cylinder with separate reservoir.Brakes RearBrembo single piston caliper, OC-ABS, single 282mm disc. Rear master cylinder with remote reservoir.Tires FrontMetzeler Tourance, 120/70R19 (M/C 60V TL)Tires RearMetzeler Tourance, 150/70R18 (M/C 70V TL)
Fuel Tank Capacity5.28 Us GalColorELECTRICAL
IgnitionSpark PlugsHeadlightLEDTail LightLEDDIMENSIONS
Overall LengthWidth HandlebarsHandlebars 33.42″, Handguards 38.66″Height Without MirrorLow screen 56.53″, high screen 58.93″Wheelbase61.41″Trail4.72″Seat HeightAdjustable 33.46/34.52″Wet Weight529lbsWARRANTY
WarrantyExtension
2022 Triumph Tiger 1200 GT Features
ALL-NEW ENGINE
The unique, lightweight, new 1160cc T-Plane triple engine has been optimized for capability, character and performance.
WEIGHT
The first task was to significantly reduce weight without sacrificing the Tigers’ planted feel and well-earned reputation for comfort.
DESIGN
Each Tiger 1200 has been designed to feel as good on the last mile of your adventure as it did on the first.
CAPABILITY
Exploring the unknown is what adventure riders dream about. The adrenaline of discovery, the rush of riding in new landscapes.
RIDER-FOCUSED TECHNOLOGY
The latest technology has been incorporated seamlessly into the new Tiger line-up to help you ride further, for longer, more safely and in total comfort.
INCREDIBLE STYLE
The Tiger 1200’s rugged good looks, poise and attitude is so much more than the result of an exercise in aesthetics.
2022 Triumph Tiger 1200 GT Photos
2022 Triumph Tiger 1200 GT Videos
2022 Triumph Tiger 1200 Official Promo:
2022 Triumph Tiger 1200 vs BMW R 1250 GS by 1000PS Motorcycle Channel
Links
Triumph Motorcycle Official Websites
Social Media Links
The post 2022 Triumph Tiger 1200 GT [Specs, Features, Photos] appeared first on webBikeWorld.
[webbikeworld.com] - 2022 Triumph Tiger 1200 Rally [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 June 12th, 2022 03:33 AM
[webbikeworld.com] - 2022 Triumph Tiger 850 Sport [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 June 8th, 2022 02:55 AM
[webbikeworld.com] - 2022 Triumph Tiger 900 Rally [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 June 7th, 2022 05:13 PM
[webbikeworld.com] - 2022 Triumph Tiger 900 GT [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 June 7th, 2022 05:00 PM
[webbikeworld.com] - 2022 Triumph Tiger Sport 660 [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 June 7th, 2022 04:42 PM
