Old July 2nd, 2022, 09:47 AM   #1
[webbikeworld.com] - 2022 Triumph Scrambler 1200 XC/XE [Specs, Features, Photos]
Click here for full story...
The 2022 Triumph Scrambler 1200 XC/XE: Hardcore Scrambling
Contents
The Triumph Scrambler 1200 sits towards the very top of the Britsh manufacturer’s ‘Modern Classics’ range and is the bigger sibling to the Street Scrambler in the 2022 Triumph Motorcycles portfolio. The bike is available in two variants — a base Scrambler 1200 XC and a more off-road-focused Scrambler 1200 XE.
Both variants are powered by a 1,200cc, liquid-cooled, parallel-twin engine that produces 89 hp and 81.1 lb-ft of torque. Triumph has mentioned that it has tuned the engine for a strong low- and mid-range, typical of what you’d expect from a scrambler.
The Scrambler 1200 XC and Scrambler 1200 XE also shared similar hardware. The 1200 XC features a fully-adjustable 45mm Showa USD fork and fully-adjustable twin shock absorbers from Ohlins, both offering 200mm of travel. Meanwhile, the 1200 XE gets a thicker 47mm Showa fork and the same Ohlins unit at the rear, with 250mm of travel at either end.
While the Scrambler 1200 XC offers five riding modes (Rain, Road, Off-Road, Sport, and Rider), the Scrambler 1200 XC gets an additional Off-Road Pro mode. Triumph Motorcycles has also equipped the XE with cornering ABS, cornering traction control, and heated grips. Features like regular ABS, traction control, cruise control, and a full-color TFT display are standard on both variants.
The 2022 Triumph Scrambler 1200 starts at $14,445 USD / $15,645 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Triumph Scrambler 1200 XC and Scrambler 1200 XE in one place.
Model Overview
</p>General Info
  • Price: $14,445 USD / $15,645 CAD
  • Key Features:
    • 1,200cc parallel-twin engine, with dedicated tune
    • Optimized cornering ABS and cornering traction control on the XE
    • Up to 6 riding modes
Main Specs
  • Engine: 1,200cc parallel-twin
  • Power: 89 hp
  • Torque: 81.1 lb-ft
  • Dry Weight: 456 lbs (207kg)
  • Seat Height: 34.2 in (870mm)
Competitors
2022 Triumph Scrambler 1200 XC/XE Specifications
ENGINE
Engine1160cc, Liquid-cooled, 12 valve, DOHC, inline 3-cylinderPower148bhpBore x Stroke3.54″ x 2.38″Compression Ratio13.2:1Fuel SystemMultipoint sequential electronic fuel injection with electronic throttle controlStarterElectricExhaustStainless steel 3 into 1 header system with underslung primary silencer and side mounted secondary silencerDRIVETRAIN
ClutchHydraulic, wet, multi-plate, slip and assistTransmission6-SpeedFinal DriveShaft driveCHASSIS
Suspension FrontShowa 49mm, semi-active damping USD forks. 7.87″ travel.Suspension RearShowa semi-active damping monoshock, with automatic electronic preload adjustment. 7.87″ wheel travel.Brakes FrontBrembo M4.30 Stylema monoblock radial calipers, OC-ABS, twin 320mm floating discs. Magura HC1 span adjustable radial master cylinder with separate reservoir.Brakes RearBrembo single piston caliper, OC-ABS, single 282mm disc. Rear master cylinder with remote reservoir.Tires FrontMetzeler Tourance, 120/70R19 (M/C 60V TL)Tires RearMetzeler Tourance, 150/70R18 (M/C 70V TL)
Fuel Tank Capacity5.28 Us GalColorELECTRICAL
IgnitionSpark PlugsHeadlightLEDTail LightLEDDIMENSIONS
Overall LengthWidth HandlebarsHandlebars 33.42″, Handguards 38.66″Height Without MirrorLow screen 56.53″, high screen 58.93″Wheelbase61.41″Trail4.72″Seat HeightAdjustable 33.46/34.52″Wet Weight529lbsWARRANTY
WarrantyExtension
2022 Triumph Scrambler 1200 XC/XE Features
ALL-NEW ENGINE
The unique, lightweight, new 1160cc T-Plane triple engine has been optimized for capability, character and performance.
WEIGHT
The first task was to significantly reduce weight without sacrificing the Tigers’ planted feel and well-earned reputation for comfort.
DESIGN
Each Tiger 1200 has been designed to feel as good on the last mile of your adventure as it did on the first.
CAPABILITY
Exploring the unknown is what adventure riders dream about. The adrenaline of discovery, the rush of riding in new landscapes.
RIDER-FOCUSED TECHNOLOGY
The latest technology has been incorporated seamlessly into the new Tiger line-up to help you ride further, for longer, more safely and in total comfort.
INCREDIBLE STYLE
The Tiger 1200’s rugged good looks, poise and attitude is so much more than the result of an exercise in aesthetics.
2022 Triumph Scrambler 1200 XC/XE Photos
2022 Triumph Scrambler 1200 XC/XE Videos
2021 Triumph Scrambler 1200 XE Review by Chaseontwowheels:
Triumph Scrambler 1200 vs Indian FTR Rally: Which Should You Buy? By MOTOBOB
Links
Triumph Motorcycle Official Websites
Social Media Links
The post 2022 Triumph Scrambler 1200 XC/XE [Specs, Features, Photos] appeared first on webBikeWorld.
[webbikeworld.com] - 2022 Triumph Tiger 1200 GT [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 July 2nd, 2022 09:11 AM
[webbikeworld.com] - 2022 Triumph Street Scrambler [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 June 12th, 2022 04:07 AM
[webbikeworld.com] - 2022 Triumph Tiger 1200 Rally [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 June 12th, 2022 03:33 AM
[webbikeworld.com] - 2022 Triumph Speed Triple 1200 RR [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 June 9th, 2022 01:33 PM
[webbikeworld.com] - 2022 Triumph Speed Triple 1200 RS [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 June 9th, 2022 01:33 PM
