April 20th, 2014, 04:33 AM | #1 |
[RideApart] - News: MV Agusta F3 800 AGO Launched
Tweet
Although it was shown last year, MV Agusta has just announced the final specification and pricing for its F3 800 AGO that will go on sale around the world at the beginning of May. The F3 800 is a race replica limited edition bike (only 300 will be made) and has been created as a tribute to former MV Agusta works rider Giacomo Agostini and15 times World Motorcycle Champion. Agostini will sign every F3 800 AGO tank and the factory will supply each bike with a commemorative certificate signed by Agostini. Essentially the F3 800 AGO is the same as the regular F3 but with some of additional electronics, a unique tri-color paint scheme (red, white and green), weight saving carbon fiber and aluminum parts and forged wheels. There is the regular electronic traction control but for this version of the F3, but MV Agusta says it has taken it to a new level with eight different levels to choose from and the ability to switch the whole thing off if you don’t want to use it. For track use you have what MV Agusta calls Motor & Vehicle Integrated Control System on the F3 800 AGO, which allows the rider to select the ratio between throttle twist and throttle opening. The F3 800 AGO is also equipped with Brembo 4-piston caliper 320mm front discs and a 220mm rear. There’s Bosch ABS 9MP (with Race Mode) and MV Agusta’s RLM system, which prevents the rear wheel from lifting under heavy braking. Carbon fiber has been used on the front and rear fenders and forged rims offering a weight saving, according to MV Agusta, of more than 4.5 lbs over the standard F3. That’s the good news. The bad news these will probably sell out before they even get to the dealer showrooms and with MV Agusta quoting a price of 23,990 Euros that roughly translates to $33,216 with the added caveat from MV Agusta “every country could have a price variation due to local import duties and taxes. MV Agusta F3 800 AGO Technical Specification PERFORMANCE Maximum speed* 269.0 km/h (167.1 mph) FRAME Type ALS Steel tubular trellis Rear swing arm pivot plates material Aluminum alloy FRONT SUSPENSION Type Marzocchi “UPSIDE DOWN” telescopichydraulic fork with rebound-compression damping and spring preload external and separate adjustment Fork dia. 43 mm (1.69 in.) Fork travel 125 mm (4.92 in.) REAR SUSPENSION Type Progressive Sachs, single shock absorber with rebound and compression damping and spring preloadadjustment Single sided swing arm material Aluminum alloy Wheel travel 123 mm (4.84 in.) BRAKES Front brake Double floating disc with Ø 320 mm (Ø 12.6 in.) diameter, with steel braking disc and flange Front brake caliper Brembo radial-type monobloc, with 4 pistons Ø 34 mm (Ø 1.34 in.) Rear brake Single steel disc with Ø 220 mm (Ø 8.66 in.) dia. Rear brake caliper Brembo with 2 pistons – Ø 34 mm (Ø 1.34 in.) ABS System Bosch 9 Plus with Race Mode and RLM (Rear wheel Lift-up Mitigation) WHEELS Front: Material/size Forged aluminum alloy 3.50” x 17” Rear: Material/size Forged aluminum alloy 6.00” x 17” TIRES Front 120/70 – ZR 17 M/C (58 W) Rear 190/55 – ZR 17 M/C (75 W) FAIRING Material Thermoplastic/Carbon fiber ENGINE Type Three cylinder, 4 stroke, 12 valve Timing system “D.O.H.C” Total displacement 798 cm 3 (48.7 cu. in.) Compression ratio 13.3:1 Starting Electric Bore x stroke 79 mm x 54.3 mm (3.1 in. x 2.1 in.) Max. power – rpm. (at the crankshaft) 108.8 kW (148 hp) at 13.000 r.p.m. Max. torque – r.p.m. 88 Nm (8.97 kgm) at 10.600 r.p.m. Cooling system* Cooling with separated liquid and oil radiators Engine management system* Integrated ignition – injection system MVICS (Motor & Vehicle Integrated Control System) with six injectors Engine control unit Eldor EM2.0, throttle body full drive by wire Mikuni, pencil-coil with ion-sensing technology, control of detonation and misfire Torque control with four maps, TractionControl with eight levels of intervention Electronic quick shift MV EAS (Electronically Assisted Shift) Clutch Wet, multi-disc slipper clutch Transmission Cassette style; six speed, constant mesh Primary drive 19/36 Final drive ratio 17/41 ELECTRICAL EQUIPMENT Voltage 12 V Alternator 350 W at 5000 r.p.m. Battery 12 V – 8.6 Ah DIMENSIONS AND WEIGHT Wheelbase 1380 mm (54.33 in.) Overall length 2060 mm (81.01 in.) Overall width 725 mm (28.54 in.) Saddle height 805 mm (31.69 in.) Min. ground clearance 125 mm (4.92 in.) Trail 99 mm (3.89 in.) Dry weight 377lbs Continue Reading: MV Agusta F3 800 Ago Launched>> The post News: MV Agusta F3 800 AGO Launched appeared first on RideApart. Related Stories
Click here for full story...
April 20th, 2014, 04:43 AM | #2 |
Purty.
[sportrider - features] - MV Agusta F3 800 Ago First Look | Ninjette Newsbot | Motorcycling News | 0 | April 20th, 2014 07:00 PM |
[faster and faster] - MV Agusta F3 800 Ago unveiled | Ninjette Newsbot | Motorcycling News | 0 | April 17th, 2014 10:20 PM |
[motorcycle-usa.com] - MV Agusta F3 800 AGO First Look | Ninjette Newsbot | Motorcycling News | 0 | April 17th, 2014 05:00 PM |
[motorcycle.com] - Special Edition MV Agusta F3 800 AGO | Ninjette Newsbot | Motorcycling News | 0 | April 17th, 2014 10:20 AM |
[roadracingworld.com] - MV Agusta Announces F3 800 Ago Limited Edition | Ninjette Newsbot | Motorcycling News | 0 | April 17th, 2014 10:10 AM |
