Old July 1st, 2009, 07:14 PM   #1
jink
Motorcycle(s): 09 ninja 250r
Could someone create a DIY for oil pan removal?
whoever does it will be forever in my debt<333333333333
jink is offline   Reply With Quote
Old July 1st, 2009, 07:30 PM   #2
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
well, normally we do them as we have to do some maintenance - since you have to do this, how about you work on the DIY? we can help answer questions you might have along the way...
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders
Old July 2nd, 2009, 03:57 AM   #3
Snake
Snake's Avatar
I'm not sure if you have a garage and tools. If mot then I would be more than glad to lend you my garage, tools and my mechanical experience.
Old July 2nd, 2009, 04:00 AM   #4
Old July 2nd, 2009, 04:16 AM   #5
Snake
Snake's Avatar
KKim I am following your pay it foward motto.
Old July 2nd, 2009, 10:05 AM   #6
HKr1
IC2(SW)
HKr1's Avatar
Oil pan? The cover for the screen, that has the stripped out drain plug.
Take the 5 bolts out and rap it with a mallet
Old July 2nd, 2009, 05:38 PM   #7
Bsmith
Bsmith's Avatar
Motorcycle(s): '08 Ninja 250 R.I.P.
NOTE he said FIVE bolts then whack it. Four does not count. Don't ask.....
Bsmith is offline   Reply With Quote
Test fitting diy belly pan Zombarian Pictures 1 June 7th, 2014 05:35 PM
Oil Plug/Pan Stripped? Nienu 1986 - 2007 Ninja 250R Tech Talk 11 August 10th, 2013 04:27 PM
DIY: How to create Daytime Running Lights on a 2 wire system CThunder-blue 2008 - 2012 Ninja 250R Farkles 5 March 28th, 2013 08:23 AM
Oil Pan and tires for pregen htdub Ninjettes At Speed 8 May 1st, 2012 09:37 PM
Stripped oil pan jink 2008 - 2012 Ninja 250R Tech Talk 7 June 29th, 2009 08:23 AM
