May 25th, 2011, 02:55 PM | #1 |
Am I too lean?
I have a quick question on jetting. I'm confused because my issue covers a high rpm hesitation when there's small throttle inputs.
here's the scenario. I start from a stop, go WOT in first, then second and decide I'm going fast enough, so I shift to third and give it just enough gas to keep a constant speed. I get a stumble/ some surging (and the engine is turning about 9k) so I upshift again to 4th, and the surging is gone and the engine is at a little under 8k (give or take.) So my question is, since I'm at a small throttle opening should I go with another shim on my needles since it's acting lean at a low throttle opening, or should I move up to 108 mains since the engine is acting lean at a high rpm? for the record, the bike pulls hard all the way to redline, I shimmed with one washer on each needle and got rid of the 3-4k stumble, and i adjusted the idle mix to get the right responce when I blip the throttle. Did I not shim enough or do I need to go up to a bigger main jet? as always, help is appreciated edit I think the title should say "needles or jets" rather than "am I too lean" Last futzed with by choneofakind; May 25th, 2011 at 07:20 PM. |
May 25th, 2011, 03:02 PM | #2 |
MOTM - Mar '13, Jun '14
check your plugs
May 25th, 2011, 04:03 PM | #3 |
didn't we go through this before? I recommended 2 shims, but you decided to go with only one, if I remember correctly.
bottom line, try adding another shim and see if it improves. |
May 25th, 2011, 07:10 PM | #4 |
Yeah we did but 1 felt better at the time. I'll tear it apart and try 2 again I guess
sorry I was mainly confused about whether I should be first trying the needles or the main jets based on my symptoms because I was getting my slight lean spot at high rpm and small throttle openings. |
May 25th, 2011, 07:17 PM | #5 |
when I shimmed a pregen, I used 2 washers and the bike was completely stock. The owner really liked the out come. With your setup, I'd say 2 or maybe even 3 would work. try it and see.
Lean or Rich? | xaple | 2008 - 2012 Ninja 250R Tech Talk | 50 | April 14th, 2013 04:01 PM |
Ever wonder what serious lean angle looks like | rojoracing53 | Videos | 6 | April 4th, 2013 12:06 AM |
How far can I lean? | oroboros | Riding Skills | 55 | June 8th, 2011 02:02 PM |
how to lean? | mr.jake | Riding Skills | 25 | January 15th, 2011 09:35 PM |
Troubles from too lean? | joe250 | 2008 - 2012 Ninja 250R Tech Talk | 6 | November 27th, 2010 02:47 PM |
