November 7th, 2011, 11:38 PM | #1 |
is it my cct?
bike was ticking, did the valves. they were barely out of spec, tight on both sides so i put them back in the middle of spec. bike still ticks at high rpm... is it my cct? did i wait to long from the start of the tick to do the valves? (started ticking about 1000mis ago faint but got worse, first two valve jobs by the dealer measured in spec, its at 16kmi) should i tear it down and check the valves for mushroom heading? should i just try replacing the cct? ugh what if my measuring tools were wrong!
November 8th, 2011, 09:01 AM | #2 |
I'm sure it's fine. ninja 250's have a tendency to have a noisy valvetrain. as long as it isn't INSANELY loud, you said you put them in the middle of spec, I think it should be ok
November 8th, 2011, 09:11 AM | #3 |
9_9 i've ridden so many 250s though... none of them sound so... pingey... with earplug on and wind noise at 75, the tick is louder than my stupid loud yoshi exhaust... maybe i am just paranoid... i will try to find a way to get sound recorced
November 8th, 2011, 09:40 AM | #4 |
That's kinda interesting. Mine was ticking pretty loud with my mgp growler and yesterday I put the stock can on for kicks and the ticking quieted substantially.
http://sandollarmotorcycleclub.com/ |
Where to get a Manual CCT? | Graugaard | 2008 - 2012 Ninja 250R Tech Talk | 17 | August 21st, 2013 11:59 AM |
Detailed instructions on how to reassemble the CCT | indr | 2008 - 2012 Ninja 250R Tech Talk | 8 | April 23rd, 2013 02:37 PM |
WTB: new or used CCT | NinjaBoyEddy | Items Wanted | 8 | January 19th, 2013 07:31 PM |
CCT Removal | menikmati | 2008 - 2012 Ninja 250R Tech Talk | 5 | August 3rd, 2012 01:51 PM |
Resetting CCT while on the bike | Broc | 2008 - 2012 Ninja 250R Tech Talk | 13 | March 8th, 2012 03:07 PM |
