Old July 4th, 2009, 01:17 AM   #1
crystalh
is awesome
crystalh's Avatar
Motorcycle(s): 2009 Ninja 250r SE
Worried about my 2nd oil change...
Did my 2nd oil change on the bike today (1000kms). When I went to go take the filter bolt off, it just wouldn't budge. And I never torqued it overly hard last time because my torque wrench wasn't working. So after that oddity was over, I tried taking the filter cover off of the bolt and that wouldn't come off either! It would slide to the threads and it wasn't going anywhere. After playing with it for a good 20 min of trying to get it off, I decided to take a small piece of wood and knock the bolt out of the cover. Then, while wiping down the filter parts, I noticed that the washer that goes over the spring was warped.
Are these things I should be worried about??
Posted via Mobile Device
crystalh is offline   Reply With Quote
Old July 4th, 2009, 01:26 AM   #2
sounds like you might have over torqued it the last time, possibly? w/o a torque wrench... how would you know?
the spring being warped is unusual as it's a pretty substantial flat washer. dunno what to make of that.
the cover not coming apart... did you lube the o rings with oil before assembly the last time you did the oil change?
Old July 4th, 2009, 02:13 AM   #3
crystalh
is awesome
crystalh's Avatar
Couldn't have over torqued it because last time, I put it on tight, but not so tight where I had to push against my bike to get the leverage needed to get the bolt off.
The drain bolt came off just fine.
and yes, i did lube the o rings. the cover came off the o ring just fine, but then it got stuck about halfway on the bolt before the threads started.
Is it normal for oil to increase a bit in the crankcase after an oil change? cadd 2008 - 2012 Ninja 250R Tech Talk 10 May 15th, 2014 08:38 PM
Synthetic oil at 300 mile oil change? anacron 2013 - 2017 Ninja 300 Tech Talk 14 July 29th, 2013 04:58 PM
Oil drain plug gasket for oil change. tsdexter 2008 - 2012 Ninja 250R Tech Talk 8 July 10th, 2012 01:00 PM
oil change kn250 2008 - 2012 Ninja 250R Tech Talk 1 September 11th, 2010 10:28 AM
change oil filter, without draining oil? peter330 2008 - 2012 Ninja 250R Tech Talk 5 May 30th, 2010 01:08 PM
