April 13th, 2014, 09:05 AM | #1 |
Join Date: Aug 2012 Motorcycle(s): 2010 Ninja 250, 2015 F800R Posts: 90
The puzzling demise of my Oil Drain Plug Socket
Right. I know I'm not that gifted with mechanics, some might even say I have two left Hands. However, seening what happened to my poor Ninjette today I can'treally believe this could be of entirely my own wrongdoing.
A few days ago, during a ride, my engine just cut out right there in the middle of the street, no warning. I pull over, check that I didn't accidentally tap the cutoff, fuel was ok. So I powercycle it and try to start - nothing. The dash lights up but pressing the starter has no effect. I check the oil level - seemed good at the time. Let it sit for a minute, then try starting again, and voila, the bike is running. Everything feels right, maybe the clutch a little vague under the foot but might be the imagination. Today, I do a more thourough check on what might have happened. I saw that when the engine has been running for a short time, the oil level seems to drop rather low, so might as well do an oil change. The first one on this bike, the previous were done by the shop because of the warranty. Loosening the drain screw and the filter cover requires some effort as usual, but finally they're off, I drain the oil and change the filter. Now I put back in the drain plug, but immediately sense something is wrong - there is no "resistance" anymore, the plug just turns around and around. And when I check, I see that in the oil drain bucket there is a large metallic object - turns out this is half of my drain plug socket! The socket must have split - perhaps already earlier (which might explain the suddenly low oil level, but I didn't see any oil spills), perhaps when loosening the plug, or even mybe when putting it back in? (did use a torque wrench, double-checked settings and used on the filter pan previously...) Now I realize I haven't always taken care of the bike, have ridden in winter and with salt on the roads. However, I cannot explain how this might have happened at all. The bike is from 2010, so should be still in decent condition. If i'd had used the torque wrench wrong, I would understand a split thread. But this? I'm stumped, I really am. Naturally I don't want to see the fault with me but this I can't see where I might have f'ed it up... Anyways, it doesn't seem to be the endof the world. The socket assembly looks like it can be detached from the engine and replaced, so that might make an interesting project. And in the meantime, I have a perfect excuse to get that SV650S for my riding needs... |
April 13th, 2014, 09:42 AM | #2 |
Ninjette Jockey
Join Date: Oct 2010 Motorcycle(s): Ninja 250R, Harley Davidson Heritage Softail, 2 Honda Monkeys, Polini & GRC mini GP Posts: A lot.
That part is the oil screen cover. If you have never taken it off, then you have never cleaned the oil screen. The most important time to clean the screen is at the first oil change, but it is not necessary to clean it every oil change.
Just go to the Kawasaki dealer and order an oil screen cover, gasket, new drain plug and lots of plug gaskets. You will be back on the road in a week or so. Castings can have flaws , but if it happens again, it's you.
For what shall it profit a man, if he shall gain the whole world, and lose his own soul?. |
April 13th, 2014, 02:59 PM | #3 |
Fix It Till Ya Break It
Join Date: Oct 2011 Motorcycle(s): 08 250RRrrrr Posts: 623
also it's normal for the oil to show low after turning it off. Let is sit for a few minutes then check the level.
and buy a R6 |
April 13th, 2014, 03:26 PM | #4 |
Cheers for the advice guys, I'll go see for sourcing those parts then.
Usually I just would let a shop take care of things mechanical, but curiously motivated to try and fix this by myself! |
May 10th, 2014, 11:00 AM | #5 |
As for the engine dying for seemingly no reason: a few of us have had that happen. It seems to have something to do with the tank forming a vacuum. It usually happens if you get the bike nice and warm and then let it sit for 15 minutes before getting back on and riding it hard. A few blocks later it'll stumble and die. It can happen even with plenty of fuel in the tank but is more likely to happen when you have 3/4 a tank or less. Other than the 10-15 minute cool-down situation, I've had it happen when riding into a cold front or sudden rain after a long warm up.
Oil leak from drain plug | akh1685 | 1986 - 2007 Ninja 250R Tech Talk | 7 | October 4th, 2013 01:03 PM |
Oil drain plug gasket for oil change. | tsdexter | 2008 - 2012 Ninja 250R Tech Talk | 8 | July 10th, 2012 01:00 PM |
2008 oil drain plug size and specs?? | azimmer11 | 2008 - 2012 Ninja 250R Tech Talk | 4 | March 12th, 2012 09:55 PM |
[webbikeworld.com] - Magnetic Drain Plug and Oil Filter Magnet Review | Ninjette Newsbot | Motorcycling News | 0 | October 9th, 2011 10:10 AM |
2009 model oil drain plug crush washer | littledog | 2008 - 2012 Ninja 250R Tech Talk | 14 | January 14th, 2010 02:57 PM |
