Old February 18th, 2013, 06:34 AM   #1
akcalhoun
Motorcycle(s): 2013 honda shadow phantom
rear tire
about to put on new rear tire and have decided on the bt45s. question tho, would it b ok to put the bt45 on rear while keeping the stock front tire. arent they both bias ply tires, ive heard your not suppossed to mix bias and radial. thx guys
akcalhoun is offline   Reply With Quote
Old February 18th, 2013, 08:26 AM   #2
allanoue
allanoue's Avatar
MOTM - Sep '14
You will be ok, as long as you are running bias ply tires front and back. Many others will disagree and recommend replacing both when replacing the original tires.
more info here:
http://www.ninjette.org/forums/showthread.php?t=20
Last futzed with by allanoue; February 18th, 2013 at 09:29 AM.
Old February 18th, 2013, 09:23 AM   #3
red5
red5's Avatar
Motorcycle(s): 09 ninja 15.256
I ran a new BT45 on the rear with the stock IRC on the front for about 3 weeks. There were no "problems" but you will feel a big improvement once you change the front also.
"We're not always doing business, but we're always open."
"For me, it is far better to grasp the Universe as it really is than to persist in delusion, however satisfying and reassuring." Carl Sagan
red5 is offline   Reply With Quote
Old February 20th, 2013, 06:12 AM   #4
akcalhoun
thx guys
Old February 20th, 2013, 10:04 AM   #5
its fine to have different brand of tires, but you NEED traction on the front, you dont NEED traction on the rear, so if your rear needs replacing, chances are so does your front. so replacing only the rear is probably a really bad idea.
Old February 21st, 2013, 05:05 AM   #6
akcalhoun
i thought that fronts usually got like 2x the milage usually that rears do. my rears r past the wear bars but my front looks almost new. if the tread on the front is still good itd still be ok just to change the rear right?
Old February 21st, 2013, 07:59 AM   #7
Yes.
Old February 21st, 2013, 09:22 AM   #8
just look at them. there are wear indicators and date marks. if the tire has dry rot, or is past its service life, replace it.
Rear Brake Lever Travel is Excessive and Rear Brake won't Lock Tire. N-m 1986 - 2007 Ninja 250R Tech Talk 14 July 17th, 2014 04:13 AM
Rear tire size 2fidyswag 2008 - 2012 Ninja 250R Tech Talk 18 April 18th, 2013 11:42 PM
Should I replace this rear tire? Soujyu 2008 - 2012 Ninja 250R Tech Talk 18 December 23rd, 2011 05:48 PM
need new rear tire?? mhesse 2008 - 2012 Ninja 250R Tech Talk 5 June 30th, 2011 04:46 AM
rear tire james250ninja 1986 - 2007 Ninja 250R Tech Talk 5 October 16th, 2010 12:58 AM
