Old December 29th, 2014, 07:46 AM   #1
Jason5885
Jason5885's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250r FI
Question Difference between these two PC5's ?
http://www.demon-tweeks.co.uk/motorc...er-commander-5
http://www.demon-tweeks.co.uk/motorc...l-and-ignition
The Later states it ' Includes Ignition Adjustment '
What does this mean? what benefit does it have over the former ?
Thanks in advance ninja wizards.
Jason5885 is offline   Reply With Quote
Old December 29th, 2014, 07:49 AM   #2
EsrTek
EsrTek's Avatar
Motorcycle(s): '13 300
I believe that adjusts when your spark 'ignites' the fuel in chamber...not exactly sure.
Either way it's advanced stuff and if your asking what it is, you will not need it (yet).
Old December 30th, 2014, 10:20 AM   #3
Jason5885
Jason5885's Avatar
Thanks. Yeah I'm going to have to agree with you there. I have the Fuel Only version, i was just curious what the extra ~$25 was going towards with the other one.
Old December 31st, 2014, 07:42 AM   #4
HKr1
IC2(SW)
HKr1's Avatar
Thats pretty cool to have the ignition in with the pcV for a couple dollars more. Igntion module for other bikes, cost as much as the pcV.
Old January 1st, 2015, 03:36 PM   #5
Jason5885
Jason5885's Avatar
Man I should have bought it! It was only £10 more
Old January 15th, 2015, 05:53 AM   #6
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Jason, do not annoy yourself for a false purchase because you bought the correct PCV.
To tune the ignition of an engine it requires a very high level of knowledge about engine technology and very expensive test equipment.
An ignition timing WITHOUT knowing the original ignition curve is IMPOSSIBLE.
If you are keen then you can change your ignition fix with a Woodruff key to adjust for a different value, but also that I would not advise you. Although I must confess that I did just that and it's one of my best mods, but my ignition is now advanced up to 46 degrees.
So if you are really stuck and plan to go this route, then also because of his knowledge only Chris would be in question to make all the settings in the ECU directly for you.
Old January 15th, 2015, 08:10 AM   #7
Chicagobob
Chicagobob's Avatar
Motorcycle(s): '06 Ninja 250, 2018 Honda GL1800B
PCV with ignition is useful on many bikes. If you can't tune it yourself or use auto-tune, the downloadable maps make use of it. Works well on my 650r with aftermarket air filter and exhaust.
Chicagobob is offline   Reply With Quote
Old January 16th, 2015, 09:32 AM   #8
Jason5885
Jason5885's Avatar
I believe , on this occasion, this is far to advanced for me guys. But thanks for the info maybe a few years down the line il look into it
Any DIY's on fitting a PC5 to my ninja 250 ? Jason5885 2008 - 2012 Ninja 250R Tech Talk 3 December 2nd, 2014 08:24 AM
Whats the difference? Armo55 2008 - 2012 Ninja 250R Tech Talk 15 January 21st, 2013 07:29 PM
What is the difference loz944 General Motorcycling Discussion 39 January 26th, 2012 04:43 PM
Is there any difference hmm ?? GiGs 2008 - 2012 Ninja 250R Farkles 4 January 6th, 2011 11:34 PM
Whats the difference ? Plasma 2008 - 2012 Ninja 250R Tech Talk 0 September 1st, 2009 03:48 PM
