July 15th, 2010, 02:33 PM | #1 |
Join Date: Jul 2009 Motorcycle(s): Ninja 250r 09 SE Posts: 172
where to buy headlight fuse ?
I know its probably a stupid question, but where do you buy fuse for the headlight ? i want to upgrade to HID and i want a 15amp fuse, but after searching the forums and google, i didn't find much information. Any help would be apreciated.
July 15th, 2010, 02:53 PM | #2 |
how many watts is you HID kit?
any automotive parts store should have the right type fuses. |
July 15th, 2010, 02:54 PM | #3 |
35 watts
http://cgi.ebay.ca/Xenon-HID-Convers...item2a075bdd31 but people were saying fuse was blowing, even with a 35 watts |
July 15th, 2010, 03:01 PM | #4 |
from what I've read, people that were having problems had the 55w kits. if you encounter fuse problems with the 35w kit, try not starting the bike with the highlights on.
I have 35w HIDs and have had no problems with fuses blowing. |
July 15th, 2010, 03:03 PM | #5 |
Thanks kkim
but just in case in the middle of the night the fuse blow for xyz reason, where can i get another ? also, just to be sure, the kit i specified is okay ? |
July 15th, 2010, 03:26 PM | #6 |
carry some spares with you if you are nervous about it. like stated in post #2, automotive parts store should have them.
You takes your chances on Ebay, but from what I see, there should be no reason that kit shouldn't work. |
July 15th, 2010, 06:40 PM | #7 |
Join Date: Nov 2008 Motorcycle(s): Ninja 250R 2009 Posts: A lot.
35W HIDs here and still using the factory 10 amp fuse, even if I start with both lights on!
Headlight fuse - What all is running on it? 2009 | passive101 | 2008 - 2012 Ninja 250R Tech Talk | 5 | July 27th, 2013 03:15 AM |
Headlight out/fuse blown... | tsdexter | 2008 - 2012 Ninja 250R Tech Talk | 4 | June 18th, 2013 12:43 PM |
Headlight fuse keeps blowing | iangee | 2008 - 2012 Ninja 250R Tech Talk | 5 | May 26th, 2012 01:00 AM |
Keep blowing headlight fuse! | Hexdex | 2008 - 2012 Ninja 250R Tech Talk | 8 | October 26th, 2010 07:01 PM |
blown headlight fuse | sombo | 1986 - 2007 Ninja 250R Tech Talk | 15 | July 4th, 2009 11:00 PM |
