Old September 8th, 2011, 06:05 PM   #1
cuz
cuz
cuz's Avatar
Motorcycle(s): 09 ninja 250r
am i doing this wrong ? newbie Q
OK so i want to take my handlebar weights off and started to turn left you know lefty losey right thighy and started chipping the bolt that's were i stopped so is it the other way? or am i just weak? well txs
THE GOOD LIFE
cuz is offline   Reply With Quote
Old September 8th, 2011, 06:24 PM   #2
Live2ride
Live2ride's Avatar
Motorcycle(s): 06 yzf r6r previously: 09 ninja 250r, black 07 zx6r
They put loctite on them from the factory; you will probably need to apply heat to loosen them enough to unscrew. Jw, why are you removing them?
Live2ride is offline   Reply With Quote
Old September 8th, 2011, 06:29 PM   #3
cuz
cuz
cuz's Avatar
oohhh ok thanks well bought the bike used and it has some scratches so im sending her off to paint and the weights too
THE GOOD LIFE
Old September 8th, 2011, 07:20 PM   #4
greatwhiteninja
Ridin Dirty
Motorcycle(s): 2011 white se 250r , 2008 zx6R
they are a pain to get off, usually takes heat or a drill ..loL!
#1
greatwhiteninja is offline   Reply With Quote
Old September 8th, 2011, 07:34 PM   #5
NikkitaNinja
NikkitaNinja's Avatar
Motorcycle(s): 2008 Kawasaki Ninja 250 *Nikkita* - 2003 Buell XB9R
I attempted to get mine off before I had gotten my clipons and had 3 different people from where I work try to undo them but no luck. After having my clipons installed they had taken the bar ends off from the stock bars and noticed the red (permanent) loctite that is lathered on the screws. I should have asked them what they had done to remove them
NikkitaNinja is offline   Reply With Quote
Old September 8th, 2011, 08:02 PM   #6
cuz
cuz
cuz's Avatar
so when they come back from paint should i apply some loctite on the bolt?
THE GOOD LIFE
Old September 8th, 2011, 08:07 PM   #7
NikkitaNinja
Wouldn't be a bad idea, since there's a lot of vibration going through the handle bars constantly, it's likely that they would eventually rattle loose if they aren't secured by loctite or really tightening the screws.
Old September 11th, 2011, 12:28 PM   #8
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
it requires heat and an impact driver to get them off without destroying the bolts
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders
Old September 12th, 2011, 07:49 AM   #9
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
Or a #3 JIS screw driver, a towel, and adjustable pliers.
The www.ModMy250.com guy
Old September 12th, 2011, 08:39 AM   #10
dubojr1
dubojr1's Avatar
+1
What am i doing wrong? jbraz7 1986 - 2007 Ninja 250R Tech Talk 22 April 28th, 2016 05:17 AM
Talk about wrong time, wrong place tlhamon General Motorcycling Discussion 8 February 1st, 2015 12:07 PM
doing it wrong Joshua763 Off-Topic 11 May 24th, 2014 08:29 PM
Can I go wrong with just a CAN? Bushmaster11B 2008 - 2012 Ninja 250R Tech Talk 24 September 2nd, 2011 10:29 AM
Is this what I'm doing wrong? toast Riding Skills 18 May 18th, 2010 08:28 PM
