Notices
Old July 27th, 2018, 08:35 AM   #1
presto chang-o
Motorcycle(s): 93 Ninja 250
Maintenance After 2,000 miles since '01
I've got a 93 Ninja that's gonna roll 12,000 miles this afternoon. I got it 2 years ago and sat until last month. (I've learned don't take on a project unless you can store it where you live). I was wondering what all maintenance you guys would recommend. I've rebuilt and cleaned the carbs, new plugs, new oil and filter, new fuel filter, new tires this weekend, within the month I'm doing a chain and a 15/42 sprocket combo. This winter i'm gonna adjust the valves and change all the fluids and everything. Is there anything immediate I'm missing? It runs great after the carb clean. I've put around 600 miles on it with no issues. Love the bike, excited for new tires so I'm not terrified cornering with any speed. I'm pretty sure it's got the original rubber on it
presto chang-o is offline   Reply With Quote
Old July 27th, 2018, 09:09 AM   #2
Sounds like you have it covered, once you do the fluids, valves, and tires.
I'm guessing you cleaned and oiled the air filter when you had the carbs off. Hopefully you removed the caps on the idle mixture screws when the carbs were off so you can fine-tune it.
I'd also shim the cush drive when the rear wheel is off - https://faq.ninja250.org/wiki/How_to...the_cush_drive
Factory Service schedule for more maintenance ideas - https://faq.ninja250.org/wiki/Service_Schedule
General Ninja mechanical info - https://faq.ninja250.org/wiki/Ninja250_Howto
Old July 29th, 2018, 06:53 PM   #3
presto chang-o
Didn't know about shimming the cush drive. Thanks for the advice. I do notice quite a bit of lash. Glad to know I can get that taken care of.
Old July 31st, 2018, 04:32 PM   #4
Ceeloo Yello
Motorcycle(s): 250
Hopefully you remembered to clean out the oil screen.
Old August 1st, 2018, 06:29 AM   #5
Good idea, and often overlooked.
https://faq.ninja250.org/wiki/Checking_the_oil_screen
Old August 1st, 2018, 08:26 PM   #6
presto chang-o
Thanks for the tips on the oil screen. Had no idea about that. I was reading that a 106 chain should be the correct size for a 15/42 sprocket conversion. Can any of you confirm that?
15,000 mile maintenance/inspection Advincula 2008 - 2012 Ninja 250R Tech Talk 26 June 29th, 2017 09:48 AM
[RoadRUNNER] - KTM 70,000-mile Maintenance in South America Ninjette Newsbot Motorcycling News 0 October 8th, 2014 03:00 AM
I'm at 6k miles, time for maintenance? Sykes92 2008 - 2012 Ninja 250R Tech Talk 5 March 22nd, 2014 11:15 AM
Is 33,000 too many miles? XurXes General Motorcycling Discussion 10 August 25th, 2012 06:58 PM
rear brake problem after 600 miles maintenance tac12345 2008 - 2012 Ninja 250R Tech Talk 3 June 25th, 2010 02:45 PM
