Old July 31st, 2018, 03:53 AM   #1
presto chang-o
Motorcycle(s): 93 Ninja 250
Acting like hydrolocked over night?
The past 2 mornings I've went to go start my bike it'll turn over 2 or 3 times and then stop like its hydrolocked. But then I'll hit the gear shift into first and put it back into neutral. Then it started up fine. Am I getting it stuck between first and neutral and binding something?
It also didn't feel like it actually shifted into first this morning before i shifted back to neutral.
Both mornings once it started I rode it no problems. Staled it and restarted fine. And fired right up after work.
presto chang-o is offline   Reply With Quote
Old July 31st, 2018, 04:49 AM   #2
Could be just a fluke but it has been my experience that when that happens with frequency, the battery is soon to go (failing under load) or you need to clean your start switch. Get out your meter and ohm test your charging system. Things to also test and have a look at;
1. Check oil level and for contaminates
2. Clean your safety switches AND your starter switch
3. Clean your battery terminal connections
4. Check acid level in battery
5. Load test your battery
6. Ensure starter solenoid connection nuts and starter wire
7. Test your starter solenoid
Assuming all that passes, then one can only assume....
These things happen when Mars is close to the earth. https://www.space.com/41323-mars-clo...3-webcast.html
Good luck!
Old July 31st, 2018, 05:58 AM   #3
Also don't forget to monitor phase of moon and planets' alignment! Mars in retrograde can mean serious trouble!!!
Measure your neutral switch. If connection is flakey, it can go into open state with vibration of engine-cranking. Shifting out of and back into neutral may reset it into closed position. As test, disconnect wire connector from neutral switch and connect to ground full-time. Does problem go away?
[visordown.com] - Thinking Big, Acting Small Ninjette Newsbot Motorcycling News 0 March 8th, 2018 03:32 AM
Fuel gauge acting really weird Adaptive 2008 - 2012 Ninja 250R Tech Talk 1 September 14th, 2013 03:45 AM
Shifting mechanism acting weird after highway incident. milk_bear 2008 - 2012 Ninja 250R Tech Talk 3 October 12th, 2012 03:45 PM
Choke acting weird? kevinlo423 2008 - 2012 Ninja 250R Tech Talk 4 July 11th, 2011 11:14 PM
bike acting weird! fenwaynomar45 2008 - 2012 Ninja 250R Tech Talk 3 June 8th, 2010 12:03 AM
