Old June 8th, 2011, 06:21 AM   #1
egb1108
egb1108's Avatar
Motorcycle(s): 2011 Kawasaki Ninja 250r Pearl White/ Ebony SE
breaking it in
I'm just about to hit 200 miles on my 250 that i just purchased at what point is it ok to go over the suggested 4000 rpm and keep it at a constant speed.
egb1108 is offline   Reply With Quote
Old June 8th, 2011, 06:54 AM   #2
kaiserz
There's a limit to s2pdty
kaiserz's Avatar
http://motorcycleinfo.calsci.com/NewBike.html
Ride it like normal, vary the rpm, don't worry too much about the break in period(I got tons of people with tons of motorcycle experience tell me that), just make sure you change the oil, cause you don't want that filthy oil in your baby
DIY oil change: http://www.ninjette.org/forums/showthread.php?t=10780
Old June 8th, 2011, 07:00 AM   #3
TXJ
Cranky Old Fart
TXJ's Avatar
Motorcycle(s): 08 DRZ400SM
There are a lot of threads about this if you search "Break in period" etc.
If you have to commute with it, just ride normally and vary the RPMs. You don't have to follow the book to the "T". Just ride like you normally would, except try to avoid redline. It won't hurt the bike. Plenty of people have done hard and soft break in periods with no problems. Change your oil more frequently (every 200mi I'd say) if it's revving higher for the break in period, 1k miles or what-have-you then switch to a normal interval, you and the bike will be fine.
TXJ is offline   Reply With Quote
Old June 8th, 2011, 07:01 AM   #4
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
Change your oil
Old June 8th, 2011, 11:56 AM   #5
http://www.ninjette.org/wiki/Break-in
Breaking Through Boundaries csmith12 Riding Skills 19 December 29th, 2016 11:29 AM
Breaking the barrier Alex Off-Topic 4 September 26th, 2011 10:30 AM
Breaking in leather s2kenny Motorcycle Gear 1 August 9th, 2010 07:18 PM
Help! I'm breaking out! :( ninjette General Motorcycling Discussion 14 October 25th, 2009 02:47 PM
breaking chain miniguns167 2008 - 2012 Ninja 250R Tech Talk 2 September 27th, 2009 11:50 AM
