December 19th, 2012, 04:45 PM | #1 |
Join Date: Nov 2012 Motorcycle(s): 2009 ninja 250 and a 2009 Vulcan 900 Custom Posts: 8
Turn Signal Issues
Hello,
I have a issue with the turn signals. As of right now I only have the rear signals hooked up and they blink fine and Turn on and off with no issues. When I try and hook up the front blinkers the signal relay makes a weird noise instead of the normal tick and they barley light up and flash. These are not LED bulbs. Any help would be great. |
December 19th, 2012, 04:48 PM | #2 | |
Fast-Guy wannabe
MOTM - Jan '13
are you using oem bulbs? |
December 19th, 2012, 05:03 PM | #3 |
No, I am assuming they are not OEM bulbs since they are flush mount signals. They are 12v23w, what are the OEM specs on the bulbs?
December 19th, 2012, 05:11 PM | #4 |
Fast-Guy wannabe
MOTM - Jan '13
look here sounds the same
http://www.ninjette.org/forums/showthread.php?t=120412 |
December 19th, 2012, 05:17 PM | #5 |
Fast-Guy wannabe
MOTM - Jan '13
Here's the relay i installed, it's nice because it plugs right in with zero wires or mods at all.
http://www.superbrightleds.com/morei...asher/781/835/ Here's the thread about it, look at post #25 to see where it goes http://www.ninjette.org/forums/showthread.php?t=88895 |
December 19th, 2012, 05:40 PM | #6 |
December 19th, 2012, 05:57 PM | #7 | |
Fast-Guy wannabe
MOTM - Jan '13
December 19th, 2012, 08:28 PM | #8 |
problem fixed
New relay worked like a charm... Thanks for all the help.
December 19th, 2012, 08:44 PM | #9 |
Fast-Guy wannabe
MOTM - Jan '13
December 19th, 2012, 09:16 PM | #10 |
I had to go with the Tridon eg22 they did not have the other one in stock. But, the round one worked perfectly and fit into a slot inside of the frame (not on the outside of the frame like the stock relay location) almost like it was made for the round relay.
Looking for 09 oem rear turn signal and front turn signals and tail fairings | mbbernas | Items Wanted | 1 | September 11th, 2013 10:48 AM |
Front turn signal issues... | snowman7 | 1986 - 2007 Ninja 250R Tech Talk | 6 | June 30th, 2013 07:21 AM |
HELP ASAP please! - turn signal issues | SafetyPaws | 2008 - 2012 Ninja 250R Farkles | 31 | June 25th, 2012 07:05 PM |
2009 ninja turn signal issues | schultzy808 | 2008 - 2012 Ninja 250R Tech Talk | 3 | March 28th, 2012 08:06 PM |
Turn Signal Indicator Issues | menikmati | 2008 - 2012 Ninja 250R Tech Talk | 9 | December 12th, 2011 08:17 PM |
