Old February 25th, 2017, 01:09 PM   #1
StuntPuppy
Motorcycle(s): 2010 Ninja 250r SE, 02 CBR600F4i
Turn signal wiring issues
So I have a bit of a unique problem with my turn signals. Searching around hasn't really helped, because most tutorials assume that you still have your dash and stock turn signals. The issue I have is that I removed every fairing, and no longer have a dashboard at all, or any turn signals left. I am trying to wire in LED strip turn signals, only on the rear, no front. It's been so long since I removed the fairings and stock turn signals that I no longer remember what wires go to what, and I have no idea if or how my removal of the dash will affect this.
Basically what I'm looking for is the easiest way to rig up my rear turn signals, and which connectors to wire it in to. I think I wired them into one of my old turn signal connectors for testing, a grey two wire connector in the tail, but, naturally, they did not flash or even turn off, actually, just came on with 12v power and turned off when I turned the key off. I know that I need an electronic flasher relay, but I also need to know if I need to bypass any stock wiring to just make the rear turn signals work, and how.
Have poked around in the wiring diagram but I'm awful at reading them, plus it assumes that I have all the stock wiring hooked up properly. Any help would be greatly appreciated.
I'm heading over to work on it after I make this post, so I can provide pictures if needed.
*Edit* Sorry for the double post.
Last futzed with by StuntPuppy; February 25th, 2017 at 01:36 PM. Reason: Double posted
StuntPuppy is offline   Reply With Quote
Old February 25th, 2017, 01:31 PM   #2
StuntPuppy
Shameless self-bump so that this one is on top instead of the one where I deleted all the relevant text.
Old February 25th, 2017, 03:16 PM   #3
Welcome, Natalie !!!
I would test the remaining wires with a regular directional bulb first, then replace the flasher and install the new indicators.
Old February 25th, 2017, 03:39 PM   #4
StuntPuppy
Thank you for the welcome! After 4 years of owning my 250, maybe its time I joined a community for it XD
I was incorrect about which part I'd wired them up to. Now that I am working on it, I see that I originally wired it to a connector with a red/blue stripe wire and a black/yellow stripe that is near my tail light but not plugged into to anything, for testing.
I figured out where my actual turn signal connectors are, but they don't really seem to be getting any power, at least nothing happened when I wired the LEDs up to it. I made sure I wired it properly, ground to ground, etc.
Do I need to bypass any of the wiring that originally went to my dash (which is no longer present) for it to get power?
Old February 25th, 2017, 04:25 PM   #5
StuntPuppy
Okay so the fuse was blown, explaining why there was no power. Apparently I already had an electronic flasher relay from the previous owner, and there's no need to bypass wiring, because when I wired up the LED turn signal it worked perfectly!
Thanks for the help, motofool
Old February 25th, 2017, 06:25 PM   #6
I did not help much, but I am glad that you figured it out by yourself.
Turn signal wiring issues StuntPuppy 2008 - 2012 Ninja 250R Tech Talk 1 February 25th, 2017 01:10 PM
Front turn signal issues... snowman7 1986 - 2007 Ninja 250R Tech Talk 6 June 30th, 2013 07:21 AM
Turn Signal Issues dsmisfits 2008 - 2012 Ninja 250R Tech Talk 9 December 19th, 2012 09:16 PM
Turn Signal Indicator Issues menikmati 2008 - 2012 Ninja 250R Tech Talk 9 December 12th, 2011 08:17 PM
WTB: Ninja 250 turn signal wiring CGNY87 Items Wanted 10 January 22nd, 2010 01:32 AM
