Old November 21st, 2009, 12:53 AM   #1
welcome2thedawn
welcome2thedawn's Avatar
Motorcycle(s): 08 ninja 250r modded, 73 honda cl200, 74 kawasaki 400 triple
hotbodies undertail/BM integrated tail light question???
does anyone know if there is a way to use the turn signals on the bike monkey integrated tail light with the turn signals on the hotbodies undertail? i called a local bike shopwith this question...and was told that this cannot be done...and if it was that it would be a lot of work....i don't know much about lighting, but it seems like there may be some kind of splitter or something to wire both???
welcome2thedawn is offline   Reply With Quote
Old November 21st, 2009, 01:53 AM   #2
Ken08Ninja
Motorcycle(s): 08 Ninja 250R Candy Plasma Blue
Stay far away from that bike shop. You could have 1 or 50 lights all wired to one turn signal.
All you need to do is connect both of the left side lights to the original left turn signal wire, and both right side lights to the original right turn signal wire. You will also need to change your flasher relay.
Ken08Ninja is offline   Reply With Quote
Old November 21st, 2009, 11:24 AM   #3
chokne
I name everything
chokne's Avatar
Motorcycle(s): Eva
+ 1.
Very simple and straight forward connection
Reborn
chokne is offline   Reply With Quote
Old November 21st, 2009, 11:56 AM   #4
coffeecandy
Motorcycle(s): 2002 Ninja 250
+1 even though i never done it
Bay Area Event Coming Up:
June 2, 2012 Mike's Newb Group Ride
coffeecandy is offline   Reply With Quote
Old November 21st, 2009, 01:33 PM   #5
randomwalk101
self wrencher
randomwalk101's Avatar
Yup..just splice the wire and hook it up...EZ.
Old November 21st, 2009, 03:31 PM   #6
welcome2thedawn
thanks...i've never even spliced a wire and i was thinking that i could just do that....do i just change something on the flasher relay that is already there....or do i need to buy something? thanks again....
Old November 21st, 2009, 06:17 PM   #7
randomwalk101
self wrencher
nope..if it is working right now, splicing another signal in shouldn't effect it.
Old August 8th, 2010, 03:07 AM   #8
Fierce Fiend
Fierce Fiend
Motorcycle(s): 2010 Kawasaki Ninja 250R
Question
Hey welcome2thedawn
Did you end up wiring those led indicators on the undertail up aswell?
I have proton flushmounts, a BM intergrated tail light and just bought a hotbodies undertail and was wondering the same thing about running the LED indicators on the undertail aswell as the others but was not sure if i could.
Cheers
Fierce Fiend is offline   Reply With Quote
Old August 8th, 2010, 03:56 PM   #9
welcome2thedawn
i did....i just spliced the undertail signal wires, and the bike monkey signal wires, with the signal wires from the bike...i did change my flasher relay...it all works fine...i will try to post a video, although i have never done that, so no guarantee it will happen
Old August 11th, 2010, 03:40 PM   #10
tjkamper
tjkamper's Avatar
Pictures??? Videos??? Updates???
Old August 11th, 2010, 06:01 PM   #11
welcome2thedawn
hope this works...i tried take this with my phone...it's not too clear...looks better in real life...they both flash at the same time...but anyhooo...if posting it works right, here it is
yes!!! success!
Old August 13th, 2010, 10:57 AM   #12
Cazper
ninjaholic
Cazper's Avatar
I've been seriously considering this as the small turn signals I've got came undone on a long ride. I think I like this idea quite a bit... we'll see how money goes...lol.
09' SE Ninja 250R
$2,547.83
Old August 13th, 2010, 12:12 PM   #13
sb71
sb71's Avatar
Motorcycle(s): 2009 ninja 250
Call Chris, he did this to both our bikes. He can help you out!
I'm a vet, too
sb71 is offline   Reply With Quote
Old August 13th, 2010, 05:31 PM   #14
Cazper
ninjaholic
Cazper's Avatar
If I end up getting stuck I definitely will. I'm pretty good at wiring though
Posted via Mobile Device
Old August 13th, 2010, 06:18 PM   #15
welcome2thedawn
if you are good at wiring, you can definitely do this...i had never wired anything in my life before this, ever, and it turned out fine the first time
Old August 13th, 2010, 07:14 PM   #16
FerociousNINJA
Motorcycle(s): 2008 Ninja TwoFiddy
Glad to see you got it working.. IMO those Hot Bodies turn signals are weak.
FerociousNINJA is offline   Reply With Quote
Old August 13th, 2010, 10:33 PM   #17
welcome2thedawn
they actually seem pretty bright to me...i'll try to take some pics/vid in the daylight, hopefully a little clearer
Old July 13th, 2011, 09:57 PM   #18
welcome2thedawn
hmmmmmm....what the heck happened? bike has been put away for the winter...I got it started, was kinda checking everything out...and my rear signals are now blinking opposite of the front...I know it's not my imagination...I have some videos of them working fine last year...I hope that there is a logical explanation....weird
HotBodies Undertail. NickNYC Motorcycle-related 5 June 19th, 2012 08:15 AM
tail light/undertail question gsxrninja250 2008 - 2012 Ninja 250R Tech Talk 8 August 30th, 2011 10:22 AM
Bike Monkey Integrated Tail Lights and HotBodies Undertail sarapacman99 2008 - 2012 Ninja 250R Tech Talk 15 May 15th, 2011 02:32 PM
