December 6th, 2012, 07:58 AM | #1 |
Who's jealous now?
Join Date: Jun 2012 Motorcycle(s): Ninja 250R 2012 Posts: 54
Head Specs for use with Nassert Beet Cam
I am planning to use a Nassert Beet T-1 280 degree duration cam. I have the cam already: http://www.beet.co.jp/english/kawasa...50r/index.html. I am not sure of the complete specs for this cam but have heard it is good.
I already have Yoshimura TMR-MJN 32mm carbs and an Arrow Titanium Street Thunder full exhaust system. I have talked to a couple of mechanics and they seem to recommend port-n-polish. I think this is because they only know how to do this and nothing different (in Indonesia). I remember RacerX mentioning doing "valve-relieving" in conjunction with this cam to me a while back. What I am looking for is the best specs to modify the head for use with the Nassert Beet T-1 cam. I have the following questions and would really appreciate RacerX weighing in on this thread as well as anyone else in the know:
BTW bike use is for street Last futzed with by fordendk; December 6th, 2012 at 08:27 AM. Reason: added bike usage |
December 6th, 2012, 08:42 AM | #2 |
MOTM - Sep '18, Feb '16
I have not used anything but stock cams. But I think at least cleaning up the ports of the intake and exhaust would be a good idea. Porting alittle with someone that know how can be good. If they are just grinding away with no flow bench it can be bad.
The main restriction is around the valve seat. So working that area is going to be best. What you are looking for is called deshrouding the valve. And yes you are limited by the exhaust as to how much you can port. Remember that big ports with out a big pump under them will cause air to slow down. When that happen fuel will fall out of suspension and coat the ports. Hi speed air has inertia and will put in more air and fuel that a big port. But the difference is something you can only find from experience and a flow bench then dyno. Porting is an art. http://www.diyporting.com/Shrouding.html How do you like the carbs?
December 6th, 2012, 06:42 PM | #3 |
Who's jealous now?
Thanks for the quick feedback. What I am actually looking for is the specs for the deshrouding so that I can give it to a workshop here. For example what radius to use around each of the valve seats and how deep to go into the head. Also I want to know whether to do both intake and exhaust sides.
I am fully aware of the hand tools etc. that guys use when porting. The guys here know how to do that and have plenty of experience. Do you think I should have them pnp as well as deshroud or just pnp or vice versa? The carbs are really good. They completely flattened out my torque curve and gave me a lot more acceleration than the standard carbs with jet kit etc. I run them with dual velocity stacks and no air filter on the street. So far no problems. Have serviced the bike twice since installed and had the carbs cleaned to get rid of any crap. No big deal there either. I have even taken the bike touring outside city in Indonesia with the worst dusty/dirty conditions you can imagine and no issues. |
December 6th, 2012, 08:37 PM | #4 |
Join Date: Jul 2012 Motorcycle(s): 2010 Ninja 250 2009 Ninja 250 Posts: 730
Mill the guides for the extra lift and use a higher spring rate maybe?
2010 Red Ninja 250 2009 Black Ninja 250 -If you ride like lightning,you're gonna crash like thunder- |
December 7th, 2012, 02:19 AM | #5 |
The is no spec for the port and polish work. I would say to do the work on both intake and exhaust. And polish the head .
Let us know how it works out. Have you run with out the stacks? Some carbs run better just wide open.
December 7th, 2012, 12:21 PM | #6 |
Who's jealous now?
December 7th, 2012, 01:56 PM | #7 |
I removed my stacks when on the dyno. I was trying different filters and exhaust systems. There was a clear one hp drop. So I dismissed it. While talking to some very reputable people. People that had the fastest 250 ninja. And still hold the fastest 250 all motor pass at 117 mph they said the same thing. One hp down with out the stacks on the dyno. BUT on the track the bike picked up a couple mph. They did back to back tests and confirmed it. I have not had a chance to conferm it. But that is the story.
April 9th, 2013, 10:07 AM | #8 |
Who's jealous now?
Just in case you are interested this was what my bike dyno'ed today. I changed the Arrow exhaust for a Yoshimura R77 Japan model and installed the Nassert Beet T1 camshafts. The bike is tuned a little lean right now (you can see on AFR) but is running very nicely and the Yoshimura carbs work very well with the Yoshi R77 exhaust. Acceleration is now very good... as you can see on the dyno chart the torque curve is very flat. Max torque is 20.27Nm now (14.95ftlb). It actually accelerates better than an ER6N up to about 140Kmh tested (87mph... ER6 rider was shocked). Max HP was 32.63. The 3 runs on the dyno chart were 3 different ignition maps on my BRT. Interestingly the bike seems to run best on 92 octane fuel:
April 9th, 2013, 05:09 PM | #9 |
Board Member
Those are some nice curves
April 17th, 2013, 02:36 AM | #10 |
PnP engine mods..
even the part is quite expensive, but I liked how the beet cam work to improvise engine. that's why I'm lovin it. |
Beet Camshaft Info-Anyone know how to translate pdf | tubarney | 2008 - 2012 Ninja 250R Tech Talk | 98 | October 9th, 2020 05:03 PM |
replacing exhaust cam with intake cam | subxero | 2008 - 2012 Ninja 250R Tech Talk | 2 | June 1st, 2014 12:19 PM |
Installed Nassert Beet 320mm Front Rotor today | mania | 2013 - 2017 Ninja 300 Tech Talk | 12 | February 12th, 2014 05:22 PM |
BEET 265cc kit | angrycrow | 2008 - 2012 Ninja 250R Tech Talk | 8 | September 18th, 2009 05:44 AM |
