Old September 22nd, 2009, 08:50 PM   #1
[motorcyclistonline] - Braking Styles On Motorcycles - Code Break
Up To SpeedBraking, it turns out, does much more than just slow you down. Fork flex, geometry changes, tire deformation and a host of other forces come into play, drastically affecting the way the motorcycle negotiates a corner. The forward pitch of the bike under braking can steepen the fork angle by as much as 4 degrees on a Ducati 1098, for example. This reduces trail by roughly an inch on the same hypothetical 1098, and effectively shortens the wheelbase as well. Front-wheel load can double under heavy braking. Tire height shrinks under load, further decreasing trail by a slight amount. At the same time, however, the contact patch both broadens and lengthens rearward, which can restore trail by as much as 1 inch. Trail is now close to where it started, unless the tire locks up-at which point you'd have very little stability, owing to an instant reduction of trail. Braking doesn't sound so simple anymore, does it?
Photo Gallery: Braking Styles On Motorcycles - Motorcyclist Magazine
Read More | Digg It | Add to del.icio.us
Click here for full story...
[motorcyclistonline] - Braking & Downshifting | Code Break Ninjette Newsbot Motorcycling News 0 November 29th, 2012 08:00 PM
[motorcyclistonline] - Code Break - Electric Motorcycles - The Golden Age Ninjette Newsbot Motorcycling News 0 April 27th, 2010 05:10 PM
[motorcyclistonline] - Code Break - Braking and Downshifting Smoothly Ninjette Newsbot Motorcycling News 0 April 13th, 2010 04:00 AM
[motorcyclistonline] - Code Break - Braking and Downshifting Smoothly Ninjette Newsbot Motorcycling News 0 April 6th, 2010 02:00 AM
[motorcyclistonline] - Code Break - Braking and Downshifting Smoothly Ninjette Newsbot Motorcycling News 0 April 1st, 2010 10:50 AM
