Old May 31st, 2017, 07:10 PM   #1
Dbrubaker
Motorcycle(s): 04 Ninja 250r
Exclamation Hose Connected to Air Box
Okay so I'm trying to put my air box on and I'm not sure where the hose that is attached to the air box goes. It has a flat rectangle shape. Help!!!!
Dbrubaker is offline   Reply With Quote
Old May 31st, 2017, 07:13 PM   #2
MrAtom
MOTM - July '15
It doesn't go anywhere. Oil can get into the airbox and you're supposed to remove that little plug on the bottom to drain it if it fills up.
Old May 31st, 2017, 07:31 PM   #3
Dbrubaker
I figured that out right after I posted. My other question is do you know what goes in the hole under the airbox. My bf took it apart so I don't know what's what.
Old May 31st, 2017, 07:48 PM   #4
MrAtom
MOTM - July '15
Looks like a threaded hole that a bolt goes into but I have no idea what.
Word to the wise, don't let someone monkey with your bike if they don't know what they're doing, or if they're going to do half the job and make you finish an unfamiliar task that you've never done before.
Good luck with your bike!
Old May 31st, 2017, 07:51 PM   #5
Dbrubaker
He's not just some random person... and he knows what he's doing. I didn't watch him disconect it. That being said, it's my bike not his which is why I'm the one putting it back together. I have to learn some how.
Old May 31st, 2017, 07:58 PM   #6
MrAtom
MOTM - July '15
I didn't call him a monkey. I said he was monkeying with your bike.
It'd also be pretty weird if I'd let someone else disassemble something I'm not familiar with without me watching, and then try to put it back together myself. When I wanted to learn more about my bike, I took it apart myself in order to get an idea of where things went when I reassemble it.
I figured you'd get your boyfriend's help if he knew what he was doing. It's not difficult to see why I came to the conclusion that I did. So, go get his help.
Old May 31st, 2017, 08:14 PM   #7
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
That is the crankcase vent, there's an odd shaped hose that goes from that nipple to the nipple on the bottom of the airbox, on the right side.
and welcome to the board!
Old May 31st, 2017, 08:55 PM   #8
Hi Deena, it's good to meet you, and welcome!
Old June 1st, 2017, 02:49 PM   #9
Dbrubaker
Is it the hose in the first picture?
Old June 1st, 2017, 04:43 PM   #10
Momaru
Momaru's Avatar
Negative. I'm not sure if it's true on your model, but on the newer ones, it's somewhat S or question-mark shaped, with a taper that's larger on the gearbox side.
Proud member of the Blue Army
Old June 1st, 2017, 05:11 PM   #11
Dbrubaker
So what do I do if I don't have that hose?
Old June 1st, 2017, 06:12 PM   #12
Z1R rider
Z1R rider's Avatar
Yep that's what the pre-gens have too. Here's a link to BikeBandit's parts fish, it's "A" #92059, they're the same from 1988 to 2007 I believe.
http://www.bikebandit.com/oem-parts/...49388sch284591
Old June 1st, 2017, 06:13 PM   #13
Z1R rider
Z1R rider's Avatar
I'd be grilling the BF.
Old June 2nd, 2017, 01:07 PM   #14
Dbrubaker
I ordered it already thank you. I was there when he took it off and I don't even know where it is. LOL
Old June 5th, 2017, 09:55 PM   #15
Snake
Snake's Avatar
Hello and welcome!
Old July 12th, 2017, 01:15 PM   #16
marbus76
good luck! you can look on part diagram online for it too
marbus76 is offline   Reply With Quote
air box John D 1986 - 2007 Ninja 250R Tech Talk 10 September 4th, 2012 08:07 PM
K&N air filter to stock air box Graugaard 2008 - 2012 Ninja 250R Tech Talk 29 July 28th, 2012 06:33 AM
Air box removed, now.... cbowman78 2008 - 2012 Ninja 250R Tech Talk 6 December 15th, 2010 08:11 AM
Issue with leaking oil ... no hose on air box ? thsadmin 1986 - 2007 Ninja 250R Tech Talk 10 May 9th, 2009 06:18 PM
