Old August 13th, 2014, 01:07 PM   #1
joecool
Yoshimura fender eliminator install question
Hey guys,
I wanna buy this kit, I am looking at the yoshimura instructions and it doesn't look detailed!
My question is once I reassemble the stock turn signals, how do I screw them to the new fender? do I use the supplied bolts? before they were attached by rivets on the stock fender.
Does anyone have a clear pic of under the eliminator kit once its installed so I can see how the signals were mounted?
Thank you!!
Joe
joecool is offline   Reply With Quote
Old August 13th, 2014, 01:20 PM   #2
Jefft
Motorcycle(s): 2012 250R
Once you drill the rivet out, you save all of the stock mounting hardware and re-use it.
Jefft is offline   Reply With Quote
Old August 13th, 2014, 01:22 PM   #3
allanoue
allanoue's Avatar
MOTM - Sep '14
https://www.ninjette.org/forums/showthread.php?t=184753
Old August 13th, 2014, 01:26 PM   #4
joecool
Thanks! But how do you screw it onto the new kit?
Old August 13th, 2014, 01:27 PM   #5
joecool
Originally Posted by allanoue View Post
Thanks for the picture, I was looking for a pic of how the flashers are bolted on to the new kit
Old August 13th, 2014, 01:33 PM   #6
Jefft
Use the same screws that you unscrewed to remove the signals. Once everything is apart, it makes a lot more sense. You don't need to source out any extra hardware.
Old August 13th, 2014, 03:11 PM   #7
Ralgha
Ralgha's Avatar
It will make sense when you do it.
I installed this on my bike a couple months ago, my problem was that the screw for one of the signals WOULD NOT come out of the stock fender. It must have been cross threaded or something, I stripped the hell out of it trying to get it loose and it wouldn't budge.
Got out the screw removal bit for my drill, that didn't move it either, so I resorted to drilling the whole screw out. Got so hot while doing that, it melted the plastic base of the turn signal so much that a screw wouldn't hold it anymore.
Ended up having to buy a new signal assembly and screw, the only parts of that signal that I could reuse were the metal bracket and rubber spacer thing.
Anyway, you probably won't have that issue, and it's a pretty easy install other than that circus I went through.
Old August 13th, 2014, 08:20 PM   #8
joecool
Posted via Mobile Device
Wow!! i hope that doesn't happen to me lol, thanks for the help guys
How to install Yoshimura Fender Eliminator reroka 2008 - 2012 Ninja 250R Farkles 4 June 14th, 2014 05:20 AM
Yoshimura Fender Eliminator cstro250r Pictures 42 June 14th, 2014 05:17 AM
Yoshimura fender eliminator SpicyNuggets 2008 - 2012 Ninja 250R Tech Talk 4 January 20th, 2013 08:37 PM
Another Fender Eliminator Question e90 2008 - 2012 Ninja 250R Tech Talk 16 December 10th, 2012 01:56 PM
Help!! install fender eliminator uncle hilty 2008 - 2012 Ninja 250R Farkles 7 October 9th, 2012 09:43 AM
