Old June 18th, 2013, 01:18 PM   #1
spooph
spooph's Avatar
Motorcycle(s): '08 Ninja 250R
MOTM - Oct '15
Spooph's 250 build thread
So, Racer X convinced me to post this up here. This is a migration form newninja.com, since the project was started almost 3 years ago!
Re-build dyno, 40K heavy miles on the engine:
Steps towards an empowered engine:
It's kinda funny really... I started out wanting to install steel braided brake lines and just kept running with the "Well, while I'm here, I might as well do this...."
Phase 1: Getting the 250 in shape:
Optomizing stock parts:
1.) Return to stock setup, have it dyno tuned and get a base line figure of HP and A/F
2.) Install data logger from Innovate to match A/F from baseline for future mods.
LM-2 Wideband O2 Digital Air/fuel Ratio Meter
3.) Install modified airbox, run dyno
4.) Install modified exhaust, run dyno
5.) Install flowed head, possibly deck head, Have it dyno tuned.
6.) Install 13:1 pistons, run dyno.
7.) Futz with ignition timing/cam timing, dyno.
Old June 18th, 2013, 01:56 PM   #2
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Awesome.
Worlds fastest 250 ninja
Old June 18th, 2013, 02:04 PM   #3
Racer x
Racer x's Avatar
To address an earlier question. It took just the pressure of my finder nail to push the bearings into the rod.
Old June 18th, 2013, 02:07 PM   #4
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
sounds cool, so where are you at in the process?
you said you started 3yrs ago, are you done?
Did you do all those dyno runs? if so lets see the paper work, i think lots of people would like to see what those mods did on paper.
cool stuff
Old June 18th, 2013, 02:13 PM   #5
spooph
spooph's Avatar
MOTM - Oct '15
Thanks for the photo X!
This project is being resumed, so I'm still at step one. I will post some updates tonight concerning the bottom end, and it will be slow-going....
Old June 18th, 2013, 02:26 PM   #6
Sub'd.
My $0.02: Racer X and I have both found that this engine likes fuel. I've got my EFI setup supplying 12.5:1 AFR at the top end and WOT, and it really responds well. My shop typically tunes for 12.8-13.2, but FWIW richer feels better on the 'ol butt-dyno.
Old June 18th, 2013, 04:10 PM   #7
mgentz
Board Member
Interested to see how yours comes along. What are you all doing?
Old November 19th, 2013, 09:23 AM   #8
spooph
spooph's Avatar
MOTM - Oct '15
Update: So, this little project isn't nearly as cool as some of the other engine/bike builds around here....
However, I believe mine is the only one with a nearly stock engine without a counter-balancer... Got it all put back together and went for a test ride the other night. Aside the fact that I lost my front sprocket nut (forgot to torque it down in all the excitement) on the high way, I'm happy to report the vibes aren't much more than with the counter-balancer.
So, balanced crank, went from 1,700lbs @ 12K out of balance to 55lbs @ 12K. Scott Jensen at Moto Garage did the work, and tapped a bolt into the counter-balancer to keep it in place and keep oil pressure up. Some of the counter balalncer's weight was cut off to clear the rods and such, and I totally failed and forgot to take pictures....
Next step is to adjust jetting and then get some time on the dyno to see what a balanced crank w/o counter balancer gives, and then see what the subsequent changes (air box, exhaust, etc) does...
Side note: I had no idea there was so much to building an engine. If I have learned anything through this process, it's that I'm not an engineer, and I never will be, and it's much less of a headache to pay a reputable shop to do this, than trying to do it on your own...
Old November 19th, 2013, 12:08 PM   #9
mgentz
Board Member
Cool. But seriously pics?
Old November 19th, 2013, 04:43 PM   #10
cuong-nutz
cuong-nutz's Avatar
That's very interesting! How does the motor feel reving? Smoother/faster?
HalfFast Racing Team
Old November 20th, 2013, 02:59 AM   #11
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
@spooph it's interesting to read about your plan and why should an engine without a counter-balancer not run smooth? For sure it will rev better...
I remember in earlier times no engine had one and the only engine I know for which it is a must have is the 5 cylinder (engineer is the great Ferdinand Piëch) and the sound from this engine also is much better then the older american muscle-V8 (just not to say that I've been having many fun with one of those old Audi Quattro)
Good luck for you
Old November 20th, 2013, 10:08 AM   #12
spooph
spooph's Avatar
MOTM - Oct '15
@cuong-nutz - the engine revs a little bit faster, however I don't think it's going to show it's true benefits until some more modifications are made... Trying to get a dyno run scheduled to figure out if by itself it has provided any gain... Feel-wise, the motor vibrates a little bit more, but not much more than stock. Like, not nearly enough to make your hands go numb, or to make the bodywork rattle, etc.
@mgentz - yea, I know, I'm kicking myself for that now....
Old May 5th, 2014, 09:30 AM   #13
spooph
spooph's Avatar
MOTM - Oct '15
Finally got the jetting done and another Dyno in, 2hp gain by removing the balance shaft...
Old May 5th, 2014, 09:37 AM   #14
sonny4472
sonny4472's Avatar
Motorcycle(s): 09 250r, 09 1125r, 95 Virago
What happened to your torque curve? Is that the intention of your design?
sonny4472 is offline   Reply With Quote
Old May 5th, 2014, 09:45 AM   #15
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
^ looks like A/F plot not torque
but regardless your A/F looks like it needs some work.
what is your jetting?
I'm surprised by how much your HP curve drops after 10K especially being rich. I feel like the higher revs run a good bit richer than range.
Old May 5th, 2014, 09:54 AM   #16
mgentz
Board Member
2 HP just by getting rid of the balance shaft or did you change your jetting? By and large, slightly lean = more HP. Due to this I would wonder about the true effects of the balance shaft on HP.
Old May 5th, 2014, 09:59 AM   #17
sonny4472
sonny4472's Avatar
I always wondered how much a balance shaft affected performance. I wonder how the motor feels without out it or if there are any adverse affects.
Old May 5th, 2014, 10:25 AM   #18
spooph
spooph's Avatar
MOTM - Oct '15
@subxero - yes, jetting definitely needs some work! Stock jets, idle and main, 2 shims under the needles to get rid of a pesky low spot around 7K RPM's.
@mgentz - I thought all 250 power curves drop off around 10K RPM with stock exhaust system, as it restricts air flow and starts working against itself?
Next step would be to install either the modified airbox or exhaust, jet appropriately, and get another dyno.
What I'm really trying to do is to see which single factor has the biggest impact on the engine, and how much of a multiplier the counter balancer removal... Unfortunately I don't have oodles of time/money to dump into a purely scientific approach (changing 1 factor at a time), but I've never seen a systematic look at each factor....
usually it's intake + exhaust, jet appropriately and more power, but does anybody know how much each part is worth?
any ideas on how to do this better would be appreciated!
Old May 5th, 2014, 10:26 AM   #19
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
from the graph he would be rich though right?
A/F higher being lean, lower being rich?
Old May 5th, 2014, 10:27 AM   #20
sonny4472
sonny4472's Avatar
This could turn out to be an awesome thread.
Old May 5th, 2014, 10:27 AM   #21
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
Oh you are still running stock, I was under the impression that you had some other things done. My mistake
Old May 5th, 2014, 10:38 AM   #22
I thought all 250 power curves drop off around 10K RPM ..
Isn't that because of the New Gen tuning changes for more midrange?
Old May 5th, 2014, 10:40 AM   #23
spooph
spooph's Avatar
MOTM - Oct '15
@jkv45 - Yes, I believe so, somebody correct me if I'm wrong!
Old May 5th, 2014, 10:42 AM   #24
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
I really like what you are trying to do but you probably already know that it is going to be tough to really get individual affects narrowed down because you will have cumulative affects with some things.
I might have done this
Tested stock
I would have probably jetted the bike first - test 2
Remove snorkel, rejet - test 3
Full exhaust, snorkel in rejet - test 4
Full exhaust, snorkel out, rejet- test 5
Full exhaust, pods, rejet, - test 6
Return to stock everything, balanced shaft, - test 7
Balanced shaft, full exhaust, snorkel out, rejet - test 8
......................................, pods, rejet - Test 9
ect...
^ the idea being to try and get readings for all the more easily swapped on and off parts first before doing things that can not be easily un done... if at all. Since you balanced the shaft already you have kind of created a new baseline in which your other readings will have to be measured from unless you put an unbalanced shaft back in, ya dig?
Again impossible to get around in some instances but it is what it is.
Regardless it will be cool to see everything and a boat load of work
Old May 5th, 2014, 11:02 AM   #25
spooph
spooph's Avatar
MOTM - Oct '15
@subxero - yup yup, I totally agree, but here's my thinking.. I don't have that kind of cash - that's $486 in just dyno pulls (I haven't been able to find anybody willing to do it for less than $54)... This is also a great discussion to point out what we don't know.
I thought with the variances in dyno results I would be getting trends anyway, not hard numbers, since it takes me forever to do anything. If I could, for instance, do this all within a week in a temperature/pressure controlled dyno it would most certainly be worth it!
I can't remember all the threads and discussion, but from before my internetz hiatus these were the trends (2011):
pods + full exhaust would usually get ~33rwhp.
high comp pistons, worked head ~37rwhp.
ignition timing 38rwhp+
@RacerX I believe was the first to push a new-gen 250 beyond the limits of the stock clutch around ~40bhp (~38rwhp).
So, I was hoping to interpolate from those numbers, so I wouldn't have to redo all of that work. So, anyway, you and I are tracking. I guess I just wanted to put these number down so that other people could follow along...
I guess what I really want to know, and through using other's results (I know, not terribly consistent and scientific) I'm hoping to figure if the counterbalancer is a multiplier, or if it's worth a finite amount of power on it's own. So, as long as the question is a "yes" or "no" and not that of a value amount, methinks this process will be accurate enough. It won't produce hard numbers, but it will give us an idea, so somebody else can do something better with their resources...
Old May 5th, 2014, 11:05 AM   #26
mgentz
Board Member
yes, he is rich now. Leaning up the main will get him more HP (in theory).
I am still shocked about the 2 HP.
Old May 5th, 2014, 11:13 AM   #27
mgentz
Board Member
@Racer x exceeded the stock clutch abilities before adding N2O I believe. Then he added N2O and got 60 (+?) HP. Too much for stock, but not for a modified clutch like he and I have.
As for these numbers:
They may be in the ballpark, however if I would guess they should be more like 32, 35, 36. Also, you must remember that many other systems will need to be updated along the way.
NOT TUTING MY OWN HORN HERE, but I most likely have one of the most modified NA bikes and I am working to get 40 HP out of just the motor. I will post my dyno results here and in my thread once completed.
Old May 5th, 2014, 11:44 AM   #28
spooph
spooph's Avatar
MOTM - Oct '15
@mgentz - thanks for the #'s! Just post your dyno in your thread, we'll keep things organized... BTW, I'm going through you Ultimate build thread with a fine toothed comb, trying to soak up as much as I can...
I was surprised by the 2 HP as well... I thought it was going to be a decimal increase and it would pay dividends later... We'll see how the other mods get on..
Old May 5th, 2014, 12:05 PM   #29
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
same dyno right? Just 1 pull for each time there?
Old May 5th, 2014, 12:30 PM   #30
mgentz
Board Member
careful in that thread. There is a lot of information buried in a lot of problem solving, mixed with a lot.
Old May 5th, 2014, 12:33 PM   #31
mgentz
Board Member
you should get a package deal from the dyno place. Agree to or pay for 10+ pulls for a time period, then ask for a discount.
^ this works as I have done it before
Old May 5th, 2014, 12:45 PM   #32
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
+1
Was thinking along same lines, you should be able to do some quick changes between pulls. All plastic and non essentials off the bike and you should be able to change jetting, remove snorkel, re install snorkel and even, put on a full exhaust system between pulls. Probably wouldn't be able to remove airbox and install pods between pulls though
Old May 5th, 2014, 12:51 PM   #33
Racer x
Racer x's Avatar
Unfortunately most shops cant let you work on the bike in the shop. The insurance will not cover a giant fire from spilled gasoline and a spark from the starter lead touching a fuel bowl. Just for instance.
And you probably can't push it outside and do it in the parking lot either.
Old May 5th, 2014, 12:56 PM   #34
mgentz
Board Member
this sounds like you have some experience with this?
Old May 5th, 2014, 01:47 PM   #35
Racer x
Racer x's Avatar
I have been on fire. But not from that one. But I am aware of the danger.
Old May 5th, 2014, 04:44 PM   #36
cuong-nutz
cuong-nutz's Avatar
Would you want the counter balancer oiling holes to face perpendicular to the oiling galleys on the crankcase to keep oil pressure up?
So to make this work you remove the gear off the counter balancer and clearance the counter weights on the balancer.
Old May 5th, 2014, 04:54 PM   #37
Racer x
Racer x's Avatar
Ya that seems to be what he did. A brilliant way of doing it. I wish I was that smart.
Old May 6th, 2014, 04:08 AM   #38
mgentz
Board Member
@spooph do you have pics of this? From what I've seen you would need to turn the balance shafts weights almost completely off as they will hit the crank. the shaft will turn.
Old May 6th, 2014, 06:21 AM   #39
Racer x
Racer x's Avatar
The normal way to remove a balance shaft is to make pieces that replace the shaft but allow oil flow. Using the original shaft and just removing the weight is a better solution in my opinion.
Old May 6th, 2014, 06:52 AM   #40
mgentz
Board Member
I think that's a good idea too. I would like to see pics I like it so much.
The only thing to note is that the shaft will turn no matter how you initially orientate it. However, using the original shaft with the oiling holes and proper clearances would be best.
Ninja 250 racer build thread bitaria Ninjettes At Speed 81 December 8th, 2015 08:19 AM
New Pickup - Eventual Build Thread ninjakuma The Ex-Ninjetters Lair 9 August 22nd, 2014 11:36 AM
99 Ex 250 project Cafe/streetfighter, The build thread. cerberusrex25 1986 - 2007 Ninja 250R Tech Talk 260 June 14th, 2014 04:27 PM
Christmas Build thread ds650rida 1986 - 2007 Ninja 250R Tech Talk 84 June 10th, 2014 02:46 PM
Epic build thread Alex Off-Topic 8 April 8th, 2013 04:57 PM
