Old December 2nd, 2013, 09:01 AM   #41
bitaria
Motorcycle(s): CRF450X, CRF250R/SM, Husky 630 SMS, Ninja 250R
The rear shock is in...
After drilling out top and bottom mounting holes to 12mm everything lined up and went in fine. There seems to be good suspension movement, no binding up etc., but I plan on doing a bit more testing with spacers.
First impression is that there is not enough static sag (using GSXR stock settings across the board).
bitaria is offline   Reply With Quote
Old December 2nd, 2013, 11:47 AM   #42
the engine and frame are a good 75 lbs lighter. you'll want to switch springs
Old December 2nd, 2013, 12:23 PM   #43
bitaria
GSXR spring rate is the same as stock Ninja, at least on paper. Fork is still stock, but will get professional re-valve at some point this winter.
Old December 2nd, 2013, 12:28 PM   #44
spring rate doesn't translate directly when you replace the reducer knuckle. i forget but i think the 05 gsxr is a 0.4 where as the ninja is 0.6. the triangle "knuckle" piece that the dogbones and shock mount to actually introduces a small sine-wave (because it rotates) into the compression graph to provide a more "progressive" shock compression. depending on how much the knuckle moves it can be almost nothing but it is there. the knuckle also acts as a reduction lever since the dogbones are mounted further out than the shock itself (or vice versa in many cases). the distances between the gsxr knuckle and the 250 knuckle are different.
Old December 2nd, 2013, 12:31 PM   #45
bitaria
Right, I mean the raw spring rate, linkage aside.
Old December 5th, 2013, 11:57 AM   #46
Tough Noogies
Motorcycle(s): 675, 250
Random question:
Did you drill out the upper shock spacer / bearing to 12mm? Or drill out the GSXR upper shock hole to 12mm and then press in the Ninjette OEM spacer / bearing?
Curious because I will be doing the same soon and the language people use to convey what they did is always minimal. Haha
Tough Noogies is offline   Reply With Quote
Old December 5th, 2013, 12:34 PM   #47
bitaria
Originally Posted by Tough Noogies View Post
Random question:
I drilled the gsxr fitting to 12mm. Didn't have to press it out or anything.
Old December 5th, 2013, 09:08 PM   #48
sparkplug896
sparkplug896's Avatar
Motorcycle(s): 04 ex250f
talking about the rear shock.. what year make and model does gsxr have that fits the ninjas
sparkplug896 is offline   Reply With Quote
Old December 6th, 2013, 10:34 AM   #49
Tough Noogies
Have a look through here the below thread link and the Ninja FAQ. Lots of suggestions on applicable years, etc. Hope that helps!
http://www.ninjette.org/forums/showthread.php?t=59486
Old December 6th, 2013, 10:50 AM   #50
sparkplug896
thanks very helpful
always hit the back roads..
Old December 24th, 2013, 10:13 PM   #51
bitaria
Made some progress!
Custom fairing stay mostly finished up, just need to add Vapor dash mount.
Old December 27th, 2013, 02:16 PM   #52
bitaria
With dash mounted
At this angle dash is hard to see, I will re-mount it leaned back more and do the final pretty welds. It's all spot welded for now.
Old December 27th, 2013, 04:56 PM   #53
bitaria
Final product!
Old December 29th, 2013, 12:18 PM   #54
bitaria
Eyes are in. Pinch bracket holds everything on 2 bolts, so easily removed for track and re-installed for street.
I wish I had a better welder... still lighter than stock fairing stay it would be better if made from aluminum, but my MIG can't handle it.
Old December 31st, 2013, 09:31 AM   #55
Foxrider64
Hello Moto
Foxrider64's Avatar
Motorcycle(s): 1975 RD350; 2001 KX125; 2003 Z1000; 2003 KDX50; 2009 ZX6R; 2011 Ninja 250R; 2014 KX250F
Looks good.
Much lighter than stock for sure.
Foxrider64 is offline   Reply With Quote
Old January 5th, 2014, 10:49 PM   #56
bitaria
Other than front turn signals electrical work is done. Bike can convert from street to track in a few minutes.
I'm still evaluating crash protection options, Shogun sliders kit seems like the best option, but price is rather high. Any suggestions?
Old January 6th, 2014, 07:47 AM   #57
Foxrider64
Hello Moto
Foxrider64's Avatar
In my experience- the little ninja's frame is too narrow for frame sliders to not inflict more damage than a crash.
They act as lever arms when the bike goes down and can twist the frame or break the engine mount.
I actually took the sliders off my bike when I converted it to track use.
Just my
Old January 6th, 2014, 08:41 AM   #58
bitaria
Just my
This is not the first time I hear this. I've seen some slider setups where they do not protrude from the bodywork, essentially race glass becomes disposable. With something like Shogun kit it would involve cutting down sliders to fit.
Old January 18th, 2014, 10:51 AM   #59
bitaria
Made a bit more progress. Pretty much gave up on eBay seller to send me the right linkage and made my own connector. Really just a threaded m6 rod with LH twist on one end and RH on the other, had to use a lathe to make it all work.
Now the bike is a runner but it will not rev well and dies at WOT, could need some fresh gas and I know for sure it is very lean, especially in cold weather. Carbs are next on the to do list.
Old January 28th, 2014, 08:33 PM   #60
bitaria
Contacting the Chinese rearset manufacturer to get the right parts has failed. They told me several times that replacement parts were shipped, but nothing ever showed up. Ended up turning a bolt to but RL and LH thread on it to make it work.
Old February 6th, 2014, 05:38 PM   #61
bitaria
In my last post I had a picture of a custom bolt I made to connect shift linkage. Today parts from China came as promised, it just took them a really long time to get here. They did send me 2 sets, so my spare kit is also covered.
That said the bike is not longer in my garage, it went to Dave Alexander of Fluid Suspension Science for you may have guessed - suspension work. He will also be ordering a few other bits like clipons, brake pads, and in general checking my work.
Old February 10th, 2014, 02:17 PM   #62
shane liberty
shane liberty's Avatar
Motorcycle(s): None Yet
Hopefully you haven't cut the subframe on your bike yet. Just a heads up on that. Supersport/Superstock rules prohibits cutting or modifying the subframe. You'll get protested if someone wants to be a dick about it.
shane liberty is offline   Reply With Quote
Old February 10th, 2014, 04:12 PM   #63
bitaria
Nope, was not planning on doing anything.
Old April 10th, 2014, 08:53 AM   #64
bitaria
Got the carb off, but ran into a few questions around routing and what can be blocked off.
https://www.ninjette.org/forums/showthread.php?p=841372
I will be at the Ridge this weekend with 2-fast.org, 1st time out this year (and really in 3 years at a big track)
Old April 11th, 2014, 03:09 PM   #65
bitaria
Ready to go, just in time.
Old April 15th, 2014, 04:08 PM   #66
chugs
Schönen Tag noch
chugs's Avatar
Motorcycle(s): 08 ninja 250 race bike, 02 gixxer 600 telefonica
Got any more pics of your clipon setup? Looks like yours are fairly low and had to cut your fairings to accomodate.
chugs is offline   Reply With Quote
Old April 15th, 2014, 04:36 PM   #67
bitaria
Clipons are Vortex, and they sit below the upper triple, with controls rotated at a pretty steep angle down. I basically set it up the way I like and then cut fairings to make everything work. Had to add some material to steering stops, so turn radius isn't as tight.
Old April 16th, 2014, 06:26 PM   #68
chugs
Schönen Tag noch
chugs's Avatar
Thanks, I currently have the woodcrafts clipons. I'm gonna slide them down the forks and see how it goes.
Old April 30th, 2014, 07:47 AM   #69
bitaria
Started on paint, or rather plastidip. Kawasaki should be green, but I didn't want to buy another tank or repaint this one - so plastidip. We will see how durable it is, worst case - easy to remove.
Here is a preview
Old April 30th, 2014, 11:13 AM   #70
Foxrider64
Hello Moto
Foxrider64's Avatar
Love the color.
Old May 2nd, 2014, 09:51 AM   #71
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
definitely let us know how the dip holds up
Old May 3rd, 2014, 01:47 PM   #72
Tough Noogies
The color does look fantastic!
I'm curious: how much extra weight do you think the plastidip added? In my head, it seems like it would be a lot, but I don't actually have any experience using it on something that large.
Old May 4th, 2014, 07:52 AM   #73
bitaria
I don't think it adds more than normal automotive paint... If anything should be easy to remove, but I hope it will hold up OK.
Old December 4th, 2015, 05:49 AM   #74
redkid
Motorcycle(s): ninja 250r
There is a lower lip on either side that has the ability to be bolted to the stock undertail. Hense another reason to keep the undertail.
The two indents on the top of the tail are for race subframes only.
What is this race subframe that you've been speaking off? Who makes it, and does anyone have any pictures?
redkid is offline   Reply With Quote
Old December 4th, 2015, 09:50 AM   #75
Foxrider64
Hello Moto
Foxrider64's Avatar
I haven't actually seen any for sale- I have seen some custom made ones though.
Old December 5th, 2015, 07:09 AM   #76
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
Made some progress!
if you want to get rid of you key, i know a guy that makes a harness that re-routes the ignition to be turned on and off with the kill switch.
TEAM ALFALFA
www.apexassassins.com
Old December 7th, 2015, 11:25 PM   #77
daverdfw
Motorcycle(s): 2009 Ninja 250
Who would that be? I am interested in doing that on my track bike.
daverdfw is offline   Reply With Quote
Old December 8th, 2015, 01:38 AM   #78
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
https://www.woodcraft-cfm.com/cgi-bi...4#General-Info
Old December 8th, 2015, 04:34 AM   #79
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
https://www.facebook.com/arek.stanton?fref=ts
he'll make them for $20.
TEAM ALFALFA
Old December 8th, 2015, 07:26 AM   #80
sharky nrk
sharky nrk's Avatar
^^ plug and play for $20? I would be in for one for sure. Glad to see Woodcraft is making one, but not sure I want to spend $60 on it.
1987 Ninja 750R Build Thread hawkxcore 1986 - 2007 Ninja 250R Farkles 32 September 14th, 2016 06:18 PM
Spooph's 250 build thread spooph 2008 - 2012 Ninja 250R Tech Talk 63 November 24th, 2015 07:56 AM
My 07 250 cafe racer build elephantman78 1986 - 2007 Ninja 250R Farkles 12 December 25th, 2014 07:09 AM
99 Ex 250 project Cafe/streetfighter, The build thread. cerberusrex25 1986 - 2007 Ninja 250R Tech Talk 260 June 14th, 2014 04:27 PM
Racer X engine build thread Racer x 2008 - 2012 Ninja 250R Tech Talk 189 June 12th, 2013 07:34 AM
