#1 |
Lays er down
Join Date: Apr 2012 Motorcycle(s): 2008 Lime green Ninja 250R Posts: A lot.
FS: Chinese shorty levers
I got my levers and I forgot to ask for regular size so they sent me shorties
![]() These are green with black adjusters http://www.ebay.com/itm/280843075900...84.m1423.l2649 20 bux |
#2 |
Why you no like shorties?
I UPGRADED to a YZF-R6 Mods: Shermoto LF7 Levers / Proton Flushmounts / Puig Smoked DB / Woodcraft Sliders / Tech Spec C3 Tank Grips / Rizoma Grips / Jardine |
#3 |
Lays er down
cause i like regulars
#4 |
Y u like 2 be regular? U shud b Squid lYke me.
#5 |
Lays er down
i dun want to be squid tho
#6 |
Join Date: Aug 2012 Motorcycle(s): '13 Ninja 300, '99 SV650 tracked Posts: 378
Is the quality of these crap? They're so inexpensive, but there's not much to a lever, do the adjusting mechanisms even work?
#7 |
Lays er down
No, i had these same levers before in regular size and they are very well made and do adjust. i used the closest to the bar setting on the clutch side for my baby hands and 2nd closest on the brake side (the closest setting i doubt allows you to use ALL of your braking power). There is a huge difference in the distance you can set them at from the stock ones
#8 |
Certified looney toon
MOTM Jul '13, Jul '14
$20 for the pair? That with or without shipping (going to 89407 if needed)
Is the green more standard lime green or has a hint of metallic to it? The pic seems a bit metallic which would work for my candy green. I'm interested.
![]() Hey Unregistered! The code [you] shows the username currently logged in. ![]() IBA # 56020 AMA # 521481 ![]() Hold yourself to the same rules you expect others to follow. |
#9 | |
Lays er down
#10 | |
#11 |
Lays er down
Soldddddddddddddddddddddddd
#12 |
Yippee!
JPR Shorty Levers | KrazyWalle | 2008 - 2012 Ninja 250R Farkles | 5 | June 15th, 2014 10:28 PM |
Chinese Motorcycle Purse Snatchers vs Chinese Mob | akima | Videos | 10 | May 23rd, 2012 09:34 AM |
Levers: Shorty vs Standard | saxnbass | 2008 - 2012 Ninja 250R Tech Talk | 28 | December 16th, 2011 07:38 AM |
Shorty vs. Long Levers | THE BIG SITT | 2008 - 2012 Ninja 250R Tech Talk | 19 | October 8th, 2011 10:50 PM |
Shorty levers installed | chitor | 2008 - 2012 Ninja 250R Farkles | 8 | June 22nd, 2011 06:00 PM |
