View Poll Results: Which spark plug are you using?
NGK CR8E (stock) 20 50.00%
ND U24ESR-N (stock option) 1 2.50%
NGK CR8EK (dual ground electrode) 5 12.50%
NGK CR8EIX (iridium) 12 30.00%
Other (please specify) 2 5.00%
Voters: 40. You may not vote on this poll
Old July 13th, 2012, 02:14 PM   #1
smokinsingle
L8APEX
smokinsingle's Avatar
Motorcycle(s): 07 KTM 950SMR, 06 KTM 450SMR, 99 KTM 300MXC, 00 Derbi GPR 50, 09 Ninja 250 racebike, race with www.cra-mn.org!
Spark Plug Poll
Whats everybody using?
I was using CR8EK switching to CR8EIX
www.joemillersmoderngarage.com www.starr-cycle.com
***The most important concept of science isn't memorizing facts, it's observation of phenomena.***
smokinsingle is offline   Reply With Quote
Old July 13th, 2012, 05:54 PM   #2
cuz
cuz
cuz's Avatar
Motorcycle(s): 09 ninja 250r
cr8eK
How come the change over?
THE GOOD LIFE
cuz is offline   Reply With Quote
Old July 14th, 2012, 08:08 AM   #3
smokinsingle
L8APEX
Originally Posted by cuz View Post
cr8eK
I dunno...Advertised hype has got me convinced there is another .1 hp to be had with the Iridiums
Old July 14th, 2012, 08:59 AM   #4
Snake
Snake's Avatar
I am using the iridium plugs.
Old July 14th, 2012, 09:23 AM   #5
cuong-nutz
cuong-nutz's Avatar
I think I'm using the stock type plugs. They're cheap and I replaced the last set (although still good) when I did my valve adjustment. I'll probable do the same as it's getting close to my second valve adjustment already.
HalfFast Racing Team
Old July 20th, 2012, 05:46 PM   #6
ROADandTRACK
R&T Suspension
ROADandTRACK's Avatar
CR8EK or CR9EK changed often
ROADandTRACK is offline   Reply With Quote
Old July 29th, 2012, 01:28 PM   #7
mkulchar
mkulchar's Avatar
Motorcycle(s): 2010 250r ninja
Im goin to be changing my plugs to make sure that it elimate the possiblity that my plugs are bad. Is there really a difference between the CR8E and the EIX? has anyone noticed any difference in the 2?
mkulchar is offline   Reply With Quote
Old July 29th, 2012, 02:21 PM   #8
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
NGK all the way. cr8e stock , cr9e for modified engine. And cr10e with nitrous.
Old July 29th, 2012, 05:54 PM   #9
mkulchar
mkulchar's Avatar
you can change your actuall spark plugs to difference sizes? and you mean "modified" what do u mean by that? full exhaust?
Old July 29th, 2012, 07:08 PM   #10
Racer x
Racer x's Avatar
I went from the # 8 to the #9 with full exhaust and pods. The cooler plug is good when running pump gas with hi compression pistons.
Old November 28th, 2015, 08:11 PM   #11
ROADandTRACK
R&T Suspension
Run the EK's. Same price.
Old November 29th, 2015, 08:59 AM   #12
HoneyBadgerRy
HoneyBadgerRy's Avatar
I'm running the denso U grooves right now, but next time I change them I will go Denso iridium racing IU01-24.
Last futzed with by HoneyBadgerRy; November 29th, 2015 at 09:31 AM. Reason: Adding knowledge
Old November 29th, 2015, 09:02 AM   #13
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
I voted CR8EIX, which is the equivalent to what I'm using on my 500. Stock for us is DR9EA, and I'm using the DR9EIX Iridium version of it. I used the IX plugs on my Vulcan, and they came standard on my Cobalt.
The smaller electrode results in a more focused and consistent spark. It also requires a stronger material, hence the exotic metals used in these (standard copper/nickel electrodes wear down more quickly, which would result in your tiny electrode completely disappearing before too long).
NGK 4218 CR8EIX IX Iridium Plug
Originally designed to improve starting and reduce fouling on two-stroke engines, a Fine Wire electrode was found to improve performance in four-stroke engines as well.
A smaller electrode requires less voltage to jump the gap, resulting in fewer misfires, which translates to increased fuel economy and horsepower. A smaller electrode also reduces flame quenching.
Reducing the electrode size on a standard nickel plug would result in a drastically shortened life span, so the smaller electrodes require exotic metals such as platinum or iridium to maintain (and at times surpass) the longevity of a traditional spark plug.
While a traditional center electrode is 2.5mm in diameter, NGK's Iridium IX series features a 0.6mm center electrode.
Note that the K plugs are made for specific engine designs that require a different type of plug, not as a performance upgrade. The difference of the plug gap area may or may not perform better for you (I have no personal experience to say either way). The extra electrode is added because that design tends to wear more quickly so they need a "backup" to avoid frequent plug changes.
NGK 3478 CR8EK Multi-Ground Plug
Some engine designs require the spark plugs have the ground electrode placed to the side of the Center Electrode rather than below as on a traditional plug. This may be for combustion chamber design as in the case of a rotary engine, or a surface gap design as used in leaner air/fuel ratio’s on industrial engines.
The side electrode design tends to wear faster than a traditional plug. Erosion at these points creates a larger gap between the center and ground electrodes, causing plug misfire. Thus, if the engine design requires a side discharge plug, more ground electrodes extend plug life. Multi-Ground plugs are offered in 2, 3 and 4 ground electrode designs.
It is important to note that multi-ground does not mean multi-spark, there will still only be one spark at a time.
Caution should be made in selecting a "high performance" plug. If your car came OE with a multi-ground plug, your engine will likely wear through single electrode plugs, especially fine wire plugs, at a rapid rate.
I got used to doing ignition tuneups on the Syclone (~$50 for wires, plus 6 spark plugs) seemingly every other week, so paying an extra $8 per tuneup on the Ninja to get Iridiums instead of standard plugs doesn't bother me. Even if I see no measurable performance improvement, they last longer and don't foul as easily, which means less time wrenching and more time riding.
Old November 29th, 2015, 02:21 PM   #14
ROADandTRACK
R&T Suspension
For a racebike run the EK's.
Or don't.
Old November 29th, 2015, 03:50 PM   #15
HoneyBadgerRy
Or don't.
I haven't tried it yet, so I shouldn't be taking, however I wanted to add to that, denso IU01-24 is a sparkplug designed for racing, and should fit our motors.
Old November 29th, 2015, 08:12 PM   #16
mgentz
Board Member
I run these, but my motor makes a lot of heat like @Racer x 's motor does.
melted spark plug alex.s 2008 - 2012 Ninja 250R Tech Talk 6 October 5th, 2012 12:16 PM
spark plug tool rideclassiv 1986 - 2007 Ninja 250R Tech Talk 11 March 19th, 2012 10:49 AM
spark plug removal eddiekay 2008 - 2012 Ninja 250R Tech Talk 3 October 21st, 2011 10:56 AM
Broken Spark plug? Yasko General Motorcycling Discussion 8 June 8th, 2011 08:39 PM
Spark plug reading Racer x 2008 - 2012 Ninja 250R Tech Talk 14 October 7th, 2009 07:53 PM
